Author Topic: Robbe F14 Navy  (Read 6687 times)
adamD98
  • Born free, forced to work!
Robbe F14 Navy
« on: July 18, 2014, 11:41:31 am »
Hi all,
I've been using spectrum and planet 2.4 sets for a while, however I've noticed a lot of folk tend to go for the Robbe F14 gear.So I just wondered, what is it about that particular set up and if I were to get myself into the F14 navy Rx/Tx, what advice would you give?
 Is it difficult to get used to they system, to add features etc?
Cheers,
-Adam-
Mankster
  • Wheelerdealer
    • RC Model Submarines
Re: Robbe F14 Navy
« Reply #1 on: July 18, 2014, 01:30:13 pm »
The F14 is a great radio if  by fitting the optional decoder and switch modules ( or just simple switches) or If you want to run submarines when you will need 40mhz rather than 2.4Ghz.
You might have some need for theNavy twin stick -though if it is to control motors independently, I find a mixer is better for most instances.
I would get the FC-16 to benefit from the computer and add a Navy module separately. The F-14 and FC-16 can both be fitted with switchable 2.4ghz pretty easily.
U-33
  • K-157 Vepr. Akula-11
Re: Robbe F14 Navy
« Reply #2 on: July 18, 2014, 01:47:38 pm »
I use an FC-16, having previously owned an F-14, and I find them the nearest thing to the perfect radio. I suffer badly from rheumatoid arthritis in my shoulders/wrists/hands/fingers, so mine is fitted with the extended sticks, and I use it in a tray, the tray takes the weight away from my wrists and makes the whole thing so easy and comfortable to use.
Mine is fully modded to within an inch of it's life, I think I have around 90 functions at my disposal, although I only use seven of them...or is it eight? I'll have to count them...
IMHO...superb radios.
adamD98
Re: Robbe F14 Navy
« Reply #3 on: July 18, 2014, 01:58:04 pm »
 :o :-))
 Well I think that just about answers that gents, thank you very much indeed.
I will indeed require the twin stick, as it will be used for my warships, all of which are of course twin props. I assume with the twin stick, I do still get independent running on my shafts? Also, regards to set up, is it just as you would usually use esc's and what not?
Cheers,
-Adam-
Mankster
  • Wheelerdealer
Re: Robbe F14 Navy
« Reply #4 on: July 18, 2014, 02:12:58 pm »
Yes everything is the same as any other radio, interms of hooking up ESC's to the receiver etc.
Here a thread about converting to 2.4ghz.
http://www.modelboat mayhem.co.uk/forum/index.php/topic,24085.0.html
gribeauval
Re: Robbe F14 Navy
« Reply #5 on: July 18, 2014, 03:04:30 pm »
This is the corerct link as the one above is incomplete.  {-)
http://www.modelboatmayhem.co.uk/forum/index.php?topic=27200.0
True Lifeboat Nutter!!
adamD98
Re: Robbe F14 Navy
« Reply #6 on: July 18, 2014, 03:46:53 pm »
Thanks guys that's very much appreciated indeed. I shall be investing in that case, roll on payday!
 I think conversion to 2.4ghz is an absolute must for me really, being a skimmer I shouldn't have to many problems on the signal front  ;)
Cheers,
-Adam-
U-33
Re: Robbe F14 Navy
« Reply #7 on: July 18, 2014, 03:52:29 pm »
You can convert an F  series to dual frequencies as well...40mHz, flick a switch, and onto 2.4gHz.
adamD98
Re: Robbe F14 Navy
« Reply #8 on: July 18, 2014, 04:32:52 pm »
Oh really? That is definitely worthy of consideration, especially for you sun dodgers! Haha
 I'm looking forward to ordering myself a set now.
Cheers,
-Adam-
U-33
Re: Robbe F14 Navy
« Reply #9 on: July 18, 2014, 05:24:57 pm »
Someone on here did that recently...now who was it? I believe it was Mark (username Grim Reaper).
mrlownotes
Re: Robbe F14 Navy
« Reply #10 on: July 18, 2014, 08:12:31 pm »
I use an F14 with the multiswitch/decoder modules added for loads of switching and it is a chunky reliable piece of kit. The transmitter is larger and heavier than most others, but the weight and size give it a presence that just feels good.
I was going to convert it to 2.4gHz but found out that you cannot then use the multiswitch/decoder modules.
I've not read anything yet to suggest otherwise, unless anyone here can confirm a way to do it.
If there was a conversion that preserves the use of the decoders I'd be the next in the queue.
I may be wrong but I don't think they are manufactured any more, although retailers are still seem to be advertising them. I'm sure someone will put me right on that also.
Bintur Ellenbach
Mankster
  • Wheelerdealer
Re: Robbe F14 Navy
« Reply #11 on: July 18, 2014, 08:18:19 pm »
Robbe still list is on their website, so assume they still make them.
The modules not officially supposed to work/supported on 2.4Ghz but I have seen at least one fully working radio (at one of the St Alban Dive in's I think)
mrlownotes
Re: Robbe F14 Navy
« Reply #12 on: July 18, 2014, 08:40:59 pm »
That sounds promising !
Bintur Ellenbach
adamD98
Re: Robbe F14 Navy
« Reply #13 on: July 18, 2014, 09:24:54 pm »
Interesting to hear. Me personally I'm not overly bothered if I have to stick to 40mHz to be able to use the modules. However if anyone can tell us otherwise regarding the 2.4Ghz that would be champion  :-))
 I am sure there will be a way, there usually is somewhere. As you say Mankster, if you have seen one, then there is obviously a way to do overcome the 2.4Ghz not supporting the module.
Cheers,
-Adam-
Re: Robbe F14 Navy
« Reply #14 on: July 18, 2014, 09:50:44 pm »
Sorry just not a convert of these overpriced overspeced table size  radios.
The best thing about them is the aerial stowage in the case.
Time Bandit
Re: Robbe F14 Navy
« Reply #15 on: July 18, 2014, 10:27:38 pm »
I converted a lot of F14 and FC16 to 2,4 GHz.
Multiswitch and Multiprop still work if you use one of these modules:
http://www.hobbyking.com/hobbyking/store/__9770__Corona_2_4Ghz_DIY_Module_RX_DSSS_.html
Very cheap but has no additional functions and a questionable declaration of conformity, why I would not use it in anything that flies or goes faster than 20 mph.
But you can also buy it at giantshark at around double price, so the importers risk in case any accident happens is up to them.
Or http://www.jetimodel.com/en/katalog/Duplex-2-4-EX/Transmitter-Modules-EX/
Much more expensive, but absolutely legal and in combination with the mini-box makes your F14 to an up to date Tx with hundrets of (useless) mixers....
Anything else is not working or not guaranteed.
Some Decoders still work, some not seems to be luck dependend sometimes.
regards
Tobias
mrlownotes
Re: Robbe F14 Navy
« Reply #16 on: July 18, 2014, 11:10:52 pm »
Thankyou for that, Time Bandit.
I'm tempted.
I won't have to ask what frequency anyone else is on any more and I won't need to remember to peg the frequency board.
Now, where's the credit card and let's get the soldering iron out.
Bintur Ellenbach
Page created in 0.824 seconds with 21 queries.
