Hi there, thank you Mark , I just checked your build out geez its a work of art mate
.Well with these next shots inserting the stringers , if anyone is wondering why i have 2 cuts in the stem its because I measured once and cut twice instead of the other way around
. I got away with using 2 lamination's of ribs in the hollow heal section without having to steam them, then showing using fillers over the stringers at the frames , and cutting into the chine stringer for each rib, then all ribbed up ready for planking, cheers
