Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14   Go Down
Author Topic: Stevns Arctic Build  (Read 28527 times)
chipchase
Re: Stevns Arctic Build
« Reply #100 on: December 03, 2018, 11:17:15 pm »
Small update, I have decided to have just one support for the motor drive shaft, I attached the shaft into a hand drill to make sure it was running smooth, I was really pleased with the outcome  :-))
chipchase
« Reply #101 on: December 04, 2018, 09:04:00 pm »
Quite a bit done today thats both units up to the same level, the next job will be to make the nozzles and the bracket to secure them to the drives. I haven't managed to get the alloy tube yet but not desperate at the moment, the other photo is showing how the mould is progressing.
chipchase
« Reply #102 on: December 08, 2018, 08:38:46 am »
Hi all, after spending quite a while looking for the right sized alloy tube to make the nozzles  without any success i have bought a solid alloy bar off eBay. should have it early next week, it will be quite a big job boring it out to 84mm for the 80mm props.
We will see how the mini lathe copes with this as it will be at its maximum external jaw limits  {-)
Brian60
« Reply #103 on: December 08, 2018, 11:58:57 am »
Good luck with turning that size aluminium, but what  a waste of material  <:( I have been sitting on the fence over a new lathe for the last year now, finally jumped on to the side that says 'buy one' :} I'll be ordering it from Germany after Xmas, lets call it a late chrissy present.
Thinking about the wasted material, could you not mount a hole cutter in the tail stock and bore out a good portion to be set aside for future projects, in essence take a plug of material from the centre of the bar?
chipchase
« Reply #104 on: December 08, 2018, 02:43:40 pm »
It is a waste as you say Brian, I have never tried a hole cutter on alloy I don't know if it would cut. I am sure you will get a lot of enjoyment out of your new lathe  :-))
chipchase
« Reply #105 on: December 08, 2018, 02:54:13 pm »
I thought you might want a look at the first hull out of the mould, i am really pleased the way its turned out.
tugboyben
  • Kirkleesmodelboatclub
  • WARRIOR TUG BOAT
« Reply #106 on: December 08, 2018, 03:01:12 pm »
Afternoon Brian
That looks super so do the drives
Ill keep watching
Jason
chipchase
« Reply #107 on: December 08, 2018, 03:08:31 pm »
Afternoon Brian
Ill keep watching
Jason
Taranis
  • Balne Moor MBC
« Reply #108 on: December 08, 2018, 03:14:30 pm »
Usual quality  :-))  when can we place orders  8)
Is this any good 90mm OD 3mm wall makes 84 ID
https://www.ebay.co.uk/itm/Aluminium-Round-Tube-89mm-90mm-outside-diameter-section-pipe-Internal-ID-OD-/112744826221
Mark T
« Reply #109 on: December 08, 2018, 04:24:21 pm »
Thats really is beautiful work  :-))   You must be really pleased with the way the hull has turned out  :-)
chipchase
« Reply #110 on: December 08, 2018, 04:35:51 pm »
You have plenty to do Andy get your Maltby on the slips LOL, I found quite a few on eBay with 3mm wall but i wanted 6mm to give it some shape, I will try with the piece that I have ordered to see how it turns out  :-)) [size=78%]  [/size]
Taranis
  • Balne Moor MBC
« Reply #111 on: December 08, 2018, 04:39:17 pm »
Available in 6mm wall too
chipchase
« Reply #112 on: December 08, 2018, 04:45:28 pm »
It must be an age thing Andy I can not see 6mm available in the selection box
chipchase
« Reply #113 on: December 08, 2018, 04:47:17 pm »
Cheers it has taken a while to get to this stage but it has been worth it.
Taranis
  • Balne Moor MBC
« Reply #114 on: December 08, 2018, 04:53:30 pm »
No it’s not age Brian
The option isn’t there but the listing says 1.5 up to 6mm so worth contacting them
chipchase
« Reply #115 on: December 08, 2018, 05:01:41 pm »
Cheers Andy I will keep it in mind just incase I make a mess out of the metal i have ordered
Tafelspitz
  • Model Boat Bedlam
« Reply #116 on: December 10, 2018, 06:41:03 am »
That hull looks super smooth. Very neat!
We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology.  Carl Sagan
chipchase
« Reply #117 on: December 10, 2018, 03:29:18 pm »
Cheers, its turned out good
chipchase
« Reply #118 on: December 10, 2018, 03:34:40 pm »
Here are a few photos of the Arctic next to my Maltby both 1/32nd scale, I'm going to enjoy building this  :-))
Taranis
  • Balne Moor MBC
« Reply #119 on: December 10, 2018, 03:42:04 pm »
Awesome Brian  8)  thank you
tugboyben
  • WARRIOR TUG BOAT
« Reply #120 on: December 10, 2018, 05:08:37 pm »
Brian
What a beast of an hull.  you best start having three weetabixs {-)
Jason
chipchase
« Reply #121 on: December 10, 2018, 10:08:53 pm »
Cheers lads, really pleased with the outcome I don't think she is going to roll much with a fourteen and a half inch beam,
another photo showing the 5mm bulwark top rail built in  :-))
Taranis
  • Balne Moor MBC
« Reply #122 on: December 10, 2018, 10:14:54 pm »
Would £200 slivs buy me one  8)
From the black interior looks like Orion production  :-))
chipchase
« Reply #123 on: December 10, 2018, 10:20:50 pm »
Yes Orion Mouldings is going to market the hull plus a plan.
https://www.orionmouldings.com/modelboats.htm
Taranis
  • Balne Moor MBC
« Reply #124 on: December 10, 2018, 10:30:23 pm »
Looks like I was bang on with valuation.  O0
Thanks for all your hard work
Duly bought and paid by PayPal  :-))  so easy  :-)
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14   Go Up
