Pages: 1 2 3 [4] 5 6 7 8 9 10 11   Go Down
Author Topic: 1/48 Hunt Class MCMV HMS Quorn Build log  (Read 100530 times)
T888
Re: 1/48 Hunt Class MCMV HMS Quorn Build log
« Reply #75 on: December 01, 2015, 08:21:47 pm »
Thanks Ian,
To load pictures I will have use one app to change file type and another to resize that file. Don't full understand why but , This is the only way I can get photos loaded via iPad.
Regards David
Jerry C
« Reply #76 on: December 01, 2015, 10:11:55 pm »
T888, on an iPad I just email a pic to myself. When you press send it asks you to choose the size of the pic. Just choose the closest value below 300mb. When you receive the resized pic hold your finger on it and it will give you the option to save the image. Save it and use that pic to post on here. No apps required. Takes far longer to tell than to do.
Jerry.
radiojoe
« Reply #77 on: December 01, 2015, 11:14:58 pm »
Yep that's just what I do, windows resizes the resolution rather than the physical size it sounds a bit long winded but it's probably no longer than using a resizing app,  hope you had a good exhibition at Action Stations Dave.  :-))
T888
« Reply #78 on: December 02, 2015, 06:48:30 am »
Jerry,
Thanks I will try that.
Joe,
AS went well, Friday was a bit slow but Sat/Sun was flat out. I was not noting show any models, as I had commitments that kept me away Sunday.
Your build is moving at a great rate of knots.
Regards David
T888
« Reply #79 on: December 07, 2015, 04:16:10 pm »
Bridge, so far, still need to add more detail and tie in the fibro optics
Regards David
« Reply #80 on: December 07, 2015, 11:14:57 pm »
That's a lot of detail you have already Dave - even down to the bookcase and books :o
Interested in how you will go about installing the fibre optics on the bridge. :-))
Starspider
« Reply #81 on: December 08, 2015, 03:05:20 pm »
Had not even seen those, need new specs. Great skill  O0
colin
« Reply #82 on: December 08, 2015, 03:18:52 pm »
Don't forget a retaining rail for the bookcase {-)
Bit different to the Minesweepers open air types
(Ton class) that I used to mend in Port Edgar.
T888
« Reply #83 on: December 08, 2015, 04:13:57 pm »
Gents, thanks for your comments,
Ray,
Once I start installing the fibre optics I'll post picture showing how I do it.
For the detailing , I need to add ,maps printers, book tie downs and computers.
Regards David
T888
« Reply #84 on: December 09, 2015, 04:57:18 pm »
Fittings cast off last night
Regards David
« Reply #85 on: December 11, 2015, 10:36:58 pm »
Excellent detailing and also crisp castings. Very professional.
T888
« Reply #86 on: December 12, 2015, 04:50:29 pm »
Thanks for your comments,
I'm considering whether to start offering my fittings for sale,  as I'm retiring next year I will have more free time to make fittings.
Regards David
« Reply #87 on: December 15, 2015, 09:11:03 am »
It should also help subsidise your hobby! Even if it just keps you in Humbrol/Paints then that can't be bad?
T888
« Reply #88 on: January 03, 2016, 09:24:17 am »
Happy new year to all
Regards David
« Reply #89 on: January 03, 2016, 07:02:31 pm »
That mast is amazing!
T888
« Reply #90 on: January 03, 2016, 09:13:49 pm »
Thanks, I did hoped to have all the lights working but the wiring was a nightmare , so aborted that plan.
Regards David
T888
« Reply #91 on: January 07, 2016, 12:39:29 pm »
Picture of the actual mini gun ammo locker and my master ready for mould, I will be adding the side plates to the cast resin later.
Regards David
J.beazley
  • The building never ends
« Reply #92 on: January 10, 2016, 12:23:57 pm »
Really coming along nicely  :-))
T888
« Reply #93 on: January 10, 2016, 03:42:12 pm »
Thanks J ,
How your RCPV coming along,Mike to see some picture if you have any?
Regards David
T888
« Reply #94 on: January 16, 2016, 02:15:16 pm »
RIB and out board motor , I will make a mouldy using the RIB as HMS Quorn has two , puts I need Couple for another 1/48 scale OPV I'm making.
Regards David
T888
« Reply #95 on: January 17, 2016, 01:52:05 pm »
Casting made today
Regards David
T888
« Reply #96 on: January 22, 2016, 12:20:54 pm »
Picture of HMS Quorns main Radar
Regards David
Starspider
« Reply #97 on: January 22, 2016, 12:22:57 pm »
Nice rib mouldings and a very  nice radar  :-))
colin
T888
« Reply #98 on: January 22, 2016, 12:31:35 pm »
Thanks,
I also should have said , the Radar drive motor forms apart of the main radar support post, this has a planetary gear box, which is the black section of the radar post. This type of arrangement gives 6 rpm.
Regards David
Starspider
« Reply #99 on: January 22, 2016, 12:47:17 pm »
Hi is the motor you used in the radar a readly available motor?
colin
Pages: 1 2 3 [4] 5 6 7 8 9 10 11   Go Up
Page created in 0.167 seconds with 18 queries.
