Author Topic: Tug bridge pic's  (Read 13302 times)
Damien
Tug bridge pic's
« on: August 01, 2008, 12:13:31 pm »
Does any one have any  interior pic's of a Tug's bridge showing fittings and placement of controls screens etc.
The bridge on my Seaport conversion has some large windows , I've ordered some sailors & a ships wheel from Red Bank Models and I'd like to add more detail.
If not personal pic's a link to a site with pic's would be appreciated.
Thanks in advance.
Damien
Re: Tug bridge pic's
« Reply #1 on: August 01, 2008, 12:39:27 pm »
Here's a few....
toesupwa
  • USA'd ex Brit
« Reply #2 on: August 01, 2008, 02:41:19 pm »
Try this http://www.rcgroups.com/forums/showpost.php?p=9541570&postcount=102
and
http://www.rcgroups.com/forums/showpost.php?p=9541600&postcount=103
 O0
andyn
« Reply #3 on: August 01, 2008, 09:26:35 pm »
I expect to see a superspringer with that level of detail soon  O0
By the looks of Martin's Puffer, he could do the lighting  ;)
chingdevil
« Reply #4 on: August 01, 2008, 10:30:32 pm »
Are these any good? I have a couple more if you want them.
Brian
chingdevil
« Reply #5 on: August 01, 2008, 10:33:39 pm »
And a couple more.
Brian
chingdevil
« Reply #6 on: August 01, 2008, 10:38:23 pm »
Last two
By the way Damien if you want the dimensions of any of the equipment in my photos PM me. I am going back to the tug in a couple of weeks, to take some more pictures and measurements before I start my build of her.
Brian
Damien
« Reply #7 on: August 01, 2008, 11:33:52 pm »
Martin, Toes, Andy & Brian The pic's are fanastic thanks.
Dimensions i'll work to the Sailors  Red Bank list them as 1:20 - 1:30 scale and the Seaport works out to be 1:26 scale of the Lorraine i'm approximating, hopefully i'll have the ordered bits within a week.
Thanks for the super fast replies O0 O0 O0
Damien
« Reply #8 on: August 02, 2008, 12:22:35 am »
A technical question, in the pic of the compass what are the balls on either side for ? Are they for calibrating the compass to overcome the influence of the metal structure ?
Damien.
andyn
« Reply #9 on: August 02, 2008, 12:30:44 am »
Damien.
Nah they're for overcoming the compass completely so the captain has to use the sat-nav  O0
chingdevil
« Reply #10 on: August 02, 2008, 11:44:00 am »
Hi Damien
Yes Damien that is what they are for, this is what Wikipedia has to say:-
http://en.wikipedia.org/wiki/Binnacle
"The construction of many early binnacles used nails (mid 1700s), which were later discovered to cause magnetic deviations in compass readings. As the development of the compass and understanding of magnetism progressed greater attention was given to binnacle construction to avoid compass disturbances caused by iron.
With the introduction of iron-clad ships the magnetic deviation observed in compasses became more severe. Methods of compensation by arranging iron or magnetic objects near the binnacle were developed. In 1854 a new type of binnacle was patented by John Gray of Liverpool which directly incorporated adjustable correcting magnets on screws or rack and pinions. This was improved again when Lord Kelvin patented in the 1880s another system of compass and which incorporated two compensating magnets.
Brian
Damien
« Reply #11 on: August 02, 2008, 01:39:29 pm »
Thanks Brian, I just knew there was another explanation besides Andy's humor
Can you tell me the approx dimensions of the brass binnacle in the second last pic please ?
chingdevil
« Reply #12 on: August 02, 2008, 01:54:12 pm »
Sorry Damien
I can not give you any dimensions of the binnacle, this is one of the reasons I am going back to the tug in a couple of weeks. I took 125 pictures of her, but did not measure much luckily the marine superintendant of the company that owns her does not mind me going back to have another look.
Brian
mike_victoriabc
« Reply #13 on: August 02, 2008, 03:54:04 pm »
Must have a manual for operating controls in those first photos! Must duplicate some functions depending on direction?
Thanks for posting those.
Damien
« Reply #14 on: August 17, 2008, 02:37:09 pm »
Hi Brian,
I would appreciate some measurements and any more pic's, if you get back there ie: Ships wheel diameter, width & depth of the control panel, other desks, drawers etc.
Depth sounders, radar screens & computers and radios i can work out myself easy enough.
It must be great having access  like this.
Damien.
chingdevil
« Reply #15 on: August 17, 2008, 02:54:04 pm »
Damien
I am going back to the ship on Wednesday morning, that will be no problem. Do you want the dimensions of the binnacle?
Brian
Damien
« Reply #16 on: August 17, 2008, 09:34:01 pm »
Yes please Brian, I have a 9mm bullet casing i'm hoping will be a good starting point.
Damien.
chingdevil
« Reply #17 on: August 21, 2008, 12:04:20 pm »
Damien
Did not get to the tug yesterday due to car problems, now going Tuesday.
Brian
Damien
« Reply #18 on: August 21, 2008, 12:27:48 pm »
No probs Brian i can wait i work so slow anyway, a few days won't matter.
Damien.
Damien
« Reply #19 on: September 05, 2008, 02:46:49 pm »
I made a start on bridge fittings, the binacle is only needing a few points on the compass.
I used a .22 bullet casing (used) as the calliper shows 7.1mm diameter.
and a chart table with draws crewman 1:30 scale shows size, i nees some 1:26/ 1:30 scale charts/maps.
Well under way with the control/wheel area pic's soon.
chingdevil
« Reply #20 on: September 05, 2008, 04:40:15 pm »
Damien
I will post the dimensions over the next couple of days, have the pictures just need to write the dimensions on them. Once again work has got in the way of pleasure.
Brian
Damien
« Reply #21 on: September 06, 2008, 12:03:05 am »
Thanks Brian, No pressure or rush I was  feeling good and my brain was working so i started. I thank you for your efforts and look forward to seeing the new info.
Damien.
chingdevil
« Reply #22 on: September 07, 2008, 11:35:22 am »
First off the binnacle
Main casing
260mm diameter
140mm height
Rim
45mm from top off casing
Shroud
130mm height at the back
The gap at the front is 240mm
The shroud is fitted inside the binnacle casing
The balls are both 85mm in diameter, the brackets holding them are 110mm out from the binnacle and the part on the binnacle is 50mm deep. The bracket was 30mm wide
The compass was a 150mm in diameter, the ring supporting the compass was 220mm in diameter.
Wheel Next.
Brian
chingdevil
« Reply #23 on: September 07, 2008, 11:45:03 am »
Now the wheel
Diameter across the spokes 840mm
The rim was 580mm outside, 480mm inside
Handles were 130mm long
Diameter of central hub 135
Rim was 55mm thick
Cabinets next
chingdevil
« Reply #24 on: September 07, 2008, 11:52:19 am »
Cabinet
I did not measure the doors or drawers just the basic size, if you want those dimensions I can get them.
Width 1130mm
Height 920mm
Depth 590mm
It has an edge around the top which is 20mm higher than the surface. The toe board at the bottom is 60mm back from the front
Seat next
Brian
Page created in 0.176 seconds with 18 queries.
