Pages: 1 2 [3] 4 5   Go Down
Author Topic: Multipurpose workboat "Viking Energy" 1/50  (Read 23056 times)
pufferfish
  • puff up the fish :-)
Re: Multipurpose workboat "Viking Energy" 1/50
« Reply #50 on: June 04, 2020, 05:59:24 pm »
To take the cable apart from the clutch and then stops I've designed three separate chambers for them.
A critical thing for me was the axialslot for the stops. 2mm wide and 7mm deep and only a  self made lathe tool.
But it works well and i'm really happy with the result
Ralf
pufferfish
« Reply #51 on: June 05, 2020, 06:29:16 pm »
Setup the 3-jaw-chuck on the roundtable to drill the holes for the stops and the cables.
After that, the first crane segment gets his outer shape
Ralf
pufferfish
« Reply #52 on: June 07, 2020, 05:10:54 pm »
After all that technical things, a crash with the mill and another issue with the cables and the principle construction of the cranes I take a brake and put some red paint on the ship.
Ralf
pufferfish
« Reply #53 on: June 09, 2020, 05:40:53 pm »
The fiddly gangway around the cockpit. Part 1
Ralf
pufferfish
« Reply #54 on: June 10, 2020, 06:45:43 pm »
Bumper, bumper bumper  %%
Double Rubber, Rubber and Wood.
wood is saturated with diluted varnish
Bars are from 3x3mm wood
Shelfs are printed
Ralf
pufferfish
« Reply #55 on: June 18, 2020, 08:51:19 am »
Nice little testdrive during vacation. Very manoeverable that little tug. I'm happy with his look and feel. So, this testdrive was an great motivation to put more time in it and his details.
Ralf
« Reply #56 on: June 18, 2020, 09:32:06 am »
Looks Great!   :-))
Tug Fanatic
« Reply #57 on: June 18, 2020, 10:20:22 am »
That looks like a really nice basis for all the detail work that it deserves.
Watching.
« Reply #58 on: June 18, 2020, 08:06:35 pm »
Excellent progress Ralf! The engineering looks first rate, and I think everyone with a mill has 'Redesigned' a bit and the work once.
pufferfish
« Reply #59 on: June 23, 2020, 09:15:14 pm »
Thank you all.  :-))
Material for the cranes second attempt is ordered.......
Meanwhile  more nonfunctional details are done.
Railings, Ventilations, Exhausts etc. and the great searchlight is online. (Movable but not rc)
Ralf
pufferfish
« Reply #60 on: June 25, 2020, 04:29:08 pm »
Second attempt to build the crane has started. First part is the rotating part of the leadthrough.https://www.instagram.com/p/CB3N7_2KdF0/?igshid=wslt5piiz3r0
Ralf
pufferfish
« Reply #61 on: June 26, 2020, 05:54:50 pm »
Sorry for the lack of pics in the last post.  Here they come:
Brass rings with soldered cables
Isolators and centrical helpers from printed resins.
In the middle a ring with four adjustment screws for the little n20 gear motor
The stator:
Base plate with the ring of holes for the cables
Brass pins to the sliprings.
arranged in a circle
ready for the o-ring to push the brassoins onto the sliprings
all together and in action you can see here https://www.instagram.com/p/CB57AgQKibC/?utm_source=ig_web_copy_link
Ralf
pufferfish
« Reply #62 on: July 12, 2020, 09:13:09 pm »
hi,
it's been a while since my last post. A surgery on my Achilles tendon prevents me from continuing the build. Actually I'm still unable to make complex technical things on the mill or lathe but I don't waste my complete time. I've build many details like the mast with his fiddly lights and antennas, the complete rooftop-arrangement, handrails, lifebuoys and the rearward bulwarks. Not scale but useful is the little threaded bolt, hidden in the great bollard. It will be hold a little camera.
btw: Shortly before the surgery, the cranes base was completed and takes his place on deck
GMTY
Sprache erkennenAfrikaansAlbanischAmharischArabischArmenischAserbaidschanischBaskischBengalischBirmanischBosnischBulgarischCebuanoChichewaChinesisch tradChinesisch verDänischDeutschEnglischEsperantoEstnischFilipinoFinnischFranzösischFriesischGalizischGeorgischGriechischGujaratiHaitianischHausaHawaiischHebräischHindiHmongIgboIndonesischIrischIsländischItalienischJapanischJavanesischJiddischKannadaKasachischKatalanischKhmerKirgisischKoreanischKorsischKroatischKurdischLaoLateinishLettischLitauischLuxemburgischMalagasyMalayalamMalaysischMaltesischMaoriMarathiMazedonischMongolischNepalesischNiederländischNorwegischPaschtuPersischPolnischPortugiesischPunjabiRumänischRussischSamoanischSchottisch-GälischSchwedischSerbischSesothoShonaSindhiSinghalesischSlowakischSlowenischSomaliSpanischSuaheliSundanesischTadschikischTamilTeluguThailändischTschechischTürkischUkrainischUngarischUrduUzbekischVietnamesischWalisischWeißrussischXhosaYorubaZulu
Die Sound-Funktion ist auf 200 Zeichen begrenzt
Ralf
pufferfish
« Reply #63 on: July 15, 2020, 08:53:31 pm »
Are you going to model the sacrificial bars as well?
Here they are  :-)
Lights are done too. Positionlights
And the working lights
Ralf
« Reply #64 on: July 16, 2020, 09:19:20 am »
pufferfish
« Reply #65 on: July 22, 2020, 05:23:28 pm »
Details, details, details.
mooring winch and rear towing pins
massive winch guards, the base of the rear crane, and a water hose for cleaning the winches
interior is in and the deckshouse is now finished and glued
the chef has found his place too.
Ralf
pufferfish
« Reply #66 on: July 26, 2020, 03:32:13 pm »
Retractable Towing Pins: Pins (diameter is 6mm)  are done. Including the fiddly little hook with autorelease.
Next step will be the under deck mechanic.
Ralf
pufferfish
« Reply #67 on: July 29, 2020, 04:20:14 pm »
First buoy is laid  :-)) I'm really happy how smooth the pins are working.
A short clip from this action you can see on +++instagram+++
GMTY
Ralf
pufferfish
« Reply #68 on: July 31, 2020, 04:58:33 pm »
Still unable to walk to a lake  :(( , i made it at home. What? A quick bollard pull test :-))
https://youtu.be/4iowZC_Dkdo
Ralf
« Reply #69 on: July 31, 2020, 05:01:27 pm »
https://youtu.be/4iowZC_Dkdo​
Error  #404 !
pufferfish
« Reply #70 on: July 31, 2020, 05:11:28 pm »
Thanks.  :-))
Now the link works.
Ralf
pufferfish
« Reply #71 on: August 05, 2020, 11:38:25 am »
The rear crane is ready for painting.
actually manual movable but it will be glued in this position
Ralf
pufferfish
« Reply #72 on: August 07, 2020, 04:16:26 pm »
The crane is painted and gets some hydraulic pipes too
Ralf
pufferfish
« Reply #73 on: August 09, 2020, 07:17:22 pm »
Main winch is done  :-))
Radio controlled, of course  :embarrassed:
In action:   [size=78%]https://www.instagram.com/p/CDrNjXoKl6q/?igshid=o78hu6axqrnl[/size]
Now i can close the hull
If i dare  %%
Ralf
pufferfish
« Reply #74 on: August 12, 2020, 05:19:41 pm »
Making a bit more scale mooring buoy in used look, with bad welds, rust and bird poop
a little clip of a nightly pick up test, only with lights of the boat.   https://www.instagram.com/p/CDtx_F-Kh76/?utm_source=ig_web_copy_link
The last functional item on deck were the two pulleys
brass bearing , aluminium pulleys
parting the bearing
fits well  :-))
glued m3 on/in deck
plus lower part brass bearing
plus pulley
plus upper part bearing
Ralf
Pages: 1 2 [3] 4 5   Go Up
Page created in 0.019 seconds with 18 queries.
