Author Topic: Andy’s, nothing like a Stevn's arctic build!  (Read 116677 times)
Taranis
  • Balne Moor MBC
Re: Andy’s, nothing like a Stevn's arctic build!
« Reply #400 on: December 17, 2020, 11:05:30 pm »
Thanks Rich
I wondered where your picture was but I now see you are referring to the picture Brian posted.
The stick rod or pole on the end is from a micro switch which I surmise ensures that the winch will stop if the RIB is hoisted too far due to lack of operator concentration %%
I think the RIB will perform all the tasks mentioned
ANDY
RST
« Reply #401 on: December 17, 2020, 11:47:29 pm »
Yes.  Often there is a weight on the hook colloquially called a "headache ball" for a couple of reasons.  Terribly un-kooth for a crane op to allow a crane hook to touch the deck (and the wires unload on the sheaves back to the winch) or to hoist it up to the top into the sheave at the end of the boom (and do damage) -so operator training for the former and for the latter -the common "anti-two block" preventing the block on the hook and the block on the crane boom from touching if they're distracted by the newspaper, or facebook these days.  None of that applies to HIAB's or what's horrifically referred to as "cherry pickers" which means at least 3 different things in 3 different applications.
davejo90
« Reply #402 on: December 18, 2020, 08:37:48 am »
Taranis
  • Balne Moor MBC
« Reply #403 on: December 18, 2020, 07:01:01 pm »
The winch is now painted and whilst it dries I thought I would continue down this tributary.
So the main fore winches are quite BIG requiring 65mm drum sides.
The gallery is updated where you can see how I got to here
ANDY
Taranis
  • Balne Moor MBC
« Reply #404 on: December 18, 2020, 10:33:18 pm »
This is the same green I bought for the hull but by mistake satin finish. I think it works very well and the styrene certainly doesn't look like plastic anymore.
I haven't fully loaded the drum but if I had it would hold appx 3.5 times the hull length or lets say at least 100metres on the full size boat.
ANDY
Taranis
  • Balne Moor MBC
« Reply #405 on: December 19, 2020, 04:40:57 pm »
A good burst on the banjo today saw a repeat of the same procedure to create the stern winch drums. That is the last of the large diameter machining and everything else will be within 25mm diameter.
Gallery is updated https://techno.smugmug.com/Stevns-Arctic/i-PkDMtBt
ANDY
Mark T
« Reply #406 on: December 19, 2020, 05:00:30 pm »
Lovely work Andy and the paint finish looks professional  :-))
Taranis
  • Balne Moor MBC
« Reply #407 on: December 19, 2020, 05:16:36 pm »
Thanks Mark, I think the secret is in the can  :-)  This paint supplier uses a fine fan spray nozzle  :-))
This is a sample of why it's good to have mates  8)
Coolest of cool dummy motors extra big for big winches  :}
ANDY
Taranis
  • Balne Moor MBC
« Reply #408 on: December 20, 2020, 05:28:24 pm »
It was like wading through treacle this afternoon until I had a lightbulb moment. The idea struck me to glue washers to styrene then trim around them to create bearing end caps.
Gallery is updated
ANDY
Taranis
  • Balne Moor MBC
« Reply #409 on: December 20, 2020, 11:40:33 pm »
A bit further
ANDY
Dreadnought
« Reply #410 on: December 21, 2020, 09:28:04 am »
Looks great!  :-)) :-))
Stumps
« Reply #411 on: December 21, 2020, 09:50:50 am »
Really looking good and love looking at your build images ~ very inspiring...
Howard
« Reply #412 on: December 21, 2020, 10:25:50 am »
Hello Andy,
 your build is looking so good as Stumps says so inspiring, As for making plastic discs I find my hole punch tubes great.
                 Regards Howard.
Taranis
  • Balne Moor MBC
« Reply #413 on: December 21, 2020, 03:48:41 pm »
Thank you all, all appreciated. No updates today as the parts are all in paint.
One from last night undergoing progress inspection.
ANDY
Taranis
  • Balne Moor MBC
« Reply #414 on: December 22, 2020, 09:15:35 pm »
A lot of alterations along the way but now pretty much complete with the exception of paint (I've run out  :(( ) and the large dummy motor.
More pictures in the gallery https://techno.smugmug.com/Stevns-Arctic/i-VqqDFrb
ANDY
Taranis
  • Balne Moor MBC
« Reply #415 on: December 23, 2020, 09:13:35 pm »
Finally my 1/64 brass strip arrived so I've continued with the roof ladders where I left off. More pictures in the gallery.
ANDY
Taranis
  • Balne Moor MBC
« Reply #416 on: December 24, 2020, 12:00:43 pm »
The only primer I use on brass.
I'll need a warm day to top all the brass off with appliance white
I may start the bow winch later today
ANDY
Taranis
  • Balne Moor MBC
« Reply #417 on: December 24, 2020, 04:13:40 pm »
More pics added to the gallery
ANDY
Mark T
« Reply #418 on: December 24, 2020, 04:30:27 pm »
Its certainly coming to life as more and more detail is added - superb!
Taranis
  • Balne Moor MBC
« Reply #419 on: December 24, 2020, 04:32:13 pm »
Many of the parts are in a drawer. Looks pretty far on if I put everything on. I'm not looking forwards to windows  {-)
ANDY
Howard
« Reply #420 on: December 24, 2020, 05:29:33 pm »
Hello Andy Merry Christmas,
 That winch is amazing more so that it's scratch build by the way I think your green is spot on.
                         Regards Howard.
Taranis
  • Balne Moor MBC
« Reply #421 on: December 24, 2020, 06:39:19 pm »
Same to you Howard thank you.
I just had an epiphany. I've realised that my island bench is simply too tall for this build to be comfortable  %%
So it is (four cuts later) 105mm lower  :}
ANDY
Taranis
  • Balne Moor MBC
« Reply #422 on: December 24, 2020, 09:37:13 pm »
When I started this build I had absolutely no idea how much detail I would employ or how well it would go together from a pile of flat sheet styrene especially as a newbie to this medium.
As I've progressed my nothing like a Stevn's has gotten more and more like exactly what I wanted to avoid  {-)  and closer to reality than expected.
So I now need to modify the timbered deck to accommodate another winch that previously I thought I'd give a miss.
Paxolin surgery is not a problem unless you cut out too much just like with wood.
From my newly modified working height lowered IKEA bench. It never felt a thing honest.
Engine room escape hatch fitted with screws and template of winch footprint.
ANDY
Taranis
  • Balne Moor MBC
« Reply #423 on: December 25, 2020, 12:26:55 pm »
Operation successful
Bux Fizz helps things along
Happy  :-))     More pictures in the gallery
ANDY
Taranis
  • Balne Moor MBC
« Reply #424 on: December 25, 2020, 07:52:22 pm »
Festive shots  :-) . More in the gallery
ANDY
Page created in 0.107 seconds with 21 queries.
