Author Topic: Test Tank.  (Read 5941 times)
Bradley
Test Tank.
« on: August 03, 2009, 10:20:26 pm »
Do any of you knowledgeable Mayhemmers know where I can get a test tank made up instead of having to use the bath.  I am after something about 1200mm long x 500mm wide x 300mm deep (approx) and I have had only one quote from an internet site of £95 + £20 shipping, constructed of 6mm polypropylene.  I didn't really want to pay this much so would be obliged for any suggestions (clean ones, please).   :-))
Many thanks.
Derek.     :police:
The long Build
Re: Test Tank.
« Reply #1 on: August 03, 2009, 10:23:26 pm »
Just a thought but you could by a cheap bath , 2nds or similar and use that , but not sure how you would store it..
Bradley
Re: Test Tank.
« Reply #2 on: August 03, 2009, 10:29:12 pm »
Many thanks for the suggestion about a bath but I am after something smaller that I can mount on a table top (or similar) when I want to ballast a boat as I find it difficult to see the waterline when it is down in the bath and the old bones find it difficult getting down and back up again.   :((
Derek.     :police:
tonyH
Re: Test Tank.
« Reply #3 on: August 03, 2009, 10:39:40 pm »
A pal of mine made one with ply sides and a loose liner from an old fish pond liner. There were only 2 points he took real care with being (1) the sides were well strapped together and (2) the table would stand the weight of the water, which I think would be in your case 180kg. He just syphoned the water out when he'd finished with it and folded the whole thing up.
Tony
Bradley
Re: Test Tank.
« Reply #4 on: August 03, 2009, 10:44:27 pm »
Many thanks, Tony.  I had thought along the lines of your suggestion but was just hoping that I could find something a bit more durable than ply so that I could leave it outside when not required.  I take your point about the weight of water and strength of table or stand - wouldn't want that lot collapsing  <:(.
Derek.     :police:
Re: Test Tank.
« Reply #5 on: August 03, 2009, 10:46:38 pm »
Have a look in 'Mothercare'. perhaps they have baby baths about the size you want.  :embarrassed:
tobyker
Re: Test Tank.
« Reply #6 on: August 03, 2009, 10:56:43 pm »
You could build a frame out of 2" x 6" timber, and line it with polytarp or black butyl pond liner. It wouldn't need a bottom as the table would form the bottom.
portside II
  • tugs at rest
Re: Test Tank.
« Reply #7 on: August 03, 2009, 11:00:53 pm »
I can see what your looking for Derek , probably along the lines of a fish tank , but then you have the probs that it is glass and if that breaks then its a wet sharp mess .
I built mine from plywood mounted on a sturdy stand only a foot off the floor , but the tank is 4 x 18 x 12 L,W,D, , You mention about seeing the waterline in a conventional tank/bath , if you build a ply tank with a cutout along one side you could silicone a piece of plexi glass on the inside this would then give you access to the waterline.
daz
PS when my tank is full to the top (and i have no idea how much it weighs) the sides only have a little bow , but to compensate that when not in use i have a hinged lid with a catch for support , also for H+S , the cat likes to jump up and sit on the lid to watch me pratting  :} .
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
Re: Test Tank.
« Reply #8 on: August 03, 2009, 11:02:13 pm »
Large cold water header tank- you can get them that big- then just cut the top 3-400mm off to get the depth you require.
Greg
Re: Test Tank.
« Reply #9 on: August 03, 2009, 11:04:13 pm »
I use the bath, but to check the waterline I use a mirror dipped into the water at an angle. Did it tonight in fact. You can see above and below water at the same time!
kenthompson
Re: Test Tank.
« Reply #10 on: August 03, 2009, 11:09:18 pm »
Hi Derek
 What about a child's paddle pool? cheep enough, and as big or small as you like. empty it then fold it away until next time...
 Ken.
Ghost in the shell
Re: Test Tank.
« Reply #11 on: August 04, 2009, 12:18:37 am »
I have heard of Coffins being used,
Go Nuclear!  you'll love it
john54
Re: Test Tank.
« Reply #12 on: August 04, 2009, 06:53:53 am »
In bath & a small spirit level  placed on the deck.
barriew
Re: Test Tank.
« Reply #13 on: August 04, 2009, 06:55:29 am »
Rather than ply, I used white melamine covered board. Joints sealed with silicone sealant, and a water butt drain in the bottom to make it easier to empty. Not sure about storing outside though - mine is in the garage.
Barrie
ray123
  • shuswap tugboat
Re: Test Tank.
« Reply #14 on: August 04, 2009, 07:28:22 am »
  the  thing you  want is a plasterer's bath  aprox  4ft x 2ft  & at £29   its worth every penny O0  & its plastic so wont rot!!  you get them at most 'builders merchants   regards ray
sinjon
  • Sinjon
  • Model Bioat Mayhem Forum is the Best!
Re: Test Tank.
« Reply #15 on: August 04, 2009, 08:21:52 am »
I made mine from white melamine boards from B&Q, 8''wide for the bottom, 6''wide for the sides & ends, so the tank is 8' x 6'' x 6' all just screwed together, a large piece of clear polythene as the liner. Also a vertical slot at 6'.0'' so that I can drop a piece in to give me a smaller tank. So in practice I have the choice of three tanks in one - one at 8 feet, another at 6 feet & a little one at 2 feet.
When not in use it stands in the corner of the garage - floor space 6'' x 6''
Bradley
Re: Test Tank.
« Reply #16 on: August 04, 2009, 10:29:31 am »
Many thanks to everyone for all their helpful suggestions.  It looks as though a trip to a builders merchants might be on the agenda.   :-))
Derek.    :police:
sinjon
  • Sinjon
Re: Test Tank.
« Reply #17 on: August 04, 2009, 01:44:36 pm »
I made mine from white melamine boards from B&Q, 8''wide for the bottom, 6''wide for the sides & ends, so the tank is 8' x 8'' x 6' all just screwed together, a large piece of clear polythene as the liner. Also a vertical slot at 6'.0'' so that I can drop a piece in to give me a smaller tank. So in practice I have the choice of three tanks in one - one at 8 feet, another at 6 feet & a little one at 2 feet.
Bryan Young
Re: Test Tank.
« Reply #18 on: August 04, 2009, 03:13:29 pm »
I managed to get hold of a couple of builders planks (as used on scaffolding).  Cut them up to a size (length and width) to suit a model at least 8' long. I then bought a sheet of heavy polythene, but it wasn't all that successful...so I bought a huge blue (plastic) tarpaulin from Wickes. I made the cover for my trailer with it as well as the "liner" for the tank and still have enough left over to do both jobs again!.About £12 I think. Then I "collected" a few lengths of half inch steel rod from a skip or something. Simple after that. Drive a few lengths of the rod into the lawn to keep the plank lengths roughly vertical. Drape a suitable size bit of the tarp into the "tank" and fill with water from a hose. A few 1" nails around the edges holds the tarp in position. To empty it I just remove one of the short end bits and water the garden. And planks are easy enough to stow somewhere or other until needed again. Cheap, effective and dismantleable.  BY.
Notes from a simple seaman
maninthestreet
Re: Test Tank.
« Reply #19 on: August 04, 2009, 03:41:15 pm »
How many 4ft tall babies do you know??  ok2 ok2
Re: Test Tank.
« Reply #20 on: August 04, 2009, 04:24:26 pm »
My, how things have changed since I was young. {-)
BarryM
Re: Test Tank.
« Reply #21 on: August 04, 2009, 04:50:27 pm »
The one thing that nobody has commented on is how anybody could get a 4' long test tank, slopping with water, on the table, without The Management intervening with a blunt object?   :o
Barry M
Bradley
Re: Test Tank.
« Reply #22 on: August 04, 2009, 05:30:26 pm »
A tour of the local builders merchants this afternoon failed to turn up a single plasterer's bath so I have ordered one on line from www.bexpress.co.uk at a reasonable price.  Until Ray came up with his suggestion I was under the impression that plasterers just used an old tin bath - never seen one with a posh purpose-made plastic bath so, thanks Ray, it looks as though this is just what I wanted.  :-))
Derek.    :police:
maninthestreet
Re: Test Tank.
« Reply #23 on: August 04, 2009, 08:15:49 pm »
ray123
  • shuswap tugboat
Re: Test Tank.
« Reply #24 on: August 04, 2009, 10:03:36 pm »
hi  derek  they are very strong these ''baths''   your not tank testing your new one allready ;) :D
regards ray
