Author Topic: Paint Finish  (Read 12802 times)
MTB
Re: Paint Finish
« Reply #25 on: October 27, 2006, 05:26:53 pm »
How about this Stavros ;)...........write it for the mags' ('cause you might get a couple of bob, always handy for new project materials - like paint?) then do a follow up on Mayhems pages of a re-write answering all the silly questions we ask after reading the first edition?
Not too good for you because of the extra writing but could finish up the REAL difinitive version of what we would all like to know!!! :o ;D ;D
Roy (London)
Re: Paint Finish
« Reply #26 on: October 27, 2006, 11:31:26 pm »
OK OK OK I will do it,flippin heck typer's cramp seems to spring to mind.I will start to write this article this weekend,I think I will have to think this one out,back it up with a few photo's etc.Hopefully you lads will see it in print next year sometime.If it will not be used I promise thta I will have it on the Mayhem site instead,dont forget lads I will expect you all to bow when you talk to me at shows.I will be the one looking haggard after all the writing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Paint Finish
« Reply #27 on: October 27, 2006, 11:39:28 pm »
Yes Stavros, lots of photos - mags won't be interested otherwise. A picture is worth a thousand words and given that many people don't read too well these days...
MTB
Re: Paint Finish
« Reply #28 on: October 29, 2006, 07:16:19 pm »
I'm going to my first ever show at the IMBS on Saturday 11th Nov'. :-[   I presume an encouraging pint might not go amiss should you deign to meet your adoring public there? :-* :-*
Roy (London)
martno1fan
Re: Paint Finish
« Reply #29 on: October 30, 2006, 08:32:34 am »
talking of paint finnish i just primed my higgins boat hull and the primer hasnt dried its still tacky after 48 hrs.i epoxy coated the hull then sanded and applied the primer,its just an outdoor grade primer for wood or metal .any ideas on why this has happened?ive never had this happen before but then ive never used this primer before either.im thinking i might need to remove it all and start again with a different paint,i got this one from wilkinsons and its there own brand so dont buy it!!.
Re: Paint Finish
« Reply #30 on: October 30, 2006, 10:19:13 am »
I would personally remove it.
Having been in the building industry for more years than I care to remember I would say this normally occurs if the paint is applied to a greasy or contaminated surface
{ presumably not so in your case} or you have a dodgy batch of paint. {more likely to happen with cheap own brands.}
I would play safe.
Richard :(
cbr900
  • Mayhem is the Only Forum!
    • Roys Hompage
Re: Paint Finish
« Reply #31 on: October 30, 2006, 10:23:09 am »
Have to agree with Richard remove completely and wash with prepsol then repaint with a proper primer...
Roy
Re: Paint Finish
« Reply #32 on: October 30, 2006, 10:33:26 am »
Thers a first Roy :o
martno1fan
Re: Paint Finish
« Reply #33 on: October 30, 2006, 10:35:26 am »
thanks guys whats the best way to remove it? white spirit,turps or something else?.im taking this paint back to the shop this week i beleive its dodgy like you say.it wasnt even cheap i wish id got a known name now.i paid 8 quid for it .
Re: Paint Finish
« Reply #34 on: October 30, 2006, 10:42:23 am »
I would start with the white spirit and see how you get on.
I dont think it will affect the epoxy though Roy will probably correct me if I am wrong, ;)
Richard 8)
martno1fan
Re: Paint Finish
« Reply #35 on: October 30, 2006, 10:52:51 am »
thanks mate ill have a go and see how i get on,any suggestions on a good primer i can use instead of this one?.
Re: Paint Finish
« Reply #36 on: October 30, 2006, 11:49:35 am »
I use Halfords Plasti-kote spray cans for primer and gloss. You presumably wont use the gloss.
You really want one that goes with the rest of your paint ie. enamel ,acrylic or whatever.
Richard 8)
martno1fan
Re: Paint Finish
« Reply #37 on: October 30, 2006, 12:13:42 pm »
Richard 8)
cheers i can get the same plasticoat from wilkinsons its probably cheaper i only hope they will give me a refund on this paint i allready have.i dont supose the cold temperature had anything to do with the paint not drying? or maybe not mixing the paint enough before using it?.i shook the tin up before i used it but i never stired it.
Re: Paint Finish
« Reply #38 on: October 30, 2006, 12:26:37 pm »
You were supposed to stir it!! :o :o
Richard
cbr900
    • Roys Hompage
Re: Paint Finish
« Reply #39 on: October 30, 2006, 12:29:42 pm »
Martin,
After what just happened I thought you would have learned a lesson, cheap paint cheap finish, and your going back for more, not a good idea,,,
Roy
martno1fan
Re: Paint Finish
« Reply #40 on: October 30, 2006, 02:54:16 pm »
Martin,
Roy
when i said cheap i meant cheaper than halfords but same paint lol,but its possible i didnt mix this paint well enough so i may try it again after stiring it .ill paint a small area and see how it goes if it doesnt dry i know its the paint and not me ;D.i have used the plasticoat paints on an epoxy hull before so i know they are ok.
Re: Paint Finish
« Reply #41 on: October 30, 2006, 04:40:07 pm »
Well here goes
1 You did not stirr the paint,megga mistake,all the driers sink to the bottom inc pigment,so it will NEVER dry
2 You have hit the nail on the head when you said cold temp,as temp and humidity affect paint drying time
3 Wash off the hull with either white spirit,cellulose thinner or acetone none of these will effect the epoxy coating
4 reprime wiht plasticoat paint
5 Rub primer with 600 grit wet dry
6 Spray with top coat
7 Pat yourself on the back and go for a weel deserved pint ;)
Re: Paint Finish
« Reply #42 on: October 30, 2006, 05:21:20 pm »
Hi Stavros
Really glad you confirmed my thoughts I was hoping you would show up.
Richard :)
sinjon
  • Sinjon
  • Model Bioat Mayhem Forum is the Best!
Stavros - Panel Wipe
« Reply #43 on: October 30, 2006, 05:33:34 pm »
I hope to be spraying my Missouri hull this week, so I have taken Stavros's advice and got all the bits he mentioned, including a 5 litre can of Panel Wipe, its brilliant at de-greasing kitchen cooker hoods, my wife is most impressed, I can see that I shall have no problem getting through 5 litres.
martno1fan
Re: Paint Finish
« Reply #44 on: October 30, 2006, 07:07:29 pm »
Well here goes
cheers mate ive just stired the bloody stuff and done a test patch to see if it dries before doing the whole boat!!,ill have that pint anyway .i cant believe i didnt stir the darn paint though i should know better.
Re: Paint Finish
« Reply #45 on: October 30, 2006, 11:10:00 pm »
Page created in 0.469 seconds with 18 queries.
