Author Topic: 1/72 twin 30mm  (Read 3885 times)
Rob47
1/72 twin 30mm
« on: April 19, 2026, 09:28:37 am »
Since demise of shipway I am struggling to find anyone who makes the RN twin 30 mm mount, retrofitted to many ships after the Falklands. Need it add to HMS Bristol, along with single bmarc 20mm
I will finish this model
T888
Re: 1/72 twin 30mm
« Reply #1 on: April 19, 2026, 10:41:41 am »
Twin Bob ?
Regards David
South Coast Modellers
dodgy geezer
Re: 1/72 twin 30mm
« Reply #2 on: April 19, 2026, 12:27:26 pm »
To what scale?
P.S. Ah - didn't read the title. 1:72 it is....
Rob47
Re: 1/72 twin 30mm
« Reply #3 on: April 19, 2026, 03:26:40 pm »
Twin Bob ?
Yep twin 30mm oerliken, power mounting, fitted to T42 and T82 post Falklands
T888
Re: 1/72 twin 30mm
« Reply #4 on: April 19, 2026, 09:29:10 pm »
Hi Rob,
Is this pics of the twin mounts your looking for?
Regards David
Rob47
Re: 1/72 twin 30mm
« Reply #5 on: April 20, 2026, 08:26:13 am »
That?s it
Akira
Re: 1/72 twin 30mm
« Reply #6 on: April 21, 2026, 01:16:26 pm »
I looked on Distefan's 3D fitting site and did not see that weapon, but if you contact him, he may well add it to his site.
https://distefano3dprint.com/pages/about-distefan-3d-print
Rob47
Re: 1/72 twin 30mm
« Reply #7 on: May 04, 2026, 03:57:01 pm »
Waste of time sent several messages but no reply
T888
Re: 1/72 twin 30mm
« Reply #8 on: May 04, 2026, 04:24:16 pm »
Hi Rob,
Do you have a detailed drawing for this mount?
Regards David
Rob47
Re: 1/72 twin 30mm
« Reply #9 on: May 05, 2026, 08:04:55 pm »
Yes but it has no dims on it
Rob47
Re: 1/72 twin 30mm
« Reply #10 on: May 05, 2026, 08:19:00 pm »
Umi_Ryuzuki
    • Models and Miniatures
Re: 1/72 twin 30mm
« Reply #11 on: May 06, 2026, 03:04:40 am »
Well if those are drawn at the correct scale, then draw a graphic scale on the paper that
show 0 to 40 mm with 1mm increments to five millmeter, then every five millimeters alternating
black or white, top or bottom of a center line. Then scan that so someone can print it out and
still be able to adjust the scale according to the scale drawn on the page.  :-))
And here I played around in Google AI to try and get a reasonable drawing of then Orelikon 30mm GCM-A03-2.
The AI did okay, but the front and rear views were missing the magazines on the gunner side, so I photoshopped it in.  %)
You'll just have to ignore the enclosed gunner position.  ;)
Page created in 0.011 seconds with 16 queries.
