September 01, 2025, 08:46:14 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
Robbe Jet ski
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Robbe Jet ski (Read 3205 times)
BlazingPenguin
Guest
Robbe Jet ski
on:
September 19, 2008, 04:43:08 pm »
Does anyone know how to set up the twin props properly on the Robbe jet ski?
They seem to clash with each other on normal running and will rip off a prop if you dare to try turning....any help appreciated. ::)
Tester
Full Mayhemer
Offline
Baughurst, Hampshire
Re: Robbe Jet ski
Reply #1 on:
September 19, 2008, 05:51:23 pm »
Not a lot of help but mine is set up as per the build instructions and no problems at all.
BlazingPenguin
Guest
Re: Robbe Jet ski
Reply #2 on:
September 19, 2008, 07:16:30 pm »
Erh...I dont have the build instructions¬ :(
john54
Guest
Re: Robbe Jet ski
Reply #3 on:
September 19, 2008, 07:40:43 pm »
Heard of that snag before. Try less servo throw or decrease rate on t.x.
grasshopper
Full Mayhemer
Offline
Lincolnshire!
Re: Robbe Jet ski
Reply #4 on:
September 19, 2008, 08:09:33 pm »
That's the one with two 'outdrives' isn't it? - have you got a link missing between the two, they shouldn't strike each other unless the turn angle is too high or there's too much play in the hinge points.
BlazingPenguin
Guest
Re: Robbe Jet ski
Reply #5 on:
September 19, 2008, 08:14:15 pm »
The threaded link between both drives is there so its not that.
If I reduce the throw I would less a good bit of manouverability I think.
I would like to see what the setup booklet says....anyone willing to forward a scan???
Tester
Full Mayhemer
Offline
Re: Robbe Jet ski
Reply #6 on:
September 19, 2008, 08:57:15 pm »
I'll did out the manual and scan the relevant pages, it'll be tomorrow if that's ok
Richard
BlazingPenguin
Guest
Re: Robbe Jet ski
Reply #7 on:
September 19, 2008, 09:12:25 pm »
That would be fantastic Tester!
Please dont put yourself out at all, whenever you get around to it will be fine.
Tester
Full Mayhemer
Offline
Re: Robbe Jet ski
Reply #8 on:
September 20, 2008, 09:54:15 am »
Scanned the manual and email to your address in profile.
Attached is pic file of the propeller set up section
HTH
Richard
BlazingPenguin
Guest
Re: Robbe Jet ski
Reply #9 on:
September 20, 2008, 10:26:37 am »
Just read it Richard and the horizontal/vertical alignmeny method they suggest is what Ive done myself, I do notice the drives are rather more splayed than mine,I'll also try to limit servo throw a little.
Tester
Full Mayhemer
Offline
Re: Robbe Jet ski
Reply #10 on:
September 20, 2008, 10:29:26 am »
It might be worth checking the pushrod length between the two drives, should be 41mm tip to tip
BlazingPenguin
Guest
Re: Robbe Jet ski
Reply #11 on:
September 20, 2008, 11:00:20 am »
Tadaaaaaaaaaaaaaaaaaaa!
Problem solved sir!
Sweet as a nut,nothing touches anything its not supposed to...anywhere.
Lets se what tomorrow and 9.6v brings shall we?
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
Robbe Jet ski
