Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 849270 times)
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #750 on: January 18, 2021, 08:10:47 pm »
frogman3
« Reply #751 on: January 18, 2021, 08:12:19 pm »
an that that today an im very pleased on how this model is comin on
chris
https://ibb.co/449P6BJ
« Reply #752 on: January 18, 2021, 08:12:54 pm »
That's an excellent out pouring !!
frogman3
« Reply #753 on: January 18, 2021, 08:21:26 pm »
HI YEA im very pleased at this result as that funnel tube is over 14 inches long an i dint think that small 25 mm fan would push the steam out ok
cheers for lookin in on the build
chris
T888
« Reply #754 on: January 18, 2021, 08:38:08 pm »
Looks good Chris :-))
Regards David
frogman3
« Reply #755 on: January 18, 2021, 09:15:18 pm »
CHEERS Dave
chris
frogman3
« Reply #756 on: January 19, 2021, 07:19:53 am »
AN THANK YOU Martin for bringing up my pics from the links  very nice of you
cheers
ATB   Chris :-))
frogman3
« Reply #757 on: February 01, 2021, 08:46:07 pm »
HI ALL just a small update today as ive been working on the hanger bay to get it all working first up the eletronics is now fitted so the servo morph works the hanger doors nice an slowly an here they are half way goin up
https://ibb.co/N2DR4rj#
frogman3
« Reply #758 on: February 01, 2021, 08:52:44 pm »
next the lights come on by a knock on switch fitted to a servo arm an when the servo goes back to the closed postion then the lights go out an on the hanger section her there are a lot more lights to fit to shine up the flight deck
https://ibb.co/L9bpPq6
frogman3
« Reply #759 on: February 01, 2021, 08:57:14 pm »
strenghing bars fitted an W/T door which opens an closes
https://ibb.co/ctqBFRR
frogman3
« Reply #760 on: February 01, 2021, 08:59:59 pm »
AN on the hanger bay bottom ive fitted all the eletronics to work what ive got so far but if they cause to much top wheight then they can just be unscrewed an moved down into the hull
https://ibb.co/2qztsPw
Chris Preston
« Reply #761 on: February 02, 2021, 06:26:21 am »
T888
« Reply #762 on: February 04, 2021, 03:51:42 pm »
Coming along well Chris  :-))  will you be detailing the inside of the hangers ?
Regards David
frogman3
« Reply #763 on: February 04, 2021, 06:26:29 pm »
HI Dave thanks but i will put in a little detail in the hanger but i dont think its worth putting to much in as most of it wont be seen so in my opinion an i know you put in a lot of detail in your hanger on your burke an a very nice job you made of it to :-))   but not for me
chris
frogman3
« Reply #764 on: February 13, 2021, 09:21:25 am »
HI ALL well ive started that dreaded PHOTO ETCH 965 radar an the instructions are not brilliant an it gave me some bits that were not shown on the instructions so its guess time an here its is an its quite big nearly 4 an half inches accross
https://ibb.co/LRsCFTm
frogman3
« Reply #765 on: February 13, 2021, 09:24:46 am »
next i just fitted two collets with their allen screws on a steel rod to just see where they need to be fixed to hold the radar ok on the mast
https://ibb.co/P56cM36
frogman3
« Reply #766 on: February 13, 2021, 09:30:20 am »
AN then before i started building said unit i fitted down selotape to the surface so as its shiny the P/E wont stick to the board an i also taped down the etch so it cant move an i fitted on the panel edges some 1mm sqaure plastic strips to glue to
https://ibb.co/3pr1Sy1
frogman3
« Reply #767 on: February 13, 2021, 09:35:46 am »
frogman3
« Reply #768 on: February 13, 2021, 09:38:00 am »
an sprayed grey as it would be difficult to spray in side when built
https://ibb.co/VWFSv3w
frogman3
« Reply #769 on: February 13, 2021, 09:39:41 am »
here I've now started to fit the first panel onto the faceplate
https://ibb.co/r0FRk6r
frogman3
« Reply #770 on: February 13, 2021, 09:45:54 am »
An now I've fitted no2 panel to hold the collects tight an square
https://ibb.co/3788NHc
« Reply #771 on: February 13, 2021, 09:47:16 am »
an sprayed grey as it wouldbe difficult to spray in side when built
That's good forward thinking for the painting job Chris and the pictures help explain what you're doing - great work so far.  :-))
frogman3
« Reply #772 on: February 13, 2021, 09:57:36 am »
CHEERS Ray an thanks for havin a lookin an hope you are well stay safe
chris
T888
« Reply #773 on: February 13, 2021, 10:04:33 am »
Looks good Chris, I know what you mean ref the instructions, but John at scale warship is aware there may need some clarification update to these.
Regards David
frogman3
« Reply #774 on: February 13, 2021, 10:23:24 am »
HI DAVE yes they certainly do if he had fitted the fininshed pics clearly it would have been a great help but now for me its to late as ive built it to what i see on them insturctions if ive got it wrong well that a lesson learnt but at least it strong an wont brake easy so im pleased
chris
Page created in 0.017 seconds with 20 queries.
