December 23, 2025, 01:16:16 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
Water Cooling Pump
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Water Cooling Pump (Read 1949 times)
Terry
Full Mayhemer
Offline
Ebenfurth Austria
Water Cooling Pump
on:
July 03, 2013, 04:08:48 pm »
Hi all,
can anyone recommend a 6-12 volt water pump for a motor/esc. cooling system. I have only found the Robbe and Graupner ones which are for intermittent use only, so not suitable for this application.
Cheers, Terry.
mrsgoggins
Full Mayhemer
Offline
Model Boat Mayhem Forum is the Best!
Oldham
Re: Water Cooling Pump
Reply #1 on:
July 03, 2013, 04:20:49 pm »
Try a windscreen washer pump from scrapyard or EBay. If you hang it from the silicone pipes rather than bolt it to the hull is should be quiet. Good luck
Subculture
Full Mayhemer
Offline
North London
Reply #2 on:
July 03, 2013, 04:39:59 pm »
I don't think any of the windscreen pumps will stand up to continuous operation, they're not really designed for that sort of thing.
If a water pickup tube in front of the prop is out of the question, then perhaps consider constructing a small centrifugal pump to be driven off the main motor via belt drive.
django
Full Mayhemer
Offline
I want to live forever, so far so good
Chatham Kent
Reply #3 on:
July 15, 2013, 11:02:45 am »
I have used windscreen washer pumps from Halfords or kit car suppliers for years & never had a problem even when restricting the flow to look more realistic . Make sure they are not mounted on a hard surface as they can be a bit noisy. I mount mine on a bed of silicon Django
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
Water Cooling Pump
