Author Topic: fixing of gears  (Read 2052 times)
mikgo
fixing of gears
« on: September 12, 2009, 07:01:56 pm »
Has anybody got any idea's how to fasten plastic gears to a smooth motor shaft as mine come off when the shaft gets hot.
thanks
if we didnt have boats, we'ved  have webbed feet
ian kennedy
Re: fixing of gears
« Reply #1 on: September 12, 2009, 09:10:57 pm »
Hi mikgo,
You could try drilling through the meat of the gear shaft bush then slip it into position on your drive shaft, next mark the hole position and drill through the metal shaft.
You can then slide a brass pin through bothe holes and either pein the ends to stop it working loose or just bend each end over.
Hope this helps
johno 52-11
    • lifeboat Models
Re: fixing of gears
« Reply #2 on: September 12, 2009, 10:30:54 pm »
Use a rollpin find one that's a tight fit on the motor shaft then drill your gear out so the rollpin is a tight fit then push it onto the motor shaft this would expand the rollpin in the gear and make it a tight fit on the shaft. If you look at me build of a model outboard you will see I used one to connect the shaft to the motor.
http://www.lifeboatmodels.co.uk/atlanticmotors2.htm near the bottom of the page it shows the motor and the shaft.
mikgo
Re: fixing of gears
« Reply #3 on: September 13, 2009, 05:33:15 pm »
many thanks for your Idea's I will give a go.
Page created in 0.597 seconds with 17 queries.
