Author Topic: Sanding sealer  (Read 3334 times)
Colin.L.
Sanding sealer
« on: August 03, 2013, 12:17:04 pm »
Does anyone use sanding sealer? I can't get any locally except stuff that's only good for a wax finish. And I've been told you can't post solvents anymore.
inertia
Re: Sanding sealer
« Reply #1 on: August 03, 2013, 12:26:00 pm »
Re: Sanding sealer
« Reply #2 on: August 03, 2013, 12:30:14 pm »
The stuff from CMB dave mentioned is good stuff, bit smelly tho
Re: Sanding sealer
« Reply #3 on: August 03, 2013, 01:58:59 pm »
Clear Cellulose (If you can still get it) and a slack handful of Talcum powder.   O0   Cellulose thinners if you're going to use the former for Tissue covering the hull.
    Regards   Ian.
Re: Sanding sealer
« Reply #4 on: August 03, 2013, 02:02:53 pm »
Use Halfords clear laquer it will sink into the wood and bring the nap of the wood and do the same job apply as many coats as you like
Colin.L.
Re: Sanding sealer
« Reply #5 on: August 04, 2013, 08:22:43 pm »
Thanks for all the tips , I have found a local supplier of the Deluxe range of products, will check them out. And I have just bought some Halfords clear laquer for my son's plastic model he's making, might have just 'borrow' some of that back!
