Author Topic: pillar drill  (Read 7549 times)
tomocj
pillar drill
« on: February 07, 2009, 10:22:55 am »
Can any one recommend a reasonably priced Pillar drill or has any one used the bench mounts where you add your own drill,turning that into a pillar drill? if so are they ok?
Thanks Chris
aestus57
  • Pentland Model Boat Club
Re: pillar drill
« Reply #1 on: February 07, 2009, 10:34:45 am »
Hi Chris,
Wouldn't really reccomend the ones where you put your electric drill into a stand, they're not that accurate in drilling a hole at 90 deg to the workpiece.
have a look at the Warco site for engineering tools or Chester UK Ltd or Axminster,  Google any of those and you will come up with many suggestions.
Peter
Think I'm suffering from De Ja Vu,   I'm sure I've forgotten this before!
dan
Re: pillar drill
« Reply #2 on: February 07, 2009, 10:43:58 am »
hi Chris,
have a look at the drills from screwfix, they have some decent sturdy work bench pillar drills for a very good price, plus next day delivery
http://www.screwfix.com/search.do;jsessionid=03LJWDO52QBQWCSTHZOSFFQ?_dyncharset=UTF-8&fh_search=pillar+drills
Proteus
Re: pillar drill
« Reply #3 on: February 07, 2009, 10:46:53 am »
what do you want to do with it big holes fine holes etc and how much space ?   Have a look at  http://www.arceurotrade.co.uk/Catalogue/Machines-Accessories/Milling-Machines/Model-X0-Micro-Mill  this a magic modelers tool as it is not to big and you can work to close tolerances , good if you want to drill stanchions etc and in future you can add a table and mill wood brass plastic etc  , has a digital depth gauge and fine feeds , and is quiet in use, i got one and found it much better than the set up it replaced ( a dremel type and stand).
Proteus
Re: pillar drill
« Reply #4 on: February 07, 2009, 11:05:59 am »
Bought mine from B&Q :-))
Stav
Re: pillar drill
« Reply #5 on: February 07, 2009, 11:22:00 am »
I have a dremel stand. I was surprised by just how inacurate it is. Especially condsidering the dremel is a fine tool.
tomocj
Re: pillar drill
« Reply #6 on: February 07, 2009, 04:08:55 pm »
Thanks for your help ,that one proteus has mentioned will fit the bill perfectly.Thanks again Chris
tobyker
Re: pillar drill
« Reply #7 on: February 07, 2009, 11:32:02 pm »
I have the one that turns up every so often in Aldi. Suits me fine.
barryfoote
Re: pillar drill
« Reply #8 on: February 08, 2009, 09:53:22 am »
I have one too and yes it is not very accurate.
If you are interested in a small unit, Proxxon do a pillar drill for about 135 sterling..
Re: pillar drill
« Reply #9 on: February 08, 2009, 10:16:57 am »
I don't use one often enough to justify the price. I can get a small cheap one here for 40 quid.
I have not had a need for precision yet.  ;)
tomocj
Re: pillar drill
« Reply #10 on: February 08, 2009, 11:55:27 am »
 Looking for small and cheap ,will probably only use it for model boats and aircraft.
Chris
dreadnought72
Re: pillar drill
« Reply #11 on: February 08, 2009, 12:45:21 pm »
Aldi's (Airdrie, at least) had a pile o' pillar drills in it on Friday. Cheerful, and definitely cheap.
Andy
tomocj
Re: pillar drill
« Reply #12 on: February 08, 2009, 02:33:41 pm »
Thanks Andy ,I will check my local Aldi.
Chris
