Pages: 1 [2] 3   Go Down
Author Topic: AZIZ Build  (Read 20597 times)
Darksheer
more progress
« Reply #25 on: January 24, 2014, 02:41:43 pm »
still waiting parts   the postal service is not quick to say the least
work done on main mast and bridge and started adding lights to the fittings
Re: AZIZ Build
« Reply #26 on: January 25, 2014, 12:55:17 am »
Darksheer....that is an interesting anchor winch motor/servo..... O0
Car to share how the mod was achieved?...does it run 360 degrees +? ..how do you control it?.....
Darksheer
Re: AZIZ Build
« Reply #27 on: January 25, 2014, 03:08:50 am »
its a standard servo with some simple modifications
I tore one down and took pictures
ill explain each photo
ok here is a standard futaba digital servo that volunteered for the operation
pretty much any servo will work
first thing you do is remove the 4 screws off the bottom and take the lower and upper half of the servo apart
next you pull the final drive off the top of the servo this might be on tight if it has a bearing race on it just carefull work it back and forth and it will pop off
once you have the drive off you will notice a small tab near the bottom of the drive stem this has to be removed so you get 360 traverse once its removed refit the post to the servo and make sure it rotates freely without catching
once you ensure it rotates freely look at the bottom of the post you will see a small slot inside the gear this bit attaches to a pot inside the servo that stops the servo at certain positions  usually this slot is removeable and can be popped out with needle nose pliers if its not removeable you will need to drill it out making sure the pot does not rotate with it replaced
once you get to the point you need to plug the servo in and power up your system the servo will start spinning
use your hand dandy needle nose pliers to turn the pot that is under the final drive gear util the servo stops
NOTE: sometimes the servo is already at true neutral so you dont need to turn anything basically if it stops on its own after a second dont touch anything   once it stops move the stick on the remote back and forth and you should see the gears move
at this point put the servo back together and you have a unlimited proportonal servo to use for anything you want
these servo's also make great motors and speed controls for small scale models like the lindberg coastguard tugs plastic kits
my lindberg diesel tug model is powered by a servo and i get 6+ hour runs off the reciever batteries which power everything
hope this helped
PS forum owner   if this needs to get moved to a how to section or something please feel free to move it
and apologies if this is in the wrong section
Re: AZIZ Build
« Reply #28 on: January 25, 2014, 04:12:40 am »
Thanks Darksheer....I had read similar comments ....but the additional detail here is helpful..... :-))
I am sure Martin or other moderators will not have an issue with you posting detail here as it related to your AZIZ build thread
Re: AZIZ Build
« Reply #29 on: January 25, 2014, 10:41:05 am »
A very handy tip which is useful.
As an addition, it's a good idea to drop hot candle wax on the pot to stop it turning with vibration.  (soft enough to alter it if needed)
ken
Brian60
Re: AZIZ Build
« Reply #30 on: January 26, 2014, 12:38:23 pm »
If you want to watch in greater detail there are lots of videos on youtube on how to make servo's 360 degree rotation.
Darksheer
Re: AZIZ Build
« Reply #31 on: February 05, 2014, 05:50:32 am »
more work done
got my bridge detail from a fellow club member he does fantastic work and bashed this out in about 90 minutes
working beside him at meets is disturbing you turn away for a few minutes and when you look back another part of a ship has appeared on his cutting board
more work done on the bridge area
main mast coming along nicely
new pusher bow 75% finished and installed
more to follow
thanks for looking
Darksheer
Re: AZIZ Build
« Reply #32 on: March 12, 2014, 03:12:59 am »
Rather a large update tonight been very busy with other stuff but I have gotten alot done
running gear all installed finally
power panel mounted and sorted
rear deck finally lined up and ready for glue
bridge completed needing final details and weapons
scratch built fire monitors
they will function and have about 70 degree arc rotation hooked up to a 12 volt fuel pump
thanks for looking
Brian60
Re: AZIZ Build
« Reply #33 on: March 12, 2014, 02:45:56 pm »
Nice. I might have missed it earlier, how did you scratchbuild those railings?
Darksheer
Re: AZIZ Build
« Reply #34 on: March 12, 2014, 11:34:17 pm »
the railings came with the kit the fire monitors are scratch built
Darksheer
even more work done now with extra bacon roll
« Reply #35 on: April 04, 2014, 05:12:45 am »
more work done
New Pusher bow finished and primed
modified rear cable ramp/loading ramp  finished
front deck and bridge area finished and test fitted
rear deck with winch placement and towing gear and inner ribs installed speaker is hidden in side two 20 foor seacans that will be covered in a tarp so the speaker isnt blocked
interior bridge detail fitted and painted
lighting is next
thanks for looking
david48
Re: AZIZ Build
« Reply #36 on: April 04, 2014, 09:21:12 am »
I like your build very much ,please can you tell me about the power pack.Please can any one tell me if Action do anything the same
David
inertia
Re: AZIZ Build
« Reply #37 on: April 04, 2014, 09:35:39 am »
David
No, they don't.
The Harbor Models unit has several different voltage outputs from a 12v input (3, 4.8, 6 and 12), all fed by fan-cooled linear voltage regulators. All outputs are via circuit breakers. It is quite a bulky affair and costs a hundred and twenty bucks in the US. With shipping and VAT you'd be looking at maybe a hundred and seventy quid in the UK. ACTion's power D/Bs are all similar in that they are fused and the output terminals are all at the same voltage as the input, with the exception of the 5v flylead to feed power to the receiver. You'd get six of them and change from £170.
http://www.harbormodels.com/site08/main_pages/power_distribution_panel.htm
DM
inertia
Re: AZIZ Build
« Reply #38 on: April 04, 2014, 10:43:19 am »
Sorry! Forgot the currency conversion! Make that about £105 in the UK.
DM
david48
Re: AZIZ Build
« Reply #39 on: April 04, 2014, 02:29:18 pm »
Thanks for the quick response Inertia.I have an Action DB  on stock will have a bit of a rethink .Thanks again
David
Darksheer
Re: AZIZ Build
« Reply #40 on: April 04, 2014, 05:55:07 pm »
here is a photo of my mobile sitting beside the power panel  might give you a better view of its actual size
its basically the same dimensions as 3 mobiles stacked on top of each other
which in larger boats is almost nothing
the harbor models sound module is tiny about the size of a 20 pack of cigarettes but is insanely loud
Darksheer
More work
« Reply #41 on: April 15, 2014, 04:47:58 am »
things are coming together fast now I should have her in the water finished when the pond thaws in the next few weeks
everything is done its just a case of adding all the fittings and finishing the front deck off leaving that till last so its easier to get inside the hull if i need to change something
does anyone know where i can get modern ship decal's markings in 1/48th 1/50th in either canadian or british navy
thanks for looking
GAZOU
Re: AZIZ Build
« Reply #42 on: April 15, 2014, 07:21:28 am »
Look here
http://www.becc.co.uk/
htI am filled with admiration for your  work
Darksheer
Re: AZIZ Build
« Reply #43 on: April 29, 2014, 07:19:04 pm »
loads more to add today
she went in the water on sunday and it worked out well had a few small snags but over all very happy with the performance
fried the bow thruster speed control "was about 6 years old" that will teach me to recycle old parts
Y splitter to fire monitors cracked wide open "water stayed inside the boat instead of going out "
rear deck leaks like a sieve " going to seal the deck down with silicone  people are right this is a very wet boat over the rear cargo deck "
adding the final detail over the next few weeks and once the weapons arrive she will be finished
enjoy the videos and pictures
new rear deck and loading ramp finished
new pusher bow finished and bumpers installed
didnt like the small crane that came with the kit so i built and added a larger more funtional one with a longer reach
bow detail being added
flood lights on the rear cargo deck
bow work lights
overall view
http://www.youtube.com/watch?v=FnHFIcZEcMI&feature=youtu.be
https://www.youtube.com/watch?v=v3NdOD0rsa8#t=60
Darksheer
AZIZ Build final post she is finished !!!!!!!!!!
« Reply #44 on: May 30, 2014, 05:37:49 am »
well its been about 6-7 months and she is finished the last parts have arrived and all the fittings are mounted
thanks everyone for the advice and help i got from the forum members and particularly the painting advice that saved me
here she is on the work bench finished
JaS
Re: AZIZ Build
« Reply #45 on: October 27, 2014, 11:27:22 am »
Beautiful, well done!!
/Jack
Re: AZIZ Build
« Reply #46 on: October 27, 2014, 08:07:47 pm »
A beautifully constructed boat with an eye for smooth detail.
Well done.   :-))
Ken
Re: AZIZ Build
« Reply #47 on: October 27, 2014, 09:01:46 pm »
I think our friend GAZOU would approve of this rendition.......congratulations to the builder :-)) ..... Derek
GAZOU
Re: AZIZ Build
« Reply #48 on: October 28, 2014, 03:30:50 am »
 ok2
Why I    ? {-)
I find this very clean kit, that changes us the one that we saw recently. There are things which surprise me as the accommodation of the high speaker or the survivals  orange but it is very well made and the paint is attractive  :-)) :-)) :-))
Re: AZIZ Build
« Reply #49 on: October 28, 2014, 04:39:56 am »
Why?........possibly a little different to a recent AZIZ build  >>:-( that did not take your pleasure   .......Derek
Pages: 1 [2] 3   Go Up
Page created in 0.353 seconds with 17 queries.
