Pages: [1] 2 3   Go Down
Author Topic: HMS Enchantress 1934 - 1952  (Read 15626 times)
colin-d
    • my hobby
« on: June 30, 2020, 01:04:08 pm »
So here goes, firstly I would like to say, I build models of particular ships because I like there appearance, not because of any history, I am not really interested in its history, most of you know from my last build and probably my HMS Inflexible Build that I am not really into Warships, or the so called Greyfleet, so please create a new thread if you would like to give History lessons..
my version of the Deansmarine’s kit of a Bittern Class Sloop...  selected to be a Admiralty Yacht in 1934...
There will probably be large differences with my version compared to the show room model at Deansmarine, largely because of a lengthy conversation with Mr Dean and the available fittings..  so there will probably a bit more or less.. as the case maybe..
For example, the options that I have changed:
resin ships boats
Propshaft’s and “A” Frames
single stations
there are probably a few other bits and pieces, you might recognise during the build..
I try my best to produce a decent model.. more to come once all has arrived  :-))
colin-d
    • my hobby
Re: HMS Enchantress 1934 - 1952
« Reply #1 on: July 01, 2020, 12:08:04 pm »
While waiting for the box to arrive, the research brings up a fair bit of info on the Internet, a few black and white photos...
But by all means the best info, is from the NMM, costs a fortune...
colour Plans have been downloaded..
A fair bit of red pencil, we're things have been moved around and or omitted from the original Bitten class..
One could even add more cabin space on top of the already two decks that the model shows..  only one photo that I could find on the Internet showed this arrangement.. as there was no date stamp to show when this happend.. I will stick with the two decks and omitt the 1st lords cabin..
One thing I have noticed from these plans... the propshafts do not run 100% parallel to each other..
At the motor end they are closer together than the prop end.. at this scale it's only a few millimetres, but noticeable on the plans..
Hopefully the first photos at the weekend or latest next week.. :-))
« Reply #2 on: July 01, 2020, 08:13:52 pm »
I look forward to your log Colin.
colin-d
    • my hobby
« Reply #3 on: July 06, 2020, 05:40:54 am »
the kiel has been laid…  but i dont realy feel as if its 1934..  {-)
all the normal Points to take into account, rubbing the hull down, sanding the top of the Hull down to the Deck line, adding filler to the inside of the Hull then sanding it down to make a nice Surface for the deck supports to be glues to.. make up the deck support beams, and generaly Transfer messurements from the plans onto the Hull..
« Reply #4 on: July 06, 2020, 07:39:31 pm »
You have made a great start Colin  :-))
colin-d
    • my hobby
« Reply #5 on: July 08, 2020, 06:22:12 am »
Time to install the main drive System...
I have opted for some different Propshafts and "A" Frames, reason for the Propshafts, I wanted them to have the free running part, and also a M4 boss for the Props with a 2mm shaft..
There is a larger variety of props with M4 thread than there is with a M2 thread..
Yes, the “A” Frames are a white metal fitting, I knew that Mr Dean has these, but they are not readily available, it’s a question of asking nicely
I can hear you all now….   %)
WoW a white metal fitting as a “A” frame, they will not take the strain…
I can assure you they can, I have used them before…
The centre has carefully been hand drilled out, and bushes inserted, with room for lubrication fluid…
I have made up couple of templates, to align the Propshafts
To tubes have been abraded to make sure the glue has a better chance of sticking to them..
Once all the glue had gone off, the templates and shafts were removed, some filler was applied to the outside and then rubbed down until it suited
The template from inside the Hull was then cut down to size and glued in place, a bit of a propschaft brace which also forms part of the base that will be installed for the ESC and radio gear, the bulkhead for the motors was next.. All aligned with a ammeter and once satisfied with the amount of Amps drawn, the bulkhead was glued in place.. while the motors were running..
colin-d
    • my hobby
« Reply #6 on: July 10, 2020, 05:46:16 am »
something quick and easy to build in the evening..  an leave the longwinded bits for the Weekend..
here we have the basic top part of the Bridge.. quite straightforward..
the curved part is for 0.5mm plastic, run through the fingers a few times to warm and bend as required..
once the glue has dried out, it can be sanded and then the rest of the Detail can be added...
raflaunches
  • The Penguins are coming!!!
« Reply #7 on: July 10, 2020, 09:09:24 am »
Smart assembly of parts- really like the sharpness of the pieces. Getting curved wing bridges to look even is one of the hardest things to achieve. Liking your work. :-))
Nick B
Illegitimi non carborundum!
colin-d
    • my hobby
« Reply #8 on: July 10, 2020, 10:47:53 am »
Thank you Nick...
Of course the parts, were filed and sanded to form a better join were they angle off..
When everything is at right angles, and the curved part is exactly the same hight as the rest of the side parts, then by inverting the structure you get an even top edge coming..
Making it a little easer to get everything square and the same..  ;)
colin-d
    • my hobby
« Reply #9 on: July 13, 2020, 08:03:48 am »
I have made up a template for the bilge keels..
The tabs enter into the hull and gut pinned from inside of the Hull, then through a syringe with a added metal outlet that has been filed down on one side, a filled of epoxy is laid on the joint, this enables a nice smooth cured joint between hull and Bilge keels
colin-d
    • my hobby
« Reply #10 on: July 14, 2020, 05:46:25 am »
Here is the basic build of the lower part of the bridge, really quite simple and straightforward..
Once all the main structures are built I can then experiment with the detailing..
All of the port holes have been drilled out, here is a rather simple way of making ports hole look there part..  the porthole its self is (I think in English there called “Ferrules”) multistrand cable crimps..
The eyebrow of the porthole is made from a length of brass wire wrapped around a drill bit of the appropriate size.. Cut it along the length and you get little rings, making the second cut, you get half circles, hey presto  :-))
Dean's Marine
    • Dean's Marine
« Reply #11 on: July 14, 2020, 09:47:32 am »
Hi Colin nice one, good little tip, looks good
Ron
colin-d
    • my hobby
« Reply #12 on: July 20, 2020, 07:58:39 am »
The remainder of the Basic superstructures have been built, all rather straightforward, no major problems..
One thing i have changed is the Galley, in the kit there are a flight of stairs that go up to the Roof, just like the Accommodation structure, i have omitted this as one of the photos that i have, the galley Looks rectangular..
Now it's time to start on the detailing of which some parts are obviously not included in the kit..
Of course the laser cut wooden decks are included in the kit, fit very nicely, no trimming needed, what I have done though, the top edge on the side and on the roof of all the superstructures have received an edging strip from Slaters micro flat plastic, also available for Deansmarine..
This gives a little more effect to the superstructures and a bit more plastic for the railings to be attached to.. and also evens out the height difference caused through applying the wooden decks..
Around the top part of the bridge the windbreak has been glued in place, this is also from Slaters micro flat plastic..
of Course comments and Question are more than welcome…  :-)) ok2
« Reply #13 on: July 20, 2020, 12:08:34 pm »
Lovely work Colin. Hopefully see her in the flesh in the no too distant future.  :-)) :-))
colin-d
    • my hobby
« Reply #14 on: July 21, 2020, 05:16:14 am »
thank you Doug..
there is a Little hope i gues…
all the main structures are reasonably simple and quick to build, it's the Detail that takes the time..   ok2
the aim is to have her Ready for the Show..  if we are allowed in the Country.. and if the Show takes place..
colin-d
    • my hobby
« Reply #15 on: July 27, 2020, 10:34:06 am »
One of the options that i opted for was the ships boats, i am not using the supplied vacforms, rather the resin ships boats, two gigs, two dinghies, and two motor launches, of which I have made two different types.. one open and one closed at the stern part of the launch, here is the making of the closed one, made out of 0.5mm plasticard and slaters micro square.. I recon they look the part..
colin-d
    • my hobby
« Reply #16 on: July 27, 2020, 10:35:00 am »
During cement drying time..
I started on the funnel, cut the Vacforming out, sand them flat, apply strips of left over plastic to ease in binding the two half’s..  For the Base and top part of the funnel three pieces of 1mm plastic were glued together, filed and sanded to shape..  Around the top part of the funnel I attached a strip if slaters micro flat.. a cage for the top of the funnel was also made, this out of brass wire.. which was also used to raise the top part of the funnel as there is a gap between the top coming and the top of the funnel..
colin-d
    • my hobby
« Reply #17 on: July 27, 2020, 10:35:47 am »
During more cement drying time..
Adding a little detail to the lower bridge superstructure.. And the turret blast protection, or whatever it’s called.. The three main struts are part of the kit to support the forward part of the blast plate, the side parts were then glued in place, on the photos that I have seen, there is a type of cross sections under the blast plates, with scrap 0,5mm plastic I have tried to achieve a similar effect..
colin-d
    • my hobby
« Reply #18 on: July 27, 2020, 10:36:45 am »
More glue drying time
Then why not start of the turrets, these are also available in two version, one as a complete resin form (rather delicate, but highly detailed), or flat packed as 1mm plastic to be glued together, which is what is supplied in the kit.. I have used the 1 mm plastic with a bit of detailing from photos
All rather simple to build, the detail bit have been made out of remains of 0,5mm plastic and Slaters micro flat, and rod, station chopped down to form the eyelets and a piece of 0,2mm nickel silver that is threaded through the eyelets..
Hope you are all enjoying the photos.. :-))
colin-d
    • my hobby
« Reply #19 on: July 28, 2020, 09:14:10 am »
so far so good...
« Reply #20 on: July 28, 2020, 12:40:00 pm »
Looking good. Up to your usual standard  :-))
PS might let you put it on the club stand -we'll see  {-) {-) {-) {-) {-)
colin-d
    • my hobby
« Reply #21 on: July 29, 2020, 05:02:46 am »
y, thank you Doug...
That is O so generous of you.. :kiss:
Beagle1831
« Reply #22 on: July 30, 2020, 04:03:56 pm »
Very sharp work! Great details on those 4.7in guns
Work in progress and RN history on Instagram @beagleshipmodels
colin-d
    • my hobby
« Reply #23 on: July 31, 2020, 06:49:53 am »
Thank you very much for your appreciation James..  :-))
Glad someone is enjoying the photos..  ;)
raflaunches
« Reply #24 on: July 31, 2020, 09:00:24 am »
Stunning as always Colin
I look forward to seeing your next instalment.
Keep up the excellent work. :-))
Nick B
Pages: [1] 2 3   Go Up
