Pages: [1] 2 3 4   Go Down
Author Topic: Artesania Latina Cutty Sark  (Read 22330 times)
kpnuts
« on: September 30, 2019, 08:06:52 pm »
Hi all i bought this off my brother (he decided it was too frustrating for him) there are a few problems to sort out on it (I need to strip the decking off and square the frame up , it's a bit warped) he took the planking off which has saved me a job (he bought some really thin wood for the planking as he struggled with the supplied wood but it's so thin I can see it disappearing when sanded do I'm going to use the supplied wood) here are some pics, I've managed to get the deck off fairly easily getting the wood off the deck and squaring the frame may be quite a bit harder.This will be a very slow build.
I think the pins hes used in the transom are way out of scale.
Re: Artesania Latina Cutty Sark
« Reply #1 on: September 30, 2019, 08:30:45 pm »
Well, you've got a tough job on your hands there KP, but having viewed some of your previous builds I'm sure you will get it sorted.
Enjoy  :-) .
« Reply #2 on: September 30, 2019, 10:05:25 pm »
Wishing you luck with the build Ken. Getting all the nails out will instantly make life lots easier and tidier.
kpnuts
« Reply #3 on: October 05, 2019, 05:16:05 pm »
Hi all well I've removed the deck planking squared up the frame and are attached the front decking. I thought I would get away with doing nothing to the rear deck but on closer inspection I think he put the last 2 bulkhead the wrong way round since the second to last is narrower than the last (the phrase one step forward 2 back comes to mind) anyway I managed to get the rear deck off now I'm not sure what to do the frames seem to be impossible to unglue, any suggestions (I've tried steaming over a kettle but they won't budge) would it hurt the plywood if I soaked the stern in a bucket over night.
« Reply #4 on: October 05, 2019, 05:29:49 pm »
It should be possible to add thickness to the narrower frame and, if necessary reduce the thickness of the last one.... Maybe?
That would then negate the need for soaking.
Best I can think of at the moment.
Actually, if the frames are different in shape it would be wise to create templates first.
Mark T
« Reply #5 on: October 05, 2019, 05:39:48 pm »
This is what I would do - Shape the first frame and then build the other one up with some flexible wood.  Thats one big challenge you've taken on there Ken - good luck mate I'm sure you will sort it
kpnuts
« Reply #6 on: October 07, 2019, 08:03:12 pm »
Hi all corrected the bulkheads next problem, now the side panels are correctly installed you can see the stern is too shallow so I will probably build this up with wood filler.
kpnuts
« Reply #7 on: October 12, 2019, 06:00:20 pm »
Well 1 step backwards leads to another step backwards, deck had to come off again. I was about to start planking it again and I thought surely that hump shouldn't be there.
Also I dont know if you can see it from the photo but there is a gap between the bulkhead and the deck (I thought the small oblong hole in the decking was a hatch or something at first but now I see it is a locating peg for the decking) another wrongly glued bulkhead.
I managed to get the bulkhead off (it wasn't fully home due to wood dust and glue formed at the bottom of the joint) (all nicely held in place with dried glue) took ages to cut it all away, anyway as you can see it's all nicely flush and fitted now.
Hopefully I can now proceed as if it were a new kit (apart from the splits in all the bulkheads due to where it was planked before cant think of anything to do about that, if I glue them back together I think it will make it too hard to put new pins in) I'm hoping when its replanked I can drill holes for the pins (they will only be for show anyway)
kpnuts
« Reply #8 on: October 13, 2019, 08:32:44 pm »
Ok so I've decided to start decking it, the instructions are not at all clear it shows you decking over the false deck by 2 mm for the first 120 mm and no longer mentions that afterwards (I can understand that as the planking for the sides is 2mm thick) but why stop that overlap at 120 mm, I looked at pics of the waterways on the actual ship and it looks like there is a wooden strip all the way along the ship from the front to the stern step so I decided to continue the strip all the way along, first problem was keeping a 4 mm wide strip at 2 mm on the deck and 2mm in the air so I decided to add the first plank on the sides and put the waterways over that, I figure the more accurate I can get the first plank the rest must be better so I took great efforts with the first plank.
« Reply #9 on: October 13, 2019, 09:00:20 pm »
Once you have sorted that out I guess you will then lay the king-plank and work outwards to the sides or will you be planking the hull next?
kpnuts
« Reply #10 on: October 15, 2019, 08:46:02 pm »
When the new planking gets here I will start in the middle and work out.
whilst waiting for my planking to come I decided to start on some of the many other things in this kit, here is a start on one of the cabins.
It's like a kit in its self, I have a feeling I'm going to love this kit, for the calking between the planks I used a lead pencil and just ran it along the edges of the planks.
kpnuts
« Reply #11 on: October 19, 2019, 06:50:17 pm »
Hi all I have done some of the planking I've cut the planks at 70mm which I think in this equates to 10 yards at this scale (although the planking supplied is I think is over scale at about 12"wide ) I'm not going to add the nail heads as I've seen on the printed decks available in this scale as I dont believe a nail with a head diameter of 6 mm would be visible at this scale at.
The planking is very slow going but quite satisfying.
kpnuts
« Reply #12 on: October 20, 2019, 08:37:53 pm »
Hi all well this is as far as the decking can go at the moment as I've used all the wood left in the kit for this (they were very generous with wood as it was already fully planked so they nearly give you double what you need) I just hope when the new stuff comes it's similar coloured unlike the last bit (for the waterways which were completely different colours) I realise wood is a natural product so can differ I just hope it's not too much different.
« Reply #13 on: October 20, 2019, 09:31:02 pm »
Progressing well now KP - hope the new wood works out ok :-)
kpnuts
« Reply #14 on: October 25, 2019, 08:43:20 pm »
Hi all well the planks arrived and I was happy the colour was the same but they must have used the other 3mm because these are narrower also they are not 1mm thick either ( not that that matters much once sanded down) I managed to get a knife under a few of the stuck planks and shave some off the inner sides and squashed them together I'm hoping it will be enough so the thinness of the new planks won't notice.
While I was waiting for these planks I planked some of the sides (I must say I'm quite pleased with the results.
I bought a sprung pin pusher for inserting the pins, I intend to drill the holes for the pins first as the ply on the bulkheads is all split and separated from all the pins used to plank it the first time (I would have glued and clamped them but figured it would make them harder and therefore make putting the pins in harder) I think it's all starting to come together.
« Reply #15 on: October 25, 2019, 09:14:33 pm »
You're making good progress now Ken, glad you were able to use the new planks ok, it would have been another setback if you had to return them and await more replacements - good on yer.  :-))
kpnuts
« Reply #16 on: October 27, 2019, 08:08:33 pm »
Planking of the main deck complete, I've given it a coat of clear varnish to bring out the wood grain.
« Reply #17 on: October 27, 2019, 09:57:53 pm »
Interesting to see how 'modern' her hull lines look , in her 'naked' state!
kpnuts
« Reply #18 on: October 30, 2019, 08:09:51 pm »
Hi all got some more of the side planking done and done a bit more to the cabin.
« Reply #19 on: October 30, 2019, 09:27:55 pm »
Looks like this is going to be a successful salvage job  O0 .
kpnuts
« Reply #20 on: November 02, 2019, 07:17:44 pm »
Hi all got more planking done, I'm quite pleased with how the stern is turning out.
« Reply #21 on: November 02, 2019, 07:24:00 pm »
Nice work Ken, coming together nicely.
Good job you stained the aircraft bits, otherwise some might have ended up on the boat  ;D
Mark T
« Reply #22 on: November 02, 2019, 07:53:48 pm »
Thats looking good Ken and its always harder to salvage someone else's mistakes so well done.  One of the great things about the Cutty Sark is the hull is plated from halfway down the hull.  So the only planking on show is above that so you can use any wood you like.  Keep the pictures coming  :-))
kpnuts
« Reply #23 on: November 12, 2019, 09:11:02 pm »
More work on the planking, getting there (mind you so is christmas)
kpnuts
« Reply #24 on: November 16, 2019, 05:33:37 pm »
Hi all I know I shouldn't yet but I wanted to see how she would look when sanded down so had a quick go.
I know still Leeds a bit of filling in places but I'm really chuffed how it looks at the moment.
Pages: [1] 2 3 4   Go Up
Page created in 0.148 seconds with 17 queries.
