Thanks for the advice re: chisels.
I'll take them an old fella in the village that I know - he has a proper grind stone set up in his shed.
Not sure they will be that easy to re-grind. I saw my dad batter the head off a 1/2" bolt using one of them. And the chisel won!
I was wondering about other tools:
knives ( tempted by Footprint still for these ), hammers, saws, spanners. A big one is files - I use files a lot for modelling - far more than sand paper - which I only use really for body filler - and tend to use metal files as they are a lot kinder to balsa and ply - and unlike and paper a quick whizz with a file card and they're good as new. My dad had a set of 1/2 sized engineers and farmers files which would have been brilliant to use for modelling, but I can't find anything of that size now. ( I lost the orignals in my last house move
) Choice seems to be full sized enginners file or 6" needle files - I want something 1/2 way between the two.
Also power tools. I have been pointed in the direction of Ryobi by a couple of people, but others only say bad things about Ryobi.
The set of tools I'll looking for consist of - but isn't limited to:
Hammers ( small medium and large ) - ball pain, japanese, warrington, pin - maple or hickory handles.
chisels - 1/8", 1/4", 1/2" , 3/4" 1" 1 1/2" - ferruled handles so I can give them a whack if needed
1x set enginners files , 1x set farmers files. Preferably 1/2 sized.
Set of good quality metric taps and dies plus drivers ( say M1 - M6 or similar )
GOOD set of posi- and straight head screw drivers - I've wrecked 3 sets already with all the DIY I'm doing - the points just seem to drive off them when your dealing with stubbon screws ledged in old wood - should really use a stud extractor but keep forgetting.
Good set of punches and automatic centre punch. ( can't seem to find a steel centre-punch which is actually small enough to use anywhere - another lost item in the last house move )
small impact screw driver
good set of sockets + handles ( apparently Stanley make good sockets )
good ( and accurate ) torque wrench ( going to need one if I put one or more of my bikes back together )
enginners vice - full sized with that lever that makes the wonderful "pop" noise when you over-tighten and releases the jaws ( guess how I used to drive the old man mad when I was younger???
micrometer
good quality analouge calipers
metric feeler gauge
smallish lathe - big enough to turn a 10cc piston or similar on - I have no real idea about this yet though.
decent electric drill - with selectable hammer action
pillar drill - small as possible but with a decent drop hieght - will only be for modelling
good quality drill bits ( in a wide range of imperial and metric )
"home use" sized bandsaw (also any advice you chaps have on good makes of blades for this is appreciated )
I know everything won't all be by the same maker, and I also know that it won't be cheap. But my preference is to buy one set of good stuff once, and only have to replace breakages rarely.
So, if you chaps have any recommendations for "best in show" in any of the items above, please let me have your experiences.
Steve
