Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 627888 times)
Sealord
Re: Chris' HMS TIGER (C20) - 1:72 SCALE
« Reply #1650 on: August 20, 2022, 10:45:18 pm »
 Everything looking brilliant mate. :-))
« Reply #1651 on: August 20, 2022, 11:00:21 pm »
Glad to see you've managed to sort the gun movements out Chris and look forward to seeing (and hearing) the guns in action. Hope you get the delivery soon  :-))
Aye,
frogman3
« Reply #1652 on: August 21, 2022, 05:38:57 am »
Thanks Sealord  yes she is now comin on great very pleased with myself an the model
CHEERS
CHRISB :-))
frogman3
« Reply #1653 on: August 21, 2022, 06:07:52 am »
Aye,
HI Ray  so am i glad as  it was testin the ole brain with all them gears but the way it  now works with the gears is the complete oppisste to the big gun turret as thats what threw  me by tryin to use same gears again  except i could not fit a big 1/16 tank turret gear as it was to big  so had to use normall size gears an a sail winch servo  but no joy >>:-( <*< [size=78%] . So i treid out a normal servo an different gears  sizes until i treid the three gears in the present arrement an volay yes it all worked nr enough crazy isnt it[/size] :-)) [size=78%] as it was so different to just get the guns to turn the same way but a bit of thought an yes got it right in the end. An yes when the gun fire unit comes then i hopefully can get them guns to all work togeather an guns flash with the leds but on the 3 inch gun one 1mm led has failed[/size] :embarrassed: [size=78%] so i will just have one gun barrel lighting up but better than none eh well Ray many thanks for your intrest in the tiger build[/size]
more APPS comin soon
ATB to you Sir
chrisb  :-))
Tworrs
« Reply #1654 on: August 21, 2022, 06:26:05 am »
Great result Chris, well done mate.
Garry
frogman3
« Reply #1655 on: August 21, 2022, 07:08:12 am »
Garry
HI Garry cheers for your comments an hows I/D comin on ?  as it looked great in the pics you shew me
ATB  to you Garry an have fun building
CHRISB  :-))
frogman3
« Reply #1656 on: August 31, 2022, 07:38:25 am »
HI Chaps
Time for an update well ive been workin on fitting P/E stantions an brass rods for safety railins as i cant do any more on my guns till the gun fire unit comes so a shot of nr 200 stantions that im goin to fit on her but ive had to fit them firstly on the gun directors mounts before i fitted the same to the mounts an it was a good test of the ole peppers  to to thread the rod through the stanion holes as they are so tiny
chrisb
 https://ibb.co/S7qdycj
frogman3
« Reply #1657 on: August 31, 2022, 07:41:17 am »
AN A SHOT of how small they are against my finger tip an half way a round the mounting they are fitted
https://ibb.co/MR1F61J
frogman3
« Reply #1658 on: August 31, 2022, 07:45:17 am »
an nr done just one more lot of bends of the brass wire an then cut off to size
https://ibb.co/0hfc6Y2
frogman3
« Reply #1659 on: August 31, 2022, 07:48:33 am »
An here a close up shot of the gun directors fitted on the upper S/S
https://ibb.co/thTty39
frogman3
« Reply #1660 on: August 31, 2022, 08:13:22 am »
overall shot of where they fit on the main S/S AN ITS NOW GETTIN BLOOMIN HEAVY AN IVE BUILT AS LIGHT AS POSSIBLE   >>:-( :embarrassed: %)
https://ibb.co/qkpwjkJ
frogman3
« Reply #1661 on: August 31, 2022, 08:35:32 am »
AN Movin on i started to build the ships crane an here a pic of the real thing but its a bit fuzzy so will have to geuss on the shape
https://ibb.co/yQ168rY
frogman3
« Reply #1662 on: August 31, 2022, 08:39:19 am »
An heres my attempt of it not acrrurate but will do me an here the jib fully exstened with leds on it an they will be wired up at a later date  an here im still tryin to build the crane mounting
https://ibb.co/TKwVFyw
frogman3
« Reply #1663 on: August 31, 2022, 08:42:48 am »
an ive made it so the jib foulds up so it dont get broken :-)) .
 https://ibb.co/bPxPxkS
frogman3
« Reply #1664 on: August 31, 2022, 08:46:00 am »
an here a shot of how it will be afixed to the deck with a nut an bolt so it can be moved by hand an can be removed
https://ibb.co/BPjjjjT
chrisb :-))
ScottW
« Reply #1665 on: August 31, 2022, 11:45:44 am »
Crane turned out nicely for being a guess from a fuzzy photo.  Having it fold like that is a neat idea.
"If it is something that you can make use of, that's a bonus, but the real value is in the creation." Steve Bennett; Sidelines
frogman3
« Reply #1666 on: August 31, 2022, 12:01:47 pm »
HI Scott many thanks yes impleased with how thing are goin an yes the crane jib has to fold up so i can get the front part of the ship in the boot of my car  %) :-)) as its gonna be a tight fit just got to hope me an the missus can lift it when all togeather ready for a sail  :-))
cheers for lookin in
hope you are well
chrisb
Rob47
« Reply #1667 on: August 31, 2022, 05:05:50 pm »
HI Chaps
chrisb
Chris any particular reason you are using 1/96 stanchions?
I will finish this model
frogman3
« Reply #1668 on: August 31, 2022, 05:18:36 pm »
HI Bob yes i was given about a 1000 of these by a freind an  cant afford much now as jen cant work so im payin for every thing so im usein them an really there is not a lot of difference in height to the 1/72 ones so needs must
hows that Bob an hope you are well
ATB chrisb
Akira
« Reply #1669 on: August 31, 2022, 10:51:55 pm »
Beautiful work on the crane. Your stanchions look great as well, even if I forgot my ruler :embarrassed:
frogman3
« Reply #1670 on: September 01, 2022, 08:54:25 am »
HI Akira many thanks for your nice comments on my work an yes the stanchions may be a bit short but with a 1000 of them i cant afford to not use them as there really is not a lot of height difference to 1/72 scale
CHEERS ATB
chrisb
Sealord
« Reply #1671 on: September 01, 2022, 07:25:08 pm »
  Hi Mate,
      Everything looking brilliant, i'll get over as soon as i can. :-))
frogman3
« Reply #1672 on: September 01, 2022, 10:01:20 pm »
  Hi Mate,
ok cheers m8
frogman3
« Reply #1673 on: September 04, 2022, 06:29:14 am »
HI ALL well today
a small SPECIAL  update on that ships crane an what makes it special is that its the first thing on this ship that i can say its finished :-)) %) :o O0 as ive got stuck into it to get it to the fin state an im fairly pleased its not 100% accruate but will do for me an here are some pics of the fin item
https://ibb.co/n1rqyGy
frogman3
« Reply #1674 on: September 04, 2022, 06:31:50 am »
different angle shots
https://ibb.co/dLHpPwH
Page created in 0.057 seconds with 21 queries.
