Author Topic: Glue...  (Read 2395 times)
MartinH-K
Glue...
« on: May 14, 2009, 07:03:57 pm »
I have been using epoxy contact adhesive to plank my ship. All was going fine until I ran out of teak and had to switch to pine which I was going to stain. There are a few sections of the pine that seem to have expanded in the rain and lifted. Is there a better glue/adhesive that I can use?
Re: Glue...
« Reply #1 on: May 14, 2009, 07:51:11 pm »
It's not the glue that's the problem it's the timber.
Untreated teak is more or less waterproof whereas untreated pine isn't and will swell as it absorbs water.
You need to treat the pine as soon as you can after laying it.
MartinH-K
Re: Glue...
« Reply #2 on: May 14, 2009, 08:43:29 pm »
That makes sense. :-)) Am I right in assuming that the part of the pine that's glued can be considered 'treated' and I simply need to do all the rest?
Re: Glue...
« Reply #3 on: May 15, 2009, 08:06:35 am »
Right, you should varnish it as soon as your glue has hardened.
Page created in 0.766 seconds with 17 queries.
