Author Topic: Earthrace - Ady Gil  (Read 18909 times)
Re: Earthrace - Ady Gil
« Reply #25 on: February 03, 2010, 10:49:16 am »
as long as u can get two 540's side by side in the hull that i think will be the answer i will measure it up as she is quite narrow lol
You could always try staggering the motors.
jaywayne75
« Reply #26 on: February 03, 2010, 06:19:39 pm »
well she should be here in a day or two so measuring can begin
the Cleaver props in the pic are perfect for earthrace i will be getting some of those also looking to put the dual rudders in the sponsons as per the real thing staggering the motors i think wont be a problem but only if i really have to
the empty space will mostly be filled with foam should a boat decide to try and slash me bow off
still not sure brushed or not?
brushed gives great slow running but brushless gives insane speed maybe 1500kv is ok
nick_75au
« Reply #27 on: February 04, 2010, 06:37:36 am »
If you want slow, a 700 Kv,  ;)  5000 RPM at 7.2 volts, on a 40 MM prop will give you all of 3.5 KpH, well maybe a little more with the slippery Earthrace hull :-))
I can watch the bell spinning and almost count the revs by eye.
first motor in this thread.
http://www.modelboatmayhem.co.uk/forum/index.php?topic=20084.0
Nick
jaywayne75
« Reply #28 on: February 06, 2010, 04:08:22 pm »
i spose its because i am used to brushed 540 size motors but any motors that will suit the 920mm hull at 6.5kg would be fine so keep ya ideas coming
cos918
« Reply #29 on: February 08, 2010, 10:09:53 pm »
Ok it turned up today the Earthrace and i am pleased oerall but its a big job to convert to twin motors but it beggs it to be honest oh i m Jaywayne75 but i have used my mates login as i am on his computer to save confusion!!
w3bby
« Reply #30 on: February 09, 2010, 08:31:31 am »
jaywayne75
« Reply #31 on: February 16, 2010, 09:54:57 pm »
anyone know of where i can get decals made for this model (Ady Gil)  ?
jaywayne75
Ady Gil decals
« Reply #32 on: February 16, 2010, 09:59:08 pm »
Does anybody know of who or where makes decals? (waterslide) as i need to get some made for the conversion of earthrace to ady gil
thanks
jason
andyn
Re: Ady Gil decals
« Reply #33 on: February 16, 2010, 10:43:46 pm »
Waterslide decals will waterslide on.... Then waterslide back off again...
Try RCGraphics.
justboatonic
Re: Ady Gil decals
« Reply #34 on: February 17, 2010, 08:30:17 pm »
You can make your own easily if you have a colour or laser printer by buying waterslide transfer paper here http://www.craftycomputerpaper.co.uk/productlist.asp?catid=14&RootCatID=14
If using colour ink, you'd need to seal the transfer on the boat to stop it coming off.
AFAIA there is different paper for ink jet and laser pinters.
HTH
jaywayne75
Re: Ady Gil decals
« Reply #35 on: February 17, 2010, 09:36:15 pm »
Ha ha i did intend to satin laquer them on lol
tho i will give the printing option a go
thanks
jase
funtimefrankie
Re: Ady Gil decals
« Reply #36 on: February 18, 2010, 10:41:40 am »
Just been doing some, black printing on clear backing, works well.
Not tried the white backing paper yet
Print it out, spray the paper, let it dry and then dunk and slide it on, not sprayed it again yet.
funtimefrankie
Re: Ady Gil decals
« Reply #37 on: February 18, 2010, 01:40:48 pm »
Just been trying to put some colour (red and Yellow) printed decals onto a dark blue background and the decal is all but  invisible <:(
Any any tips on decals on to a dark colour?
The ones I've done before have been black onto a white background and been fine.
mike_victoriabc
Re: Ady Gil decals
« Reply #38 on: February 18, 2010, 02:03:49 pm »
Try your local sign shop - they usually have small scrap ends that they can create your text/design onto - quite often for a donation to their tea fund. I've had a few here done using a vinyl type material.
cos918
Re: Ady Gil decals
« Reply #39 on: February 18, 2010, 02:34:53 pm »
jason
go to the sign shop around the corner from you.. Get some  of that self adhesive venial . Mark at the club has a rob cutter that will cut them out perfect.
All you need to do is to get a drawing of the transfers you want. I call you later
jaywayne75
« Reply #40 on: April 06, 2010, 07:17:45 pm »
Ok an update this is the Ady Gil prior to the driveline mods and decals but after surgery to the horns or fins on top she looks far better for it tho!!
jaywayne75
Update on the Earthrace conversion
« Reply #41 on: April 10, 2010, 11:51:38 pm »
Well its going well all electrics are out the intake/exhaust horns heavily modified (flatter angle and more swept) and now wearing the satin black
more detail mods to follow radar and IRC platform nav lights and hand rails
it will be a twin Graupner direct drive setup with two 35/40mm 4 blade props and will try tank steering if this is no good then twin rudders in the sponsons as the real thing had these so plenty to do but all quite do-able
jaywayne75
earthrace update
« Reply #42 on: April 10, 2010, 11:55:34 pm »
All going well no electrics but graupner direct drives will be going in with 2 40mm props loads to do detail mods tho the horns are heavily modified as now they sit flatter and more swept an issue with this model but looking ok now!
Minime
Re: earthrace update
« Reply #43 on: April 11, 2010, 06:35:47 am »
nice project looks great, sad though that the sea sheperds had to bring that nice boat to antarctic and get it destroyed.
jaywayne75
The final result the Ady Gil
« Reply #44 on: July 27, 2010, 07:45:31 pm »
Here it is now with twin graupner 602 multispeeds with 600 motors tank steers really well and may add sponson rudders for trimming
Peter Fitness
Re: The final result the Ady Gil
« Reply #45 on: July 28, 2010, 07:18:21 am »
Keep a sharp lookout for Japanese whaling ships  O0
Peter.
jaywayne75
« Reply #46 on: July 29, 2010, 11:58:16 pm »
Ha Ha i have a prop fouling line so they best watch out for me as revenge is sweet  :-))
« Reply #47 on: July 30, 2010, 12:50:05 am »
All topics merged... hope it still makes sense!
 Good looking boat, can't wait the video of it running!!  :-))
Yogibear
« Reply #48 on: September 06, 2011, 05:40:13 am »
Ive got the bigger brother of this and am about to start carrying out some mods to improve it.
Ive allready had to repair the bow after a little accident and that has motivated me to change a few things, the exhaust presently comes out on the left hand side but Im pretty sure that was letting water in through the turns so im blanking the exit off and going to reroute the exhuast out of the left side breather fin. Im also going to do similar and run a breather tube from the right side fin down to the carb. After that the idea is to fibreglass where the sponsons meet the main hull to add strength, at the moment their are 8 bolts securing each sponson to the main hull but id rather increse the strength in that area considerably. Then trim tabs going to be added as mine seams to have a tendency to lean to the right and on righ turns the right sponson burries into the water. With a little head scratching I think I can get the trim tabs running of a third channel so that its trimable whilst running. Oh yeah and going to add some boyancy as well , theirs quite a bit of space in front and above the fuel tank so hopefully get some packaging air packets on those spaces. Think thats my plans in a nut shell. Would like mine to have the ability to go through waves as the real one did which is my thinking behind most of my planned work. Then a quick respray in some thing appropriate.
