Author Topic: home-made sails  (Read 2890 times)
durhambargeman
home-made sails
« on: November 03, 2006, 02:21:16 pm »
 Hi, Does anyone have any advice to offer regarding suitable material for making sails?. The sails will be for a sailing barge, so I do not know if it will require different type of material; i.e thicker or stronger,than would a yacht?. Any guidance on this subject would be much appreciated.  Thankyou
Welsh_Druid
Re: home-made sails
« Reply #1 on: November 03, 2006, 04:05:59 pm »
You might find the notes at -      http://sailsetc.com/downloads/Sailmaking_Notes.pdf     - usefull
Don B
MikeK
  • Utter Bloody Chaos !!
Re: home-made sails
« Reply #2 on: November 03, 2006, 04:51:51 pm »
Making sails for the barge you are looking for scale effect, imitating canvas, whereas a yacht will either be ultra lightweight for racing or lighter anyway to look like sail cloth if scale. When I made mine(barge) I tried the recommended draughtsman's linen drawing paper with the starch boiled out but found it very hard to cut accurately. I would imagine that that stuff is hard to get now anyway with the advent of plastic materials. I ended up using some terylene cotton stuff from the dress making dept of Binns, similar to a handkerchief/shirt. Not literally of course  ::) I mean the cloth weight. Of course it will need dyeing and as I made a right pig's ear of that I will leave that to someone else to describe !
Best of luck with the project
MikeK
MCR
Re: home-made sails
« Reply #3 on: November 03, 2006, 05:34:21 pm »
These sails are made using cotton sheets I think it is called poplin.
boatmadman
Re: home-made sails
« Reply #4 on: November 03, 2006, 05:45:50 pm »
these were made from dress lining material
MikeK
Re: home-made sails
« Reply #5 on: November 03, 2006, 06:17:37 pm »
Looks like the schooner has a nice turn of speed Mr Madman  ;)
mikeK
andywright
Re: home-made sails
« Reply #6 on: November 03, 2006, 08:08:24 pm »
For the type of vessel you are making sails for you need egyptian cotton, available from this gentleman
 http://www.modellingtimbers.co.uk
Do not cut the main where it fits the mast in a straight line but a slight curve, this will give the sail a bit of shape. I make sails for one metres, southwinds, northwinds and all makes of model but do not do anything like you want. I have used draughting film for a gaff cutter I built these with properly shaped seams and it sailed well, though not quite looking the part. But the egyptian cotton is the way to go, about £3.50 per sq metre.
Cut the cloth so the selvedge runs up and down the leach of the sail, this will help to prevent the sail stretching out of shape when powered up., This goes for foresails as well.And you won't have to make a turnover seam here which will spoil the shape and the windflow. All other edges can be sewn over and some bolt rope sewn to the edge to hold shape.
Regards Andy Windpowersails)
Navigational Aids vessel Master. Old Conway 70-72
boatmadman
Re: home-made sails
« Reply #7 on: November 03, 2006, 10:36:46 pm »
yes it goes well mikek. I have put topsails on since that pic and it looks the business, even though I say so myself
ian
durhambargeman
Re: home-made sails
« Reply #8 on: November 05, 2006, 09:12:25 am »
 Hello All, Thanks once again for all the helpful advice that I have received in answer to my query, Thankyou all.Ray
