Author Topic: Sanctuary  (Read 2817 times)
Sanctuary
« on: June 21, 2018, 02:13:44 pm »
It may be a jumble but it is my jumble
Re: Sanctuary
« Reply #1 on: June 21, 2018, 02:47:10 pm »
Re: Sanctuary
« Reply #2 on: June 21, 2018, 03:36:31 pm »
What indexing system for cataloguing do you use Martin?  {-) {-) {-) {-) {-) {-) {-) {-) {-)
MartinL
  • Founder member Westham Ocean Racing Yacht Club
Re: Sanctuary
« Reply #3 on: June 21, 2018, 05:01:10 pm »
Probably the same as mine, ie
If it's not in the workshop its in the shed, or the green shed, or the garage.
I know it's not in the spare bedroom cos I was in there this morning. etc.etc.
Re: Sanctuary
« Reply #4 on: June 21, 2018, 05:08:29 pm »
Not my shed but I'm guessing.... 'it's around here somewhere...!'
tonyH
Re: Sanctuary
« Reply #5 on: June 21, 2018, 06:10:56 pm »
Hey, Baldrick,Where did you manage to get your EMCO drill stand?Tony :-))
KitS
Re: Sanctuary
« Reply #6 on: June 21, 2018, 06:30:52 pm »
Now that's a SERIOUS jumble Martin.
Respect!  :-))
Kit
Re: Sanctuary
« Reply #7 on: June 21, 2018, 06:45:54 pm »
Martin's photos remind me of Richard Howard's Model Boat Museum at Beale Park which was stuffed to the rafters with a mixture of purchased and loan boats.
Does anyone know what has happened to the collection following his death, it was very much his personal hobbyhorse.
Re: Sanctuary
« Reply #8 on: June 21, 2018, 07:22:54 pm »
  Hi Tony .   It's actually a Unimat 3 set up as a vertical mill but with a change of milling chuck to drill chuck it makes a versatile drill press . I bought the machines some years ago and have just given  all 3 a good overhaul and clean . Biggest problem is keeping corrosion at bay over the winter as even a waterproof  shed can get a damp atmosphere during a bad winter . I have just bought some Ambersil corrosion inhibitor spray to see if this helps keep rust at bay
Mark T
Re: Sanctuary
« Reply #9 on: June 21, 2018, 07:27:06 pm »
Oh my goodness Martin it looks like an Island after a hurricane has hit the coast  {-)   Thats the only other time I've seen boats stacked up like that  {-)
tonyH
Re: Sanctuary
« Reply #10 on: June 22, 2018, 09:52:53 am »
Thanks Baldrick. Does the switch still work effectively because I've had to cobble together a replacement on my U3 lathe.
Tony
Arrow5
Re: Sanctuary
« Reply #11 on: June 22, 2018, 10:20:28 am »
   as was his garage, as well as radio control planes, boats there was a couple of interesting full-size car s (it was a garage after all ) .  A rare 4 door Maserati if I remember in mafia black and a replica D type Jaguar, cant remeber the other one, too busy looking at the ship models, most with their own R/C transmitters.
..well can you land on this?
Re: Sanctuary
« Reply #12 on: June 22, 2018, 03:19:35 pm »
Tony
Hi Tony.
   Switch is fine , you can of course rotate the motor  against the backplate so that the switch comes in a comfortable position.
 Am I correct in reading that the switch on your U3 is broken  ? If so I have a motor which is duff (Bearings worn out and commutator damaged) but the switch as far as I know is fine . If you would like it to use to repair yours with you are welcome, just squawk .  Balders.
Page created in 0.119 seconds with 21 queries.
