Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14]   Go Down
Author Topic: R.N.L.I Severn scratch build  (Read 120223 times)
Peter Fitness
Re: R.N.L.I Severn scratch build
« Reply #325 on: August 08, 2011, 07:44:53 am »
Blimey, Ken, you could put a small dog in that hull O0 {-)
Peter.
« Reply #326 on: August 08, 2011, 10:15:16 am »
He was behind me ----  you can see his shadow on the hull -----   {-) {-) {-)
I shall be smoothing the frames edges today. Don't want people picking holes with my carpentry    :}
Ken
ps ---  Peter, I like your new picture. very sheikh.  Now get your scruffy's on and start on that next boat.
Peter Fitness
« Reply #327 on: August 09, 2011, 12:06:02 am »
It was taken at our daughter's wedding, hence the glad rags :-) Funny thing is it doesn't show up on my computer, the old one is still there {:-{
Peter.
« Reply #328 on: August 09, 2011, 11:07:27 am »
It may still be locked in your computer cache. try clearing it by pressing 'control'  &  'F5'
(I read that somewhere   %) )
Ken
Peter Fitness
« Reply #329 on: August 10, 2011, 12:18:14 am »
Thanks, Ken. I tried that but no change, still the same old photo...which is probably not surprising, as I'm still the same old bloke {-) {-)
Peter.
« Reply #330 on: August 10, 2011, 05:35:09 am »
No Peter - for approx 24 hours..... :embarrassed: even in your older posts you updated to the new grey suit & tie with the distinguished look of a member of Parliament   %% {-) ...but today you revert to the jungle greens again............Derek
« Reply #331 on: August 10, 2011, 07:48:28 am »
I pressed the required keys and Hey Presto your avatar changed to Your smart attire.
Still the same today
« Reply #332 on: August 10, 2011, 09:52:07 am »
No No No ....clearly Mayhem members  >:-o :D ....this is how our OZ moderator Peter.......appears this evening.........Derek  :-))
opps ...sorry about the image   resolution   >>:-(  :embarrassed:
« Reply #333 on: August 10, 2011, 07:18:45 pm »
Peter's photo now fixed!   :-))
« Reply #334 on: August 10, 2011, 07:24:51 pm »
Peter's photo now fixed!   Thumbs up
If that is fixed, how bad was it before ?
Peter Fitness
« Reply #335 on: August 11, 2011, 01:59:40 am »
Thanks, Richard, you're a real friend {-)
BTW, the avatar has now changed on my PC, thanks to computer whiz, Martin :-))
Peter.
brianB6
« Reply #336 on: August 11, 2011, 07:51:02 am »
Would you buy a used car from him?   %%
jimmy2310
« Reply #337 on: August 11, 2011, 08:03:54 am »
Last time I saw somebody dressed like that they were called 'the accused' {-) {-)
Jimmy
HS93 (RIP)
  • I cannot spell , tough
« Reply #338 on: August 11, 2011, 08:05:59 am »
remove
HS93 (RIP)
« Reply #339 on: August 11, 2011, 08:07:36 am »
Jimmy
     Was his name Barton .?   O0
Peter  <*<
jimmy2310
« Reply #340 on: August 11, 2011, 08:30:14 am »
Dick or Joey?  :}
Jimmy
Antipodes
  • Location: The other side of the world, near the Antipodes. Dunedin, New Zealand
« Reply #341 on: August 10, 2012, 10:32:19 am »
Hi Perkasaman
Yes indeed it's a great machine. Ensure you get the widest blade you can afford to prevent 'flexing'.
I have managed to cut 6 foot length of  6" by 1"  timber to a width of 1mm planks, which proved to be too thin anyway. I settled on 2 to 3 mm in the end. I have two blades of different teeth per inch and found the 10 tooth one best for accurate work. I use the 6 tooth per inch for ripping larger wood, and so far have managed to slice a piece of 3X3 inch carefully to a width of 2mm. (just experimenting)
It does need special guides clamped in place as long material like this will 'wander' if you sneeze.  :D    I had rests fixed each side of the blade to support the wood and keep it true.
One thing to note is keep away from Knots in the wood. Planks cut from these tend to snap when handled afterwards.  :embarrassed:
As to plywood, it's like cutting cheese. You can actually cut a 2 inch circle, it's so sharp and dusty, so goggles are a must.
Ken
Ken,
How much timber do you lose in wastage from the cutting in say the 3x3?
B
"Water is best tasted chilled and flavoured with hops"
KiwiCachers
« Reply #342 on: August 10, 2012, 11:22:50 am »
Me, waste timber !!!!!   {-) {-) {-)
Using my lovely bandsaw for large production runs does create a LOT of saw dust so be careful out there.  I assume you are interested in how many pieces of a certain cut one can get from a plank of wood.
This is rather like  'how long is a piece of string'. When cutting 3mm wide it would be safe to say you will get proportionally more wastage. You have to account for not only the width of the blade but add in the teeth and friction removing the material as well.  Also, do NOT use a sideways force as this will wear one side of the blade away.  Been there. Done that.  Just let the teeth do their job and gently push the timber through the guides.
Hope this helps
ken
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14]   Go Up
Page created in 0.196 seconds with 17 queries.
