Author Topic: NICD or NIMH  (Read 6550 times)
glenpens
NICD or NIMH
« on: March 26, 2007, 04:50:43 pm »
Which batteries would you use in a rc buggy. 7.2v NICD or NIMH
Glen
Re: NICD or NIMH
« Reply #1 on: March 26, 2007, 07:41:22 pm »
NIMH seems to be the way to go these days. NiCads are being phased out anyway.
glenpens
Re: NICD or NIMH
« Reply #2 on: March 26, 2007, 08:13:52 pm »
Thanks for the information.
I have just been told it looks like NICD batteries are likely to be banned
Glen
HS93 (RIP)
  • I cannot spell , tough
Re: NICD or NIMH
« Reply #3 on: March 26, 2007, 09:33:10 pm »
Nicads only go to ABOUT 2200 mah where as Nimhs go to 4500 mah and above  IN sub"C" size.  Peter
justboatonic
Re: NICD or NIMH
« Reply #4 on: June 10, 2007, 09:42:09 pm »
Yep, definitely Nimh's unless you want to run brushless motors then I think you must use Li-poly packs and dedicated speedo.
Mankster
  • Wheelerdealer
    • RC Model Submarines
Re: NICD or NIMH
« Reply #5 on: June 10, 2007, 09:58:20 pm »
Brushless motors will work of any battery, though you do need a dedicated ESC.
alan colson
  • I Just Dabble In Model Boats
Re: NICD or NIMH
« Reply #6 on: June 11, 2007, 05:07:36 pm »
I spoke to John & James (Model Power) at the Alfold show recently and I think they said nicads will not be available after July next year
grasshopper
    • A1 Hobbies Ltd.
Re: NICD or NIMH
« Reply #7 on: June 11, 2007, 07:34:42 pm »
Get an engine....tempermental, noisy, smelly (in an addictive sort of way) and loads of fun - and to keep it runnning bung in more fuel...non of this waiting to recharge business
J.beazley
  • The building never ends
Re: NICD or NIMH
« Reply #8 on: June 11, 2007, 07:48:37 pm »
So whats everyone to do when they do ban Ni-Cds  ??? surely the price of the higher Mah batterys will come down to a more affordable market.
on the cheeky side all unwanted Ni-Cds forward to me i can make good use of them  ;D
Jay
justboatonic
Re: NICD or NIMH
« Reply #9 on: June 11, 2007, 09:40:28 pm »
Is that right? I thought brushless motors wouldnt work with a 'normal' ESC and required a brushless ESC which only worked with Li poly packs.
Welsh_Druid
Re: NICD or NIMH
« Reply #10 on: June 11, 2007, 10:42:28 pm »
I just checked this with my RNLI Hovercraft which has Brushless motors and the special Esc. for brushless motors.
I tested the motors with an 11.1v Li - poly (their usual supply) and then with a seven cell (8.4v) Nimh pack.
The motors run fine on both,  but of course slower on the Nimh.
Don B.
tobyker
Re: NICD or NIMH
« Reply #11 on: June 11, 2007, 11:33:48 pm »
My airboat goes just fine with a brushless bell motor and 7.2 Nicad. However I was warned by All-Electric R/c who supplied the motor and ESC that the ESCs are set up for the higher voltages of LiPo batteries, and to cut off at 3 volts per cell or so to protect them, so that I might not get much of a run if I only started with 7.2v. This may be why people associate brushless motor/ESC combinations with LiPos, since the manufactureres assume that you are going to use them in flying machines which use LiPos for lightness. I think if I did use a LiPo in the airboat it would take off ; as it is I get as long a run as I can handle.
White Ensign
  • Limits must be limited!
Re: NICD or NIMH
« Reply #12 on: June 12, 2007, 11:14:58 am »
There is no difference for the motor if the power comes out of an Li-Po or Nicad/NiMh or dry-cell.....DC is DC, you only need a different speed-controler.
Also it is not possible to connect two brushless motors on one speed-controler.
If you compare the Nicads to NiMh you will find on the same size the NiMh with about two times the capacity, no memory effect and a better line of power until the end. If you calculate it now, you`ll find the NiMh (even if they are a bit more expensive) a better value for your money.
I.e., Nicads are in Sub C available up to 2700 mAh, the same size of NiMh are about 4400 now. Take the price and compare it, plus the advantage that the memory-effect in Nicads break them much earlier in their service, plus the price to get the same effectivity to come up to the NiMh.....- you`ll easily find it worth it.
Just my pennies.......
Jörg
When God created planet earth, he made it with 75% of water. Bet he had the modelboaters on his mind!
Re: NICD or NIMH
« Reply #13 on: June 12, 2007, 07:30:26 pm »
If you want a cheap place fro batts try the component shop no connection just a satisfied customer Stavros
wombat
Re: NICD or NIMH
« Reply #14 on: June 12, 2007, 08:06:25 pm »
You don't need a LiPo for brushless motors - anything with the right voltage. However if the weight is an issue the LiPo gives the gretest energy density.
I think also, the peak current that a LiPo source is much higher than either NiCd or NiMH battery. The problem gets worse as you increase the capactiy of NiMH cells as the internal resistance of the cell goes up becuase of the way they boost the capacity - by increasing the surface area of the electrodes.
Wom
justboatonic
Re: NICD or NIMH
« Reply #15 on: June 12, 2007, 10:22:47 pm »
Thanks for clearing that up folks. You learn something new every day!
White Ensign
Re: NICD or NIMH
« Reply #16 on: June 12, 2007, 10:23:32 pm »
Wom, don`t forget to say that you need a special charger for Lipo`s and that the might explode if they run in service under their nominal voltage.....
Lot´s of users of mobile telephones, Laptops and Notebooks may tell a story about it....
Jörg
wombat
Re: NICD or NIMH
« Reply #17 on: June 12, 2007, 10:39:01 pm »
Good point Jorg (sorry about the missing umlaut)
Most appliances that use LiPo have a shut-down that prevents startup if the battery voltage is too low.
LiPo batteries need a properly designed smart charger - don't try to use a SLA charger or NiCd/NiMH charger unless the fire insurance is up to date.
Here is a link with more info:
http://www.powerstream.com/li.htm
Wom
Re: NICD or NIMH
« Reply #18 on: June 13, 2007, 06:51:09 am »
Page created in 0.037 seconds with 17 queries.
