Hi there Andi 4 by 4
I have several of these ACTion P40 mixers & so forth. The way they work:
here is some food for thought;
To take full advantage of the mixer; you require a peed (that is how I feel today
) should read speed controller for each motor - there is provision on the mixer to take three speed controllers and your rudder servo plug. When it is connected up in this way, as you advance the throttle stick from the zero position, all three motors will run at the same speed.
If you desire to turn port or starboard and move your rudder stick this in turn, through the mixer, either increases the outboard motor speed and decreases the inboard motor speed to aid the turning. The centre motor is not affected, it remains at the same speed as what has been set by your throttle stick.
This set up using three speed controllers, extracts the best performance out of these mixers; last thing about these mixers, when your throttle stick is in the zero position and you move your rudder stick from port to starboard; the motors do not react they stay stationery. Just the rudders move. However, if you slightly advance the throttle stick either forward or reverse, only by one notch, you get an immediate response of the mixer and your motors - so basically this enables the boat to spin on the spot. One motor running full ahead and one full astern.
The motor's speed is in ratio with the movement of the rudder stick. I have been trying to persuade FLJ and his support team to add a function in where when you put the stick hard over to either port or starboard, it drops the centre motor down by at least 50% speed.
I think personally this is the only alteration this mixer needs - I have worked with it for many years and the only problems I have had, or have ever seen regarding problems with speed controllers and mixers is the plonkre or even plonker
at the end of the sticks - the person who is controlling the model.
What we want is our very own FLJ to manufacture a chip - that is easy to insert into the MODELLER not the model - to prevent the modeller making silly mistakes
things like connecting things around the wrong way.
Hope this helps
aye
john e
bluebird
