Author Topic: Orange Peel Effect using Halfords Appliance White Aerosol  (Read 7114 times)
FerryNostalgic
  • Ferry Enthusiast
« on: January 18, 2018, 12:32:39 pm »
Hi All
I have just started painting the superstructure of my model and followed advice on this forum to use Halfords "Appliance White" gloss aerosol paint. Unfortunately, I am getting an "orange peel" effect to the finish (see photos). The paint was applied over perfectly smooth coats of high-build white primer. I am spraying at about 25-30 cm from the surface.
  • Can anyone advise where I am going wrong?
  • Am I applying the paint too thickly or too thinly? (Sweeping too slow or too fast as I spray)
  • Can this be rescued by spraying over it? (I can't face the thought of having to sand it all again!)
  • I plan to spray over it with clear varnish to get a satin finish; would the varnish (if applied thickly enough) hide this horrible effect?
I would be grateful for any advice...
JP
TailUK
Re: Orange Peel Effect using Halfords Appliance White Aerosol
« Reply #1 on: January 18, 2018, 12:56:17 pm »
Seen that happen when the can is held too far away or when the can is very cold.  Personally I avoid Appliance white as its a bit stark for my taste, you might be better with a car colour white.  A light rubdown and another try is probably called for but warm the can first.
FerryNostalgic
  • Ferry Enthusiast
« Reply #2 on: January 18, 2018, 01:37:13 pm »
Thanks TailUK,
I did try warming the can first, but obviously not enough! The garage where I'm working is petty cold and so is the model...
Actually I agree about the white being too stark. Do you happen to know of any particular white car colours that are a bit softer?
TailUK
« Reply #3 on: January 18, 2018, 01:45:36 pm »
I've always liked Nissan Artic White for white projects.
inertia
« Reply #4 on: January 18, 2018, 02:04:47 pm »
I've always treated 15°C as the minimum temperature for spraying. I also use Halfords rattle cans and can attest to the orange-peel probably resulting from too low a temperature and too much distance from the workpiece. I'd advise you to leave it to dry in a warm room until you can't smell even a trace of solvent with your nose smack up against it - then leave it another 48 hours. Rub down with 600 wet-or-dry then recoat it when it's warmer. BTW I also use Appliance Gloss White. Hope this helps.
Dave M
FerryNostalgic
  • Ferry Enthusiast
« Reply #5 on: January 18, 2018, 02:14:30 pm »
@TailUK - Thanks for the advice. I will try Nissan Artcic White and compare it.Given a car colour code/name, I could get the paint colour made up and use my airbrush. I'm still very much a novice with it but I'm sure it will give me more control and better results than an aerosol...
@Inertia - Thanks for confirming the advice on temperature. Been spraying in my very cold garage. I will rub down and have another go in warmer conditions.
roycv
« Reply #6 on: January 18, 2018, 02:21:59 pm »
Hi warming up the model can help stop the orange peel effect, not always easy though.
Roy
« Reply #7 on: January 18, 2018, 02:25:11 pm »
Use a hair dryer to GENTLY warm the model and stand the paint can in warm water for a short while before using.
« Reply #8 on: January 18, 2018, 03:57:34 pm »
That's what I have been doing Colin.
It works a treat but the room must be warm after for at least the first few hours.
Brian60
« Reply #9 on: January 18, 2018, 05:05:32 pm »
DON'T SPRAY THE CAR PAINT OVER THE APPLIANCE WHITE -- THEY ARE INCOMPATIBLE AND YOUR ORANGE PEELING NOW IS NOTHING TO WHAT IT WILL BECOME IF YOU PUT THE CAR PAINT OVER IT.
« Reply #10 on: January 18, 2018, 05:19:30 pm »
I fear Brian is right! You may have to stick with appliance white after rubbing fown the existing finish, unless you strip it all off!
inertia
« Reply #11 on: January 18, 2018, 05:38:24 pm »
I've never had a compatibility problem when spraying Halfords colours on top of each other - even the Appliance White. If you use another brand then it's a different matter.
DM
cos918
« Reply #12 on: January 18, 2018, 06:36:03 pm »
been there done that got the tee shirt.
Yes cold effect the paint . I have painted at 5 deg and got away with it . Trick there is soon as you have finished spraying out side move the model indoors straight away to a nice warm room .
Your main culprit is the primer , If you have built up thick layers of that primer . What I found was when you top coat in your final colour . it re softens the primer . Now if the primer  coat was just a dusting happy day ,thick layer and you get all sorts going on. I use appliance white all the time  . I find with any so called car make white has a yellow or blue to it .
If it was me I would give a light sand once the paint is rock hard. then lots of VERY VERY light coats eg one pass and see how that works .
I have painted over appliance white with other halfords paints no problems . If in doubt do a test .
john
« Reply #13 on: January 18, 2018, 07:45:15 pm »
Sorry to say this but the underlying primer has nothing at all to do with orange peel
Causes of Orange peel with Aerosols
Poor technique
Can held to far away from the work
Can NOT  shaken long enough
Aerosol to cold
How to cure the finish
Rub down with 800 wet dry wet with fairy liquid or equivellent
Respray again
Leave the can in the house to get to room temp for a couple of days.
Warm the aerea that you are painting
Spray the model approx 9ins away
I DO NOT RECCOMEND  putting ANY aerosol in a bucket of water at all as these are a pressurised container and in extreme conditions they WILL explode especially if the are warmed up and this is made worse by shaking.
mrzippy
« Reply #14 on: January 18, 2018, 08:23:16 pm »
Think there's been more replies while I've typed this but here goes - from bitter personal experience -
don't spray Halfraud's Primer back over Halfraud's Gloss - it will act like paint stripper !
Also a friend (30 years car paint spraying experience) restoring a valuable vintage motorbike petrol tank,
time constrants forced him to use Halford's aerosols when his compressor expired.
Primers ok, metallic silver gloss ok, lacquer all ok, the final coat of Halford's petrol resistant lacquer
applied according to instructions stripped everything off back down to the metal !
I use Halford's paint on my models - it's readily available, convenient to use etc,
and generally it's ok, but occasionally a new can acts like a Dry Powder Fire Extinguisher,
the paint shoots out dry and will not flow out to liquid ?
Paul
The price also amazes me, each time I buy a large can its gone up another quid !
Klunk
« Reply #15 on: January 19, 2018, 02:38:27 am »
B and M store gloss white, black and grey and matt of the same colours above plus laquer all £1.49 a can
full time penguin
Klunk
« Reply #16 on: January 19, 2018, 02:39:51 am »
Ps for red oxide hull colours and grey, black green or blue hull colours i use floor paint from wilco. £3 a small tin.
full time penguin
carlmt
    • Linkspan Models
« Reply #17 on: January 19, 2018, 02:47:16 pm »
That is rather unfortunate JP - sorry to see this mate.
Be aware though that, with the Appliance White, I have never managed to get a completely smooth, flat, gloss finish.  Close, yes...but not absolutely perfect.
The Norland is sprayed with this and has a slightly matt (only slightly mind) finish - which I personally prefer to the full-on gloss.
Over glossy can look wrong on a scale model...
PS - The window frames look damn good though!!!!
RST
« Reply #18 on: January 19, 2018, 05:59:45 pm »
Just wanted to say as soon as I saw the first post my immediate thought especially this time of year was temperature.  Having some auto spraying background I wouldn't rattle can anything near 15deg.  More like 20-25 (which seems to be what most suppliers I've found recommend).
Re: rubbing back -you might get on better with Scotchbrite pads and I've often used them wet, with a dab of natural soap.  They conform to curves and around fine detail much better than abrasive paper.  Check your local auto factor paint shops or industrial counters.  If you're careful this may even flatten back enough not to require a re-coat!
With regards to choice of paint I have no issues with Halfords paints -they've got a very good reputation for what they are though this past year I think the forumation has changed slightly.  I've switched to appliance white also though -but I'm using Rustoleum this time -I would have preferred Plasticote but couldn't find it anywhere.  Usual caveats / guidance apply on compatibility.
Hope this helps -it's looking good otherwise -white is one colour I hate doing!
FerryNostalgic
  • Ferry Enthusiast
« Reply #19 on: January 20, 2018, 10:23:09 am »
Thank you all so much for your advice. I'm bowled over by the responses  :-) :-) :-)
In future, I will test-spray a piece of plastic card before moving onto the model.
As you can see from my photos, the superstructure has loads of protruding window frames that are close together, which make sanding really difficult. Things went badly wrong when fitting these, so I had no option but to use a high-build primer to smooth out the imperfections, which worked really well. It's only when I sprayed over it with Halfords Appliance White that it all went seriously pear-shaped!
I've started rubbing it all back down again, but sanding around the window frames is really awkward and this has brought back all the imperfections. I have no option but to use some kind of high-build primer again but will test a small area first!
No more Halfords Appliance White (or any other aerosol finishing coats) for me. I will try to be brave and use my airbrush, after I have found a suitable shade of white. I will also wait for much warmer conditions before I spray!
Thank you all again!
Brian60
« Reply #20 on: January 21, 2018, 09:23:21 am »
I said do not put Halfords car paints over appliance white for a good reason....
Appliance white is a enamel based paint for kitchen appliances, this is for the hard wearing properties of enamel paints.
Halfords car paint is a cellulose based acrylic paint - that's why it has the awful smell.
Anyone that knows paint will know that you can put enamel over cellulose, but you cannot do it the other way around, if you do, the top coat will craze and crinkle far worse than any orange peel affect.
So the  way forward is to stick to one paint system only, either car spray paints, plasticote paints, humbrol or whatever, do not intermix unless you have done a test panel first.
The one departure from this is halfords spray primers, as they are going on the substrate (the ship) first, there is not normally any reaction to other paints you put over the top. I use red oxide primer for below waterline, then mask that off and use Humbrol enamels above the waterline, although I am slowly coming round to using Vallejo acrylics, once dry they are purported to be waterproof, but I seal them under a clearcoat anyway.
cos918
« Reply #21 on: January 21, 2018, 06:27:09 pm »
Hello Brian
I think you must be mixing up paints Because ,Halfords gloss appliance white is acrylic based like there car paints .  I have used appliance white on Celestine then painted over with both halfords and hycoat car paint with no problems . If it was enamel based i would have had paint reactions all over Celestine .
Here is the speck sheet
http://www.halfords.com/motoring/paints-body-repair/car-spray-paints/halfords-gloss-white-spray-paint-500ml
john
Brian60
« Reply #22 on: January 23, 2018, 02:55:51 pm »
As I see from the spec sheet. But I also see it is named gloss white, it is not named appliance white. The true appliance whitch they used to stock was totally incompatible with their car paint range.
inertia
« Reply #23 on: January 23, 2018, 03:40:16 pm »
http://www.slecuk.com/balsa-wood/Fairey-Huntsman-31-PR814.html
I built this display model about 18 months ago for SLEC and this is what I used to paint it, in the following order.
Whole model - U-Pol white primer
Roof, hull sides and transom - Halfords Appliance Gloss White
Dark blue cabin sides - Halfords Ford Royal Blue
Boot topping stripe - Halfords Ford Olympic Blue
Hull below waterline - Halfords Rover Pageant Mid Blue
I'll be only too happy to submit photographs of the cans, if necessary.
The white was masked off only at the edges so it was definitely oversprayed with all of the blues. There was no incompatibility whatsoever.
I have found that Halfords White Primer is too soft, even when dry, so I use the U-Pol on the advice of Dave 'Stavros' Jones, who apparently knows a thing or two about car paints.
QED?
DM
cos918
« Reply #24 on: January 23, 2018, 03:54:50 pm »
Have to agree on the white primer from halfords . even when set it is still soft .
john
Page created in 0.087 seconds with 22 queries.
