Author Topic: servo  (Read 3417 times)
regiment
servo
« on: November 14, 2014, 02:35:44 pm »
my mate took his boat to the lake yesterday ok took it today servo acting up.. ok on right rudder but takes ages to get left rudder like a second hand on a clock but slower  any clues..  or any spare servos around  thanks gordon
inertia
Re: servo
« Reply #1 on: November 14, 2014, 02:48:14 pm »
Recharge or replace Rx battery first.
Disconnect rudder tiller arm from the servo and try it again.
Try servo on a different receiver channel.
Make sure the rudder turns freely in its tube when the pushrod is moved by hand.
DM
hmsantrim
Re: servo
« Reply #2 on: November 14, 2014, 02:55:45 pm »
 well if working t`otherday and playing up to-day sounds like receiver battery flat.  what about the speed control is it answering ok.
 Frank
regiment
Re: servo
« Reply #3 on: November 14, 2014, 03:22:10 pm »
hi all when we came back from the lake took servo out and tried it with new  batteries  the same.. ok on right rudder but moves very slow  on left put my servo in boat all ok gordon
inertia
Re: servo
« Reply #4 on: November 14, 2014, 06:36:39 pm »
So what is your conclusion, Gordon? This isn't "CSI", is it?
DM
regiment
Re: servo
« Reply #5 on: November 14, 2014, 08:11:56 pm »
hi not knowing what has gone wrong and I cannot fix it I will bin it forth with
hmsantrim
Re: servo
« Reply #6 on: November 15, 2014, 01:01:02 pm »
Hi Gordon.
 B4 you bin servo snip the lead off it as this can be re used
 frank
inertia
Re: servo
« Reply #7 on: November 15, 2014, 01:14:58 pm »
That's the one! Don't forget to remove the output disc/arm and the mounting grommets, too.
DM
Re: servo
« Reply #8 on: November 15, 2014, 05:13:33 pm »
And keep the disc retaining screw  :-)) :-))
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: servo
« Reply #9 on: November 15, 2014, 05:25:53 pm »
Keep it to strip down for turning into a propulsion unit - control board might be fine to experiment with.
Re: servo
« Reply #10 on: November 15, 2014, 08:46:18 pm »
The empty case makes a good storage box for those  'odd washers'.
ken
Ron Rees
Re: servo
« Reply #11 on: November 18, 2014, 04:16:24 pm »
I use the old servo gears to make miniature winches, plus a few washers and plastic tube....waste not want not.
