Author Topic: What brushless motor setup do you have?(Your replies go onto a convenient chart)  (Read 6569 times)
Weeds
Hi Martin,
Please, you HAVE to check this out. It works so well, you'd think it was specifically made for this forum!
Type in the data here: http://spreadsheets.google.com/viewform?key=p9c1CESjtjA7ZkLJHEz5XDQ
View all entries here: http://spreadsheets.google.com/pub?key=p9c1CESjtjA7ZkLJHEz5XDQ
(it takes 5 minutes for your entries to be put online)
Any suggestions? How would you like the questions on the form to be changed? Are the instructions confusing, if so, how? Is typing into the form easier or harder than just posting a reply? Is the chart easier to read than going through pages of posts?
By the way, the last member to post in the form will get $5 via paypal!
Garabaldy
my paypal account has been frozen for 6 months as some one from eastern europe hacked it <:(  I will fill out the table all the same though.  Well once she gets her bottom wet.
gribeauval
Hi Martin,
Looks good. The only thing I would say it needs is the prop diameter/no of blades to give a better picture of each setup.  8)
True Lifeboat Nutter!!
Done mine.  :D
Weeds
Hi Martin,
Done!
nick_75au
Added another Springer and my Glynn Guest Miami crashboat
Might want to add a column for measured current draw.
Nick
checked it, somehow the ratio for my Springer got munched should be direct or 1:1
Weeds
Nick
Here is what the list looks like so far..
Code: [Select]
Timestamp MODEL?                      MOTOR(S) fitted?        GEARING                  ESC/Amp Rating                          BATTERY                      RUNTIME/Amp Draw/SPEED Prop Diameter/Number of Blades Contributing Gentleman's Name/Comments
10/27/2008 6:48:21 Springer SkyWing 980kv Outrunner Direct 40Amp 12v Gel cells Hours!
10/27/2008 17:53:17 Fairy Marine Tracker 2 Thumper 4250 x2 None 60A x2 12.5Ah SLA 60 min + 45mm / 2blade
10/28/2008 3:45:36 Springer Tug KA 20-22L direct 40 2 x 6v SLA Parallel Hours/4.6 Kph 40mm/3 blade nick_75au
10/28/2008 3:47:27 GG Miami Crashboat KH450 2.3:1 40 amp 10 cell 3300mH Nimh 25 + kph 10/15 minutes 30mm 2 blade carbon nick_75au
(Admin, I am using /code brackets for a reason.. it makes it easier to read if you scroll to the right, otherwise the alignment is not right)
The forum don't 'forms very well do it!
I'll sort it out later Weeds.
Weeds
View all entries here: http://spreadsheets.google.com/pub?key=p9c1CESjtjA7ZkLJHEz5XDQ (it takes 5 minutes for your entries to be put online)
This video shows how the fill out form and automatic chart work.. enjoy..
http://www.youtube.com/watch?v=NSYKJOK7zL8
muduck
I just posted info for my MountFleet CRUISER. I have it currently running with a PROTEUS Steam engine.
Due to another commitment for the engine I wanted something in Electric Brushless.
I have only bench run the setup, but it seems to be in the ballpark. The forward/reverse looks like it's going to take some practice to perfect,
