Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17   Go Down
Author Topic: Andy's Amati Riva Aquarama build  (Read 59100 times)
Nordlys
Re: Andy's Amati Riva Aquarama build
« Reply #300 on: August 14, 2020, 10:56:50 am »
Hi Andy,  could you tell me what type of Esc's you have used to go with the Overlander motors.
Nordlys
Taranis
  • Balne Moor MBC
ANDY
Nordlys
« Reply #302 on: August 14, 2020, 02:12:51 pm »
Thanks for the edit Andy, I'm used to reading the amps size on Esc's, can't see it on this item?
20amp springs to mind with the Overlander motor?
Nordlys.
Taranis
  • Balne Moor MBC
« Reply #303 on: August 14, 2020, 03:34:31 pm »
The 16BL30 is 30 amp rated  O0
ANDY
RST
« Reply #304 on: August 14, 2020, 09:15:05 pm »
Nice work on the varnish!  Did I miss something though, or are you going to cut the holes for P or A brackets on the propshafts very carefully later?
Notice you also have the rubber O-ring on the Raboesh rudders outside the hull?  I always thought that for inside the hull.  I put a small brass or nylon washer, if anything outside using these rudders.  Will the O-ring wear away over time as you have it now as it's a hard rudder blade edge against it?  Or was it just there as a spacer for pics so far?
Taranis
  • Balne Moor MBC
« Reply #305 on: August 14, 2020, 09:30:04 pm »
No P brackets, no point given such a short protrusion and 8mm tubes are stiff enough already.
The rudder blade is against the rudder tube not the O ring and the pressure is governed by the tiller arm so that is user adjustable.
The O ring is on the outside because the locknut is not behind it but another level higher up in the hull.
In the pictures the locknut is not fitted but when it is the O ring will sink into the tapered/countersunk hole.
I will make a point of better illustrating this in pictures when I fit them
ANDY
Taranis
  • Balne Moor MBC
« Reply #306 on: August 14, 2020, 10:08:08 pm »
Hopefully this will explain better Rich.
The locknut and washer are going where arrowed in blue. Here the ply is at 90 degrees to the threaded rudder tube and also why I needed size large rudder so the tube had a long enough thread.
That arrowed red is at an angle to the tube and not suitable or accessible for a nut to tighten evenly.
The countersink on the outside of the hull takes account of the hull skin not being at 90 to the tube and accommodates the O ring when the nut is tightened.
ANDY
RST
« Reply #307 on: August 15, 2020, 03:03:13 am »
eeeeeek, after all that and no prop shaft support, functional or visual????????!!!!!!!!!!  Rationale behind that as you are normally so diligent on details and good practice with mechanics?
Taranis
  • Balne Moor MBC
« Reply #308 on: August 15, 2020, 12:22:56 pm »
This morning I've matted back ready for 3rd coat.
I'm now finishing each round with wire wool too
ANDY
Taranis
  • Balne Moor MBC
« Reply #309 on: August 15, 2020, 04:22:30 pm »
3rd coat
ANDY
Taranis
  • Balne Moor MBC
« Reply #310 on: August 16, 2020, 05:37:11 pm »
Today as it's raining I thought I'd give varnishing a break
So instead I decided to make my couplings from 10mm alumimium bar.
Second shaft fitting in progress. Props are temporary and I know they are wrong way around.
ANDY
Taranis
  • Balne Moor MBC
« Reply #311 on: August 16, 2020, 06:30:15 pm »
Due to my couplings being a custom length I don't need these.
I'm happy with that.
Video
ANDY
Taranis
  • Balne Moor MBC
« Reply #312 on: August 16, 2020, 09:45:43 pm »
For a reason unknown the video above is blank in google chrome browser so here is a link.  https://photos.smugmug.com/Amati-Riva-Aquarama/i-NnLfdJV/0/939b8edc/1920/IMG_5016-1920.mp4
ANDY
VIC
« Reply #313 on: August 16, 2020, 10:48:08 pm »
Hi Andy thank goodness you and UK Mike are working through the Riva build its so useful I am at the stage of applying the 1mm ply cover strips however these seem quite a bit different in shape size to fit , unlike the mahogany top sheets that fit perfectly , in fact holding the ply and mahogany together they do not match, am i missing a trick here, should the 1mm ply be cut about to fit it seems odd to get this far with this query as every other component just clicked together spot on have i got abad batch 1mm ply do you think look forward to your view
Taranis
  • Balne Moor MBC
« Reply #314 on: August 16, 2020, 11:13:14 pm »
All the ply is oversize Vic. Just focus on the edges where it is most important like around the stern hatch and work from there. The next parts forwards of there will over lap in the centre so need trimming, focus on the fit around the sundeck edges.
ANDY
VIC
« Reply #315 on: August 17, 2020, 12:01:24 am »
Thanks for that ,using the blogs is better than Amati instruction manual regards vic
DJW
« Reply #316 on: August 17, 2020, 10:05:59 am »
Finish looking great Andy.  Very nice sync on the motors. And the prop shaft / tube look really neat where they exit the hull, hope I can get same.
Taranis
  • Balne Moor MBC
« Reply #317 on: August 17, 2020, 01:30:31 pm »
Thanks David. The batteries were close to discharged in that video so there's a lot more revs there yet. Target is 14,500 rpm max. This is the rating of the 35mm C type propeller and safely under the max rpm of the prop shafts.
CMB are going to start selling Overlander motors too.
Today is sanding and varnishing again its like groundhog day  {-)
Next will be 5th coat on bottom and 4th elsewhere.
ANDY
Taranis
  • Balne Moor MBC
« Reply #318 on: August 17, 2020, 05:58:42 pm »
Ordered by phone Thursday arrived by Hermes today  :-))
ANDY
Mark T
« Reply #319 on: August 17, 2020, 06:13:32 pm »
Mahogany is such a lovely wood to work with - the boats looking amazing Andy  :-))
Taranis
  • Balne Moor MBC
« Reply #320 on: August 17, 2020, 06:15:06 pm »
Cheers Mark. I'm looking forwards to a lake test  O0
ANDY
Taranis
  • Balne Moor MBC
« Reply #321 on: August 18, 2020, 04:08:00 pm »
I had a break today so far. May do some varnish late evening.
I knocked up some more couplings for future builds but made them 40mm long this time.
I ordered various sizes of these from Hobbyking UK. They are £3.49 for four on eBay but a tiny fraction from HKing.
Less flapping about.
ANDY
Nordlys
« Reply #322 on: August 18, 2020, 04:17:37 pm »
Sorry, what are we looking at Andy?
N
Taranis
  • Balne Moor MBC
« Reply #323 on: August 18, 2020, 04:20:46 pm »
The battery balance lead keepers  :-)
ANDY
ChrisF
  • What's my favourite cake!
« Reply #324 on: August 18, 2020, 08:42:12 pm »
All looking really nice. I wish I had the equipment to make my own couplings etc. as some of the the ones I've bought haven't always been of the quality expected. Not really worth me investing in the tools required for the number that I will require though I do understand the satisfaction that comes from making your own.
Interesting that you say CMB are going to sell Overlander as they are my motor of choice.
Chris
Building Fairey Marine boats: River Cruiser 23 prototype, Huntress 23 Long Cabin with stern-drive, Huntsman 28, Huntsman 31 and Swordsman 33 and two more to come! All scratch built and to a scale of 1:12
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17   Go Up
Page created in 0.122 seconds with 22 queries.
