Author Topic: CNC services  (Read 1970 times)
phil b
CNC services
« on: January 12, 2013, 10:34:47 am »
Does anyone know of a company who can cut a cnc kit from paper plans?
Lash151
Re: CNC services
« Reply #1 on: January 12, 2013, 11:00:19 am »
Hi... I am looking into this too. You normally need to supply autoCAD files... I would imagine it would cost a lot more if you had to get the plans drawn for you. What I have done is used the original boat plans I found on the internet, traced them using Illustrator, which I am more comfortable with, then importing them into AutoCAD to refine them... With these files, you can get the pieces cut. Also, having just one set of pieces cut is a lot more expensive than having multiple sets.... It all depends on how much you are prepared to spend! I recently got a quote for three sheets of parts cut from three different thicknesses of birch ply... With me supplying the AutoCAD files, ready to go, it came to about £240 +vat... If I had wanted 50 sets of parts it would have been much cheaper. This was an industrial cutting service so perhaps not ideal... I have requested a quote from Model Boat Bits...hopefully this will be a lot less. What boat are you planning to make?
Lee
phil b
Re: CNC services
« Reply #3 on: January 12, 2013, 11:24:49 am »
Not very original but I have ordered a set of ORCA plans from here http://www.patscustom-models.com/boatplans.htm
I have not received them yet. I knoe SLEC will cut plane kits from paper plans this may be an option dependint on the thickness of material needed
I will have to wait untill the plans arrive.
phil b
Re: CNC services
« Reply #4 on: January 12, 2013, 11:26:06 am »
Thanks for the link Shipmate60
Page created in 0.431 seconds with 17 queries.
