Pages: 1 2 3 [4]   Go Down
Author Topic: Pelagic Trawler Build RESEARCH LK 62  (Read 28089 times)
Re: Pelagic Trawler Build RESEARCH LK 62
« Reply #75 on: July 02, 2020, 10:18:35 pm »
She's looking solid Brian - I wouldn't expect anything else, going by your previous builds.
Coming along nicely.  :-)
towrope
« Reply #76 on: July 02, 2020, 10:20:46 pm »
Really starting to come on now Brian some great detail you can start to see it take shape keep up the good work
chipchase
« Reply #77 on: July 04, 2020, 07:00:33 pm »
Thanks for the positive comments lads, I have managed to get a bit more detail added to the stern over the last couple of days  :-))
Howard
« Reply #78 on: July 04, 2020, 07:32:23 pm »
Am watching and enjoying as always Brian.
         Regards Howard.
« Reply #79 on: July 04, 2020, 10:37:47 pm »
Those vertically oriented protective bars must have tried your patience but they look great  :-))
... and so close together as well!
chipchase
« Reply #80 on: July 05, 2020, 07:48:25 pm »
They were a bit of a headache Ray but worth it in the long run  :-))
chipchase
« Reply #81 on: July 05, 2020, 07:50:31 pm »
         Regards Howard.
Pleased your enjoying the build Howard  :-))
RuneG
« Reply #82 on: July 06, 2020, 02:24:02 am »
Nice build :-)
Is it possible to move the sterngate/roller up and down?
chipchase
« Reply #83 on: July 07, 2020, 08:40:42 pm »
Nice build :-)
Thanks RuneG, the stern gate is fixed as I did not see any advantage for the gate to drop. I will be putting a lot of detail onto the main net drum deck this will be seen from above.
chipchase
« Reply #84 on: July 07, 2020, 08:49:02 pm »
A bit more progress, I decided to put on her first coat of primer to see how much more rubbing down was needed, quite pleased with the outcome the hours i have spent rubbing down has paid off  :-))
« Reply #85 on: July 07, 2020, 08:54:09 pm »
That coat of primer shows her lines off beautifully - shows your quality workmanship nicely as well  O0
chipchase
« Reply #86 on: July 07, 2020, 08:55:01 pm »
Thanks Ray
towrope
« Reply #87 on: July 07, 2020, 09:08:13 pm »
Looks a bit of a beast have you worked out what the total weight is going to be when complete Brian, looking forward to seeing the superstructure and the detail going on nice work
« Reply #88 on: July 07, 2020, 10:44:39 pm »
I wondered the same in a glancing thought a few weeks back, then after today's question......looked again  :o at the hull on the garden furniture & thought maybe 35 to 40kg?
Then remembered I had read the hull size & scale some time earlier
The vessel was listed as 16.2 metric tonnes and the scale was 1:60
Hope the batteries in my solar powered ABACUS are charged up
....so....16200 divided by the cube root of scale  = 75kg .!!!!!!!!  O0
chipchase
« Reply #89 on: July 08, 2020, 09:07:22 am »
Ballast question, when I first made the hull i checked her out in the bath (she just fit LOL) 25kg took her near enough to her water line. I decided at that stage she would need some permanent ballast, I fitted 12kg of lead under the net drum deck and two 12AH batteries 4kg each placed forward from midships and a 2kg block of lead was placed in the bow section, she was put back in the bath at this and she looked OK, I still have plenty of manoeuvrability for all the deck fittings she has. :-))
« Reply #90 on: July 08, 2020, 10:13:25 am »
Sorry Chip  %% .......just cannot rely on these Chinese batteries in my Solar Powered ABACUS  >>:-(   [or maybe an early morning typo on my part?]
Appears your trial ballasting of 25kg was pretty close  :-))  ...
DavieTait
« Reply #91 on: July 08, 2020, 10:33:11 am »
The real trawler is 3862gt ( 80m overall length x 16m beam x 7.7m draft ) Derek and closer to 5200gt when full of fish.... your looking at a fishing trawler with a displacement close to that of the Type 23 Frigates but 53m shorter !!
Biggest trawler in the world though is the old Atlantic Dawn built for Ireland and now Dutch owned called the Annelies Ilena and she's 144.7m  x 24.3m x 11.4m and 14,055gt empty and can carry 7,500t of fish....
Davie Tait,
Scotland
Howard
« Reply #92 on: July 08, 2020, 11:09:23 am »
Morning Gents,
 I have said it before and I'll say it again  when will Martin put you in the Master build section where you truly deserve to be Brian
  If anyone keeps me going and wanting to improve my modelling skills it's you Brian.
                  Regards Howard. :-))
chipchase
« Reply #93 on: July 08, 2020, 09:42:47 pm »
RST
« Reply #94 on: July 08, 2020, 11:08:07 pm »
I'm not sure what gross tonnage has to play with it as that is not really associated with displacement, nor solar power or abacuses but as I'm interested in this in the background I also worked out from curiosity beforehand it was somewhere about 30kg from what I could glean on-line from the model dimensions or the real thing but I might have been a bit high on guestimate block co-efficient.  Never the less, a very impressive model it will make.  I continue to watch in the background thanks!  It reminds me standing watching the big boats moored at Peterhead (Denholm), while I was a few minutes quayside mobbing my adjacent DSV on the north Breakwater.
chipchase
« Reply #95 on: March 27, 2021, 05:39:16 pm »
Small update on Research, got some of the paintwork done and redone the hawsers, the top section is white but this will be done at a later stage.
« Reply #96 on: March 27, 2021, 05:51:25 pm »
Hi Brian, that paint job looks brilliant - certainly bringing the hull to life - great work  :-))
hama
« Reply #97 on: March 27, 2021, 06:21:32 pm »
Really nice  :-))
Its a lovely hull!
Hama
chipchase
« Reply #98 on: March 27, 2021, 07:16:05 pm »
Cheers Ray and Hama, comments appreciated. she's starting to take shape.
Probably another year or so and I should be well through  {-)
Pages: 1 2 3 [4]   Go Up
