Pages: 1 ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25   Go Down
Author Topic: Building the FV "Mady Jeanne"  (Read 205666 times)
missyd
Re: Building the FV "Mady Jeanne"
« Reply #550 on: May 08, 2021, 05:10:37 pm »
Ordered a 100mm Prop today. Looks much better on this big hull. The Motor is OK its a Krick Max Gear with 6:1 reduction. If the gearing is not ok I can change it for one with 3:1 reduction.My Workshop has much more space as I moved thing around. I have a big Metabo bandsaw and a brilliant Proxxon lathe. I also have fixed a rope train who can lift up to 150kgs.
Pic1: New rope train to lift things up to 150kg
Pic2: Makes mowing the ship aroung much easier
Pic3: The new boat trolley. The hull can be placed as you want on the trolley. And the deck will be level and the keel going downwards.
Pic4: Trolley with hull on it
Pic5: My Proxxon lathe...brilliant machine. It sits an a sturdy tool trolley with all my gadgets in it but tools.
Pic6: Placing the lathe on the trolley
Pic6:
Danielle
Taranis
  • Balne Moor MBC
« Reply #551 on: May 08, 2021, 05:12:46 pm »
Wow  :-)
ANDY
missyd
« Reply #552 on: May 08, 2021, 05:23:11 pm »
The Max Gear 6:1 motor turns at 2633rpm at 12V. I have the 12V Batteries ready....  ok2
Danielle
missyd
« Reply #553 on: May 11, 2021, 03:33:27 pm »
The hull with its new red underwater color.....there is no exact match for the anti fouling color normally used, but it will dry much darker....I may need more layers of this wonderful acrylic paint. I bought it from the artist shop nearby.
Danielle
missyd
« Reply #554 on: May 12, 2021, 03:49:19 pm »
More color found its way to the hull.....today the typical white triangle that most trawlers in brittany have.I used the artists acrylic color from SCHMICKE in Germany. Their Academy line dries waterproof.
Pic1: I use 10mm masking tape from Tamiya and normal masking tape from the DIY shop.
Pic2: 2-3 layers of Titanwhite and it looks rather nice. 1-2 layer later and its OK.
Danielle
missyd
« Reply #555 on: May 13, 2021, 02:48:33 pm »
Pic1 & 2: Today I used a lot of wood filler to get the ugly things away on the top two planks....wasn't easy to get it right by hand sanding. I also have to redo the rudder shaft with a new 5mm diameter brass one. You also may notice the unusual way how the hull is kept in place by 6 adjustable clamps. The hull is kept in the right angle on the trolley. Helps to keepthings straight and upright.
Danielle
Mark T
« Reply #556 on: May 13, 2021, 05:58:04 pm »
That’s looking nice  :-))   The work bench also looks industrial I really like the supports.
missyd
« Reply #557 on: May 19, 2021, 05:47:18 am »
Thanks a lot Mark. During my last visit in Brittany I saw similar supports used for maintenance work in workspaces in ports like Le Guilvenec.....
Danielle
missyd
« Reply #558 on: May 22, 2021, 05:00:44 pm »
A lot of work done this week....I spent many hours in my small workspace. The result are very nice. I build most of it without any plan and freestyle ... only with this method I can put all my fantasy into the build.
Pic1: The first support is cut.
Pic2: Overall view.
Pic3: You can see the Stringer and its radius.
Pic4: Opening in the deck is big and access to the 2x 4.5kg batteries ist easy. The hull holds also all my clamps!
Pic5: Hull in full. I have to build an easy access door to the ruddershaft. The servo will be in the bif deck opening. The deck at the bow will need a special construction.
Hope you like it.
Danielle
missyd
« Reply #559 on: May 25, 2021, 06:03:21 pm »
The next step was to fit the rudder servo (Hitec servo for sails) into a very small space. I always use the chain sprocket method. It came out rather nice but I worked the full weekend to get it right.
Danielle
missyd
« Reply #560 on: May 28, 2021, 03:55:54 pm »
More work done the last days.....
Pic1: I fitted the new 100mm dia prop.
Pic2: Krick MaxGear 6:1 Motor and its propshaft coupling
Pic3: To cover the opening of the rudder mechanism I made a cover that acts as the place where they can sort the fish/shellfish/whatever......
Danielle
Mark T
« Reply #561 on: May 28, 2021, 09:55:33 pm »
Thats nice work Danielle keep the updates coming  :-))
missyd
« Reply #562 on: May 30, 2021, 06:44:37 am »
Thanks a lot Mark ....  :-))
Finished the "fishbox/cover" ....
Pic1: Fishbox/cover ...only need to add magnets to told it in place in stormy weather ... I built this model to "play" with it in the waves.
Pic2: most of the 2mm ply deck is glued in....
Danielle
missyd
« Reply #563 on: June 02, 2021, 04:36:43 pm »
Today I worked at the bow.....
Pic1&2: I glued some little pieces of wood the have more contact surface for the glue
Pic3: Time for heavy metal... ok2 a piece of swiss railway track
Pic4&5: Jean-Jacque the future skipper of the Mady-Jeanne is inspecting the hull....
Danielle
missyd
« Reply #564 on: June 04, 2021, 06:45:06 pm »
Pic1-3: Working hard to have a nice deckPic4: Overall view of the hull from the stern. I must say its really a massive and heavy hull.
Danielle
Taranis
  • Balne Moor MBC
« Reply #565 on: June 04, 2021, 06:58:34 pm »
Impressive  :-)
ANDY
« Reply #566 on: June 04, 2021, 06:59:05 pm »
Big, heavy, but looking brilliant, great work Danielle  :-))
Mark T
« Reply #567 on: June 04, 2021, 09:00:13 pm »
Impressive  :-)
I agree this build is epic  :-)
missyd
« Reply #568 on: June 05, 2021, 05:16:44 pm »
Thanks a lot to you all!!!  ok2 :-))
More work done today. I finished the planking of the deck at the bow.....
Pic 1 & 2: The deck is huge! I could place my small circular Proxxon circular saw one one side and work on the other one.
Pic 3 & 4: I have to take the radius of the deck as the workplace of the skipper must have the same radius on the roof/window section....
Danielle
missyd
« Reply #569 on: June 10, 2021, 09:45:18 pm »
All planks glued to the deck.....
Pic 1 & 2: I may change the color of the deck....looks rather nice in dark brown varnish.
Pic 3: Sadly I tried to amputate my thumb .... just joking! ;) But I have a nasty deep cut in my thumb....will need some time to heal properly....
Sorry, no work can be done the next week or two..... %)
Danielle
missyd
« Reply #570 on: June 28, 2021, 02:33:24 pm »
After a break from building the trawler because of my insured thumb, its alright again but the scar is nasty, I had the time to test my trawler in the bathtub. Everything is OK and only a few KGs of additional Ballast are needed. I think I used 20kgs
Danielle
« Reply #571 on: June 28, 2021, 04:50:53 pm »
Brilliant Danielle, the boat that is, and its only a small modelling scar....we all have them  O0 O0
missyd
« Reply #572 on: June 28, 2021, 05:39:22 pm »
The scar is exactly at the place where I have to grip things....
Danielle
missyd
« Reply #573 on: October 26, 2021, 04:53:40 pm »
More work done this week!
Pic 1&2: Added window frames to all window openings
Pic 3: the intern in dark brown
Pic 4: Outside in titanium white
Danielle
missyd
« Reply #574 on: October 27, 2021, 03:59:58 pm »
Today I made the exhaust pipe. 10mm diameter brass pipe is all I had in stock...
Pic 1: Finished exhaust pipe before painting
Pic 2: Exhaust pipe after painting it with Tamiya "Flat Alu" paint (drying in the warm sun)
Danielle
Pages: 1 ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25   Go Up
