Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... 31   Go Down
Author Topic: Andy’s, nothing like a Stevn's arctic build!  (Read 156537 times)
Taranis
  • Balne Moor MBC
Re: Andy’s, nothing like a Stevn's arctic build!
« Reply #175 on: October 22, 2020, 05:25:20 pm »
Continued
Turning into a bit of a THUG never mind tug
Many of the tools employed. The FLAT square is fairly recent but proving its worth.
ANDY
Taranis
  • Balne Moor MBC
« Reply #176 on: October 22, 2020, 06:55:20 pm »
Today I finally received some ladders from Modelboatbits. Royal Mail delivered today on the 22nd an item that was postmarked 14th first class  %%  Steve was first class and posted more out yesterday. I will post them back at my cost, not his fault.
Anyway my current problem is that they REALLY are ladders so contrary to my intention I cannot use them as stairs. NO way could anyone go down these facing forwards as there is nowhere to place a heel. They are as described ladders and that means going up and down facing them. So unfortunately for me they are redundant (keep them for stock)
So it looks like I will have to make all the companionway stairs on this build from scratch  :((
ANDY
Taranis
  • Balne Moor MBC
« Reply #177 on: October 22, 2020, 09:42:10 pm »
I've managed to find stock of Plastruct stairs. These are like fairy dust but I found them at the same shop in London where I got the Lobster boat.
29mm wide by 300 long 1:32 stairs  8)
Come up trumps twice  :-))  https://hobby.uk.com
ANDY
Stumps
« Reply #178 on: October 23, 2020, 09:09:02 am »
Andy,
That's really starting to look good. It's going to be a beast on the water.
Ant
« Reply #179 on: October 23, 2020, 02:44:45 pm »
Blimey Andy,
Your fairly getting on with it.
Have you done a propulsion test?
It would be interesting to see the drives in action.
Taranis
  • Balne Moor MBC
« Reply #180 on: October 23, 2020, 06:42:31 pm »
Thanks Ant
My attempt to ballast last week failed due to a badly fitted bow thruster leaking.
This is now sealed in a much simpler fashion and removal only requires a scalpel
I've just tested everything dry on the bench and found one steering servo has and internal mechanical fault, it rotates freely clockwise but very high resistance anticlockwise.
I ran both props to full speed and they make one hell of a draft  %%
Anyway tomorrow I'll try again to establish full displacement weight and I can run one motor to find full load current.
I'm temporarily using a Spektrum radio and the bow thruster is on Aux 3 pos switch B
ANDY
Taranis
  • Balne Moor MBC
« Reply #181 on: October 23, 2020, 06:47:51 pm »
Some more styrene photos
ANDY
Taranis
  • Balne Moor MBC
« Reply #182 on: October 23, 2020, 06:50:20 pm »
Size comparison . Wheelhouse still to build
ANDY
Howard
« Reply #183 on: October 23, 2020, 09:26:16 pm »
Andy' you have amazing plastic skills friend.
                       Regards Howard.
Taranis
  • Balne Moor MBC
« Reply #184 on: October 23, 2020, 09:38:27 pm »
Thank you Howard. To be honest it is much easier than the Portgarth was which is all plywood.
The bonus being styrene will paint much easier and creates a bit less dust in the making.
ANDY
Howard
« Reply #185 on: October 23, 2020, 10:22:21 pm »
Andy I never use any thing but plastic as you say but to paint but then some will always say ply's best  only thing I have learnt is I now always scrape my joints where I can  and not sand if I can help it.
                             Regards Howard.
Taranis
  • Balne Moor MBC
« Reply #186 on: October 23, 2020, 11:05:09 pm »
All new ground to me but loving it so far.
Just spent a couple of hours on the smokers
ANDY
Howard
« Reply #187 on: October 24, 2020, 12:56:24 am »
Andy you look like a old hand of it great work now you have tried it I don't think you'll return you ply I buy mine from HINDLEYS of  SHEFFIELD  HIPS 0.5MM UP TO 2.75.
      Regards Howard.
radiojoe
« Reply #188 on: October 24, 2020, 04:19:44 pm »
Some excellent crisp work there Andy, Ply or Plastic I really can't decide I've used both some times a mixture of,  Being a Carpenter by trade I do like working with wood, on the other hand you don't get grain problems with plastic.
Joe.
Taranis
  • Balne Moor MBC
« Reply #189 on: October 24, 2020, 07:26:44 pm »
Thank you Joe and Howard. Really anything that works or a combination of both  O0
Cannot win really. Butts told me that while Portgarth was on show at Doncaster one punter refused to believe she is wood  {-)
I suppose that should be taken as a complement but on the other hand I know wood is more than twice the effort and time? so maybe not.
I've tried styrene cement again and I still find it crap as it takes far too long to set and hold reliably.
ANDY
Taranis
  • Balne Moor MBC
« Reply #190 on: October 24, 2020, 09:55:02 pm »
Tank test postponed today due to rain. Should be ok tomorrow.
I added braces here and prepared for the staircase, should arrive Monday.
The exhausts now have a larger diameter detachable styrene oversleeve
I made the crane support
That's all today
ANDY
Taranis
  • Balne Moor MBC
« Reply #191 on: October 25, 2020, 10:48:00 am »
I had guessed over 30kg and the actual IS 34kg  8)
ANDY
Taranis
  • Balne Moor MBC
« Reply #192 on: October 25, 2020, 11:40:40 am »
The hull as pictured here with drives installed is stern heavy and 11kg. With deck furniture and bow fixed ballast I hope to keep it to 15kg max.
This is what I had to add to get to the waterline. 11.5kg of water and 11.5kg of lead
The bow thruster is almighty powerful! Makes Raboesch seem completely pathetic in comparison.
Unfortunately my clip on DC ammeter failed me but for sure the ESC's are fine.
I will buy an inline tester for next time.
I won't need a sound module  :-)
https://youtu.be/yd7DoNfV6SQ
ANDY
Taranis
  • Balne Moor MBC
« Reply #193 on: October 25, 2020, 05:22:42 pm »
Mixnmatch
ANDY
chipchase
« Reply #194 on: October 26, 2020, 08:45:20 am »
Looking good Andy, just logged on and read your log she is certainly taking shape. Unfortunately my builds have been at a standstill for quite some time know due to caring for my brother. Keep up the good work  :-))
Brian
Taranis
  • Balne Moor MBC
« Reply #195 on: October 26, 2020, 09:09:20 am »
Good morning and thank you Brian. Best wishes for you brother. I see my club mate has acquired your Maltby, I'm very envious  :embarrassed: . I hope we can see you building again before too long.
EDIT
stairs just arrived from hobby UK  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #196 on: October 26, 2020, 01:16:51 pm »
ANDY
marco
« Reply #197 on: October 26, 2020, 02:32:48 pm »
Bonjour ,
    This tugboat is superb , it is a a Robert Allan design like my RMT PENFRET which is 32m long . I built this tugboat at 1:32 . the difference is your choice For 180° with your schottles and I chose the 360° obtion for my tugboat .
     Good luck for the rest of the building .
marco
Taranis
  • Balne Moor MBC
« Reply #198 on: October 26, 2020, 03:59:04 pm »
Merci Marco  :-)
I quite like this idea that allows this to be treated as a sub assembly to add at the end of the build during final assembly with a dab of silicon.
It only remains to finish this with satin lacquer
ANDY
Taranis
  • Balne Moor MBC
« Reply #199 on: October 26, 2020, 06:02:19 pm »
@£7.80 per length I think this represents good value compared to other options.
Please do not introduce 3D printing as an option  %%
Bearing in mind that these are stairs and not to be confused with ladders. 1:32 scale
Unfortunately they only make this scale 29mm wide which happens to be suitable for most of my model but not for access to the wheelhouse.
I have put one through the band saw and stuck it back together at 22mm wide.
Will be fine when painted.
ANDY
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... 31   Go Up
Page created in 0.025 seconds with 17 queries.
