Author Topic: Should I lubricate my Raboesch Waterproof Propshaft?  (Read 3476 times)
rmaddock
« on: January 23, 2012, 01:32:44 pm »
Well, should I? They're described as "totally maintenance-free" but what I can find, opinion-wise, on t'internet varies.
Would I potentially do any hard by adding a drop of oil? Will it do any good?
gwa84
Re: Should I lubricate my Raboesch Waterproof Propshaft?
« Reply #1 on: January 23, 2012, 02:32:49 pm »
that depends if ther are eny rubber parts to the waterproofing side of things then oil will degrade it and make it leak
« Reply #2 on: January 23, 2012, 04:55:12 pm »
Wouldn't use oil but if you feel you need to lubricate I would use silicone grease.
It does say totally maintenance free so I would not bother. :-))
rmaddock
« Reply #3 on: January 23, 2012, 05:14:34 pm »
Then, on sober reflection and taking into account my natural laziness, I shall not.  :-))
« Reply #4 on: January 23, 2012, 05:22:00 pm »
Why not just look it up? The answer is here: http://www.model-dockyard.com/acatalog/Raboesch_Waterproof_Propshafts.html
rmaddock
« Reply #5 on: January 23, 2012, 05:44:19 pm »
Thanks Colin.
I did look it up. I saw that site as well as Cornwall MB from whence I bought the shaft. However, if one keeps looking there are plenty of apparent references to individuals using one sort of lubricant or another...hence the question.
« Reply #6 on: January 23, 2012, 05:52:26 pm »
Well, surely if the manufacturer says it doesn't need it that's it isn't it? As stated above, the danger is that some lubricants can damage components not intended to be lubricated, particularly seals, and it's not always immediately obvious. I would suspect that it's a thin film of moisture on the seal that provides the lubrication at the prop end without actually allowing water to enter.
« Reply #7 on: January 23, 2012, 06:08:06 pm »
It mentions sintered bronze bearings.
These are designed to be impregnated with oil in manufacture
AKA oilite. That being the case the lubrication is built in.
rmaddock
« Reply #8 on: January 23, 2012, 06:19:19 pm »
Thanks all.
Page created in 0.014 seconds with 17 queries.
