Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ... 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 247285 times)
missyd
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #200 on: August 11, 2016, 07:50:12 pm »
Thanks a lot Mark.
I used normal masking tape to masl windowns etc from 3M (BTW I only buy 3M masking tape). Not ideal for the stripe but it came out ok. Had to repaint some of the imperfections.
Masking tape is not as good as the small special tape used to spraypaint cars ets .... but the glue from the professional small masking tape damages the paint a lot (it did on the CM).
I did not clear coat the tape. Nothing goes through it.
Danielle
jarvo
  • Etherow model boat club
« Reply #201 on: August 11, 2016, 08:47:11 pm »
Thanks for that Danielle, i use 3m as well, cheep gives a cheep job, try tamiya tape for the fine lines, it does compound curves and does not damage the underlying paint, but it is expensive.
Mark
Tugs are for pulling
« Reply #202 on: August 11, 2016, 10:14:37 pm »
MMM smooth! Great work on the painting and looking forward to the next part of the project:O)
missyd
« Reply #203 on: August 12, 2016, 06:56:38 pm »
Thanks a lot my friends!!!
Today I added the rudder to its shaft/sprocket combination.
Fixed the hull to my small wheeled workcabinet.
In the end I did a cardboard deck to design where what equipment will go. As you know I do not have plans of the original deck attangements.
Danielle
« Reply #204 on: August 14, 2016, 11:02:25 am »
That is a clever idea for a cradle Danielle. I it a general purpose working cradle or the one that the Nuova will always have?
missyd
« Reply #205 on: August 15, 2016, 04:45:16 am »
Its just a temporary one .... I will make a nicer one ... something like you see when the boat is out of the water for refurbishment/new color etc.
Danielle
missyd
« Reply #206 on: August 16, 2016, 07:35:12 pm »
More work done like: Rudder servo, Deck stringers, Pump for bow truster
Danielle
« Reply #207 on: August 17, 2016, 12:08:29 am »
Hullo Danielle....I see you have again used that link chain & plastic sprockets for the rudder drive again......I think it is a great solution :-))
With the 1:1 ratio.....your Hitec HS325HB servo could throw the substantial rudder from full hard over 110 degrees in ~~0.4 seconds....and for realistic operation you need a steady hand so no not to provide unrealistic rudder movement. From this it appears you have two options that you could consider
1. Increase the diameter of the driven sprocket  to provide ~~ 3:1 reduction ratio [sufficient space appears for this diameter] however this would still provide  a rudder movement of ~~ 1.2 seconds......
2. The second option could be to install an ACTion P96 servo morph.......these are excellent devices and their reputation speaks volumes for their functionality......you could increase the rudder throw from 110 degrees to ~~ 175 degrees or so, and set the rudder moment speed to a realistic scale
missyd
« Reply #208 on: August 17, 2016, 04:33:13 pm »
Hi Derek ... you're right. I'll leave it as it is .... did it the same way with the Cornelia Marie. Never had any problems with it. You have to steer gently and everything is fine!
More work done ....
Dummy placement of the things ... I can see the net winch, exhaust pipes, staircase to lower/upper deck.
Pump with connected hoses to the bow truster ...
Deck planking .... first layer .... second one will be nicer ...
Danielle
missyd
« Reply #209 on: August 19, 2016, 03:21:17 pm »
A lot of things done the last two days ... thank god its friday and I will not work til monday ...
Fitted the Controllers ... left one for the prop motor and right one for the bow truster pump.
Finished the deck ... which will be covered with nice wood later ... what kind of wood would you suggest to buy for this job. The original has greyish/brown color and was clearcoated once.
I also started with the living quarters and stairs to the upper deck ...
Danielle
« Reply #210 on: August 21, 2016, 10:49:25 pm »
Us model ship builders don't use enough chain in our builds (apart from visual anchor chains etc). It is good to see you using some on your rudder system.
Re Nice decking, have a look at what that exceptionally skilled Australian has done on his fishing boats, it is usually mouthwateringly good.
missyd
« Reply #211 on: August 22, 2016, 06:00:52 am »
I like the chain for the rudder ... no fiddling and adjusting ...
Decking isn't the final one ... I will cover everything with some smaller and shorter planks ...
Danielle
missyd
« Reply #212 on: August 22, 2016, 05:04:26 pm »
Monday and another week ahead which I hope to use to get the Nuova Lorendana a step forward finishing it.
Some planking done ...
And the side panel need some steel reinforcments ....
Danielle
missyd
« Reply #213 on: August 23, 2016, 03:46:32 pm »
Finished the side panels today .... just the blinds for the windows and two doors have to be made.
Danielle
« Reply #214 on: August 23, 2016, 10:36:19 pm »
Very neat and solid looking work - she's coming along nicely Danielle. :-)
« Reply #215 on: August 23, 2016, 11:04:34 pm »
I bet the model smells great with all that pine inside it! Excellent progress Danielle.
missyd
« Reply #216 on: August 25, 2016, 05:56:15 pm »
Actually it smells a little bit from the pine .... ok2
More work done ... I have to finish everything on the deck before I can put the "roof" on ...
Danielle
missyd
« Reply #217 on: August 26, 2016, 05:24:57 pm »
Finished the walls today ... and the stairs to the upper deck ...
Danielle
« Reply #218 on: August 26, 2016, 10:19:26 pm »
More excellent woodwork - love the way everything appears square and true - she's coming along nicely.  :-))
« Reply #219 on: August 26, 2016, 10:36:07 pm »
Amen Ray, that is one great project. I do like these touches of detail. I hope we will be able to see them when the ship is complete?
missyd
« Reply #220 on: August 28, 2016, 04:55:25 pm »
Some of the details will be covered by the upper deck ....
Danielle
« Reply #221 on: August 28, 2016, 08:23:51 pm »
There's something very realistic about the way you have your timbers stacked! Lovely work Danielle.
missyd
« Reply #222 on: August 29, 2016, 06:11:28 pm »
Thanks a lot ... I keep thing clean and ready to use on the boat ... but if you would see my worktable ....  :o
Enlarged the deck opening a little bit ... so I can lift out even the netwinch with it ...
... 2h planking a day ... keeps the boredom away ...
Danielle
« Reply #223 on: August 29, 2016, 08:09:38 pm »
Very true! Lovely work. Regarding your bench, I know what you mean as mine are, shall we say' chokka bloc'!
missyd
« Reply #224 on: August 31, 2016, 07:08:24 pm »
Thanks a lot  :-))
Deck planking finished!
Danielle
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ... 28   Go Up
