Coppering is now completed. Took about a month and a half, eight hours a day, 1,650 plates, 6mmx12mm. I ran out of blank plates and finished with self adhesive copper tape, cutting each plate to size. But, after using that tape, I wish I had done the entire hull with it. No glue residue to mess with and holds the copper tight to the hull. Lesson learned. Attached False Keel to bottom. My research says that all the clippers used False Keels. Campbells plans also show same. So, I went ahead and did it. The keel is attached over the copper plated main keel and then varnished. False Keels were sacrificial and protected the main keel and copper when grounding. Replaced when worn out. Ok, on to deck fittings.. finally. Dennis
