Pages: 1 2 [3] 4 5 6 7 8 9 10   Go Down
Author Topic: HMS Prince of Wales breakdown  (Read 59287 times)
Re: HMS Prince of Wales break down
« Reply #50 on: September 15, 2022, 11:26:37 pm »
There is little to say of the mechanical failure apart from that speculation and Pub Talk will rear its ugly head again >>:-(  after Her Majesty is finally laid to rest
I could not imagine an RN Capital ship docking outside of the UK, or in any location of the World however with the possible exception of the USA or Australia
Should a long sea transportation event be required, the Dutch Dockwise Vanguard vessel has a flat deck foot print of 275 M length, x 70 M beam and a sea transportation capacity of 85,000 tonnes
 https://www.bing.com/ck/a?!&&p=de89491718873b70JmltdHM9MTY2MzIwMDAwMCZpZ3VpZD0xYTRmYWU1MS05Yzk0LTZiNDUtMjQyOS1iZmFjOWRhNjZhNmImaW5zaWQ9NTE3NQ&ptn=3&hsh=3&fclid=1a4fae51-9c94-6b45-2429-bfac9da66a6b&u=a1aHR0cHM6Ly93d3cuc2hpcC10ZWNobm9sb2d5LmNvbS9wcm9qZWN0cy9kb2Nrd2lzZS12YW5ndWFyZC1oZWF2eS10cmFuc3BvcnQtdmVzc2VsLw&ntb=1
The Queen Elizabeth Class Carriers are about 280 M length x 80 M beam and approx 65,000 tonnes
Who built what to suit what?...or maybe a big box of Dutch Guilders may be needed?
rnli12
« Reply #51 on: September 16, 2022, 05:44:14 am »
Specualtion as always, lets have facts  :police: if they emerge in the public domain
« Reply #52 on: September 16, 2022, 10:52:59 am »
Levels of military sophistication lead to better solutions to 'get through' defences. Given that after the Falklands Exocet saga, the solution was a gatling gun, I wonder how effective this would be against the 'new' Hypersonic missiles?
dodes
« Reply #53 on: September 17, 2022, 03:12:15 pm »
I believe there is a dry dock at Southampton capable of taking her, it was used for QE2 and several other large vessels, also I believe that Southampton was typed to be emergency back up berthing for these vessels, though I expect this problem could come under build guarantee, then BAE would want her in their dock and work personnel. But i would have thought there would be a oil seal somewhere in the stern gland to make it water tight and give lubrication, salt water would cool it, but it is also abrasive. The vessels i served in had neox oil lubrication to seal and lubricate the bearing, plus water cooling to keep it at a working temp.
« Reply #54 on: September 17, 2022, 03:47:13 pm »
While there are a number of dry docks capable of taking the hull, they are not designed to cope with the great overhang of the flight deck of carriers without removing the cranes and any buildings along the sides.
Wiki reports that the Southampton dock was decommissioned in 2005 and now serves as a wet dock berth.
The QE class could no doubt make use of facilities in the USA but Rosyth is a bit nearer....
« Reply #55 on: September 18, 2022, 04:53:32 am »
So Colin says.......'The QE class could no doubt make use of facilities in the USA but Rosyth is a bit nearer'...
Well this is very true, however our Australian Captain Cook Graving Dock.....built to RN Admilitary requirements...at 347 x 45M wide should also provide a docking facility for a QE Class Carrier in Southern Oceans should the need arise
In October 1945, we hosted and docked the HMS King George V...she was 221M in length....
[my induction history at GID was that she [King George V], was experiencing a below-waterline population issue :o
[Interesting point in the image, is that shoring timbers placed along the length of the anti-torpedo hull armour belt just below the deckside length]
dodes
« Reply #56 on: September 20, 2022, 03:46:42 pm »
Hi Colin, yes you are correct, i forgot about those massive box's fitted on each side, along with her tumble out she is even a pain to berth. Ref the aft bearing spoke to a recently retired commander e , he explained to me how water stern bearings work, he mentioned three types from the white metal bearing to a special plastic typ using high pressure water to a very hard black rubber type. When the local press was talking about the lube oil running out, they were probably near the truth, in that the water pump failed leading to a dry bearing surface??? But the dock in Roseth is probably the one especially lengthen for the Hood.
« Reply #57 on: September 20, 2022, 04:37:05 pm »
Hi Dodes,
Yes the carriers are fendered well out from the quay and there are huge apparently retractable gangways in use. I think I have some photos but am not at home at the moment.
« Reply #58 on: September 27, 2022, 08:02:56 pm »
I seem to have deleted the gangway photos - not exciting!
Meanwhile PoW is languishing in Portsmouth presumably destoring and waiting until Rosyth are ready to proceed with the repairs. HMS QE is now in the USA.
It is all unfortunate but these things happen.
dodes
« Reply #59 on: September 28, 2022, 08:17:41 pm »
As they say, "you get what you pay for", the other day I was reading an old Janes and was reading about the old Victorious, apart from her heavy weapons system, 3" armoured deck and 3 x Foster Wheeler three drum boilers, her aircraft complement was 30 Buccaneers, various helicopters and 2 x Gannets. On half the P.o.W's tonnage! Never really understood why the old Illustrious was not fitted with a magnetic catapult with a couple of marinized R.A.F fighters, to investigate and trial the possibilities, as fixed wing planes have a greater payload than jump jets.
« Reply #60 on: September 28, 2022, 08:49:50 pm »
The US Navy have been experiencing problems with the magnetic catapults.
With regard to the Illustrious class, they would not have had the electrical generating capacity to operate magnetic catapults. They also had very small hangars with limited cpacity. They were never really intended as 'proper' aircraft carriers anyway. Their initial classification was as 'Through Deck Cruisers'.
They did give pretty effective service with the jump jets though.
The QE class can cary a decent number of aircraft but the problem is that we can't afford them!
KitS
« Reply #61 on: September 28, 2022, 09:37:19 pm »
'Marinizing' isn't just a matter of building in a wing fold and adding an arrester hook these days, as it was in WWII.
There's a lot more expensive engineering involved, plus the FAA's attitude of not wanting any old 'ex-RAF cast offs' to deal with.
Having said the latter, the RAF has exactly the same attitude toward anything the FAA have finished with, viz the Buccaneer S2s and the Phantom FG1s!
Kit
raflaunches
  • The Penguins are coming!!!
« Reply #62 on: September 28, 2022, 10:40:48 pm »
You’ve also got to remember that modern aircraft also weigh significantly more than WW2 aircraft. I know that BAE did consider a maritime version of a Typhoon which was going to be a joint venture with the Indian Navy but it never happened- I believe that the redesign was too drastic for a modern aircraft as the arrestor hook would have to be changed, strengthened frames and undercarriage would have to be designed into the airframe before the idea of other features such as folding wings, new nose undercarriage (two nose wheels instead of one to prevent shimmering) it would be easier to design a new aircraft from scratch then to convert these days.
Nick B
Illegitimi non carborundum!
dodes
« Reply #63 on: September 29, 2022, 08:42:13 pm »
Hi Nick, i would not describe Buccaneer's as WW2 aircraft, what I was implying that these new hulls do not carry enough aircraft or have the mix necessary to meet various combat demands, as the R.N does not have dedicated Interceptors to protect the fleet, though there is not much of a battle fleet to support these hulls. I mentioned the Vic because she had about half the displacement of the present hulls, but carried more weight in build, engineering and self-defence weapons than the present hulls. But I do worry that the R.A.F. has grab these airframes and are now dictating what the Fleet gets, they did prior to WW2 and the aircraft supplied by them to the fleet was pathetic.
raflaunches
« Reply #64 on: September 29, 2022, 09:13:03 pm »
Hi Dodes
I agree, the Bucc wasn’t a WW2 aircraft but is closer to that era than modern jets. I believe that the Bucc up until the F35B was the biggest/heaviest aircraft to operate off a British carrier and the Victorious was specifically chosen for conversion to operate the bigger aircraft. The F35B isn’t a light aircraft by any standards especially lugging a lift engine around for 99% of the time unused- it’s approximately 1.5 to 2 tons heavier than a Bucc depending on which spec you read. Coming from a ‘fast jet’ background I know that the amount of support equipment compared to the old aircraft is surprisingly immense.
As a carrier I suspect that much of the space is given to its crew as I’ve heard that each sailor/airman has their own room instead of shared bunks. I’m guessing that the reason why the new carrier are bigger is so they can operate the modern aircraft much in the similar way that the Vic and Ark were suitably modernised to operate Phantoms and Buccs.
Unfortunately in these modern days the aircraft are incredibly expensive so shared operations is only possible way of keeping these expenses down. A lot of people say we should have scrapped the Tornado fleet instead of the Harriers but from a position where the RAF had both arms tied behind its back it was common sense to retire the 89 Harriers compared to the 250 Tornados as Britain wouldn’t have any real numbers of strike aircraft other than 80 odd Harriers and the 100 or so Typhoons we had in service at the time. Personally I’d have found a way of giving the navy the Harrier fleet and the RAF keep the Tornado in the 2010 SDR which would have made sense but unfortunately the money comes out of one pot instead of three.
Nick B
ScottW
« Reply #65 on: September 29, 2022, 09:54:46 pm »
Since Buccaneer is a favorite Naval aircraft I'll take a moment to interject that it looks like design work on it was started in November 1953.
"If it is something that you can make use of, that's a bonus, but the real value is in the creation." Steve Bennett; Sidelines
« Reply #66 on: September 30, 2022, 10:28:57 am »
Yes Scott BUT ideally suited to its working environment. Long gone are bottomless budgets where (in the UK) sole purpose aircraft are designed and manufactured. We don't have Lancasters and Vulcans in service anymore, so the ability to deliver a 'Big' bomb are long gone. We are now presented with a compromise so flat tops need to be bigger to cater for the multi role capability need for todays aircraft, not for the sophistication of them but the need to carry more for past capabilities. Jimmy Doolittle wouldn't have a problem with todays carriers but I haven't seen a B52 land on one.
  Nick will probably be able to answer this one. What was the lifespan of the Harriers engaged in the Falklands 'Exercise' and these were 'Marinised'.
JimG
« Reply #67 on: September 30, 2022, 12:44:33 pm »
It has to be accepted that the new carriers have less aircraft than the older ones. But no thought seems to have been given to how effective the new F35s are compared to the old Buccaneer and Phantoms. The electronics and weaponry on the new aircraft are several generations better than the old so one F35 can do the job of several older jets. As for building a larger carrier to allow for the carrying of more jets this would lead to a considerable increase in crew needed. With the present manpower in the RN I doubt if they could man the carrier as well as the battle group need to give it protection. The increased space given to the crew is because of the amount of automation on board of the carrier leading to a much smaller crew than would otherwise be needed.
As for keeping the Harriers, they were basically obsolete with out of date electronics for their purpose as naval aircraft. There was some discussion on an old model aircraft forum with one of the members who was quite high up in BAE. His comments were that the Harrier airframe couldn't take the necessary upgrades in electronics needed to keep them battleworthy. Remember that when they were sold on to the US Marines it was for spares only as the instrumentation was not compatable with the US aircraft. Also the US use is purely as ground attack aircraft with no fighter requirement. We have already seen what happens when you try to cram electronics in an airframe too small with the Nimrod fiasco.
Jim
Dundee Model Boat club
« Reply #68 on: September 30, 2022, 01:25:48 pm »
HMS QE is designed to carry over 65 aircraft at a stretch so actually a few more than HMS Eage but I doubt if we will ever be able to afford that number!
dodes
« Reply #69 on: September 30, 2022, 02:33:03 pm »
Hi Colin, first time i have heard of numbers being carried, still think they should have fitted catapults and used fixed wing aircraft. But as yet no fighter cover for the fleet though.
JimG
« Reply #70 on: September 30, 2022, 08:59:07 pm »
I'm sure the F35 carries air to air missiles and has a cannon on board. It's not a dog fighter but in todays air warfare if they are close enough to dog fight then their missiles have failed. The idea is to destroy your enemy before it is in range of the ship.
Jim
KitS
« Reply #71 on: September 30, 2022, 10:40:23 pm »
The F-35B doesn't have a lift engine to lug around, it only has one engine, and that works for lift and forward thrust via its moveable nozzles. The bit that doesn't do anything during normal flight is the lift fan and clutch that are between the engine and the cockpit.
I installed the monster welding machine at Rolls Royce which makes the lift fan itself, so I know what I'm talking about here.....  :-)
Kit
« Reply #72 on: October 01, 2022, 03:47:24 am »
On September 15th Colin, you mentioned... 'tidal access slots for Rosyth are very specific'..
So is it a low tide for under the Bridge, then a high tide required to berth the PoW in Dock at Rosyth?
The media previously stated that the PoW was 'limping' back to Portsmouth after the initial Port side machinery failure and she was also shown at sea, assisted by a Tug Boat
Capital ships do not to limp <*< on the failure of one shaft............so it is clear to understand that she still has more than ample electrical energy available to provide 1/2 of her total population power being the 20MW Stdb electric motor drive
What has become of the Civilian GE Propulsion Engineers who salied with the PoW when she originally commenced her Deployment?
The longer the PoW is left in Portsmouth, the greater the Pub Talk will evade the truth O0
ScottW
« Reply #73 on: October 01, 2022, 04:08:34 am »
And that brings us to today's Q&A:
Q: How is an Oliver Hazard Perry class Frigate just like a Capital Ship?
A: It does not 'limp' anywhere on the failure of one shaft.
Q: How is an Oliver Hazard Perry class Frigate not at all like a capital ship?
A: It has one shaft.
« Reply #74 on: October 01, 2022, 04:47:18 am »
Scott... we had a number of FFG's [Perry Class Frigate ] in our Australian Navy [I worked on each of them as an Above Water Weapons Foreman]
So from this, understand only too well the FFG's main claim to fame was the GE LM2500 gas turbine main engine ...... 28 minutes from cold engine to maximum power on a single shaft as compared to 4 hours for a DDG x 2 shafts
A Frigate [nor a Destroyer] are not a Capital ship, which the accepted definition is a Battle Ship or an Aircraft Carrier
So my comment.......'Capital ships do not to limp <*< on the failure of one shaft' .....is still valid O0
Pages: 1 2 [3] 4 5 6 7 8 9 10   Go Up
