Author Topic: help needed in marking out.  (Read 3724 times)
boatmadman
« on: September 30, 2006, 03:39:24 pm »
Can anyone tell me how to accurately mark out for drilling, 3 points on a pcd of 21/32 nds?
Thanks in advance
Ian
gribeauval
Re: help needed in marking out.
« Reply #1 on: September 30, 2006, 04:11:45 pm »
This is the standard formula used in engineering taken from my Zeus Precision Tables ( buy a copy from your local engineeering suppliers, worth their weight in gold!!!)
mike   8)
True Lifeboat Nutter!!
boatmadman
« Reply #2 on: September 30, 2006, 04:25:50 pm »
Mike,
Thanks! you have solved a real headache for me!
Ian
gribeauval
« Reply #3 on: September 30, 2006, 04:42:33 pm »
The Zeus tables have a whole section on marking out holes on a pcd!!  8)
« Reply #4 on: September 30, 2006, 07:13:04 pm »
If you can't measure to the accuracy required by the formula, use a compass (geometric not magnetic) set to the radius of the circle and mark off radii on the circumference using each point marked to mark the next. This will give six equidistant points on the circumference. Pick 3 alternates and Bob's you aunt's husband.
Hope this makes sense.
Doug
Page created in 0.014 seconds with 18 queries.
