Author Topic: ESC for Brushless Motors  (Read 2067 times)
Turbulent
« on: March 17, 2009, 08:26:03 am »
A bit out of my area this one - Probably one for the race boys.
I've seen a load of cheap ESC for Brushless motors & have a question.
Is there any reason these cannot be used on standard motors. Cheers
andrewh
Re: ESC for Brushless Motors
« Reply #1 on: March 17, 2009, 08:41:34 am »
Hi, Turbulent
if by standard motors you mean brushed DC motors - Simple answer is yes, there is a good reason - they can't work at all!
Brushless ESC has 3 output wires and supplies a rotating 3-phase AC sinewave
Standard motor gets DC voltage - a brushed controller has 2 wires and supplies chopped DC.
As you say, brushless ESCs are very cheap and available :}  But so are BL motors!
andrew
Turbulent
« Reply #2 on: March 17, 2009, 09:03:33 am »
Cheers - It's in a sub & I might look at Brushless motors next time - what's the advantages?
andrewh
« Reply #3 on: March 17, 2009, 09:21:29 am »
efficiency and size
The amps stay in the batteries, carbon dust is not flung off by the brushes (there aren't any), very little heat put out by the motor.
also smaller motor (for a given power), smaller batteries, (if that helps)
If you need it awesome power
other than those, not much advantage :}
andrew
Subculture
    • Dive-in to Model submarines
« Reply #4 on: March 17, 2009, 09:30:05 am »
Another lesser advertised advantage, no commutator means no glitching caused by sparking. Always an advantage in a submarine.
Also brushless motors maintain their performance, unlike brushed motors which degrade over time. The only thing to wear out is the bearings.
The snag for submariners and scale boaters in general is finding brushless motors that operate in the right RPM band. A lot of the German model subamriners are making their own brushless motors, and winding them for a low RPM per volt.
Some of the Castle Creation ESC's can be used with brushed or brushless motors. Robbe do a nice motor in the 'Roxxy' range which is ideal for a larger model sub.
Andy
Page created in 0.366 seconds with 18 queries.
