Author Topic: Using plastic kit propellors...  (Read 2566 times)
Patrick Henry
« on: February 04, 2010, 05:02:18 pm »
The attached pic is of the 'as supplied' prop for the Trumpeter USS Seawolf...notice the complete lack of bite to the blades, the prop is as flat as the proverbial...well, it's flat.
Any ideas as to how it could modified for use...obviously this would involve twisting the blades without them snapping off at the root, but how could this be done? The alternative is to have one custom made at a frightening price, or use an 'ordinary' prop, but I would like to use this one if at all possible.
Roger in France
Re: Using plastic kit propellors...
« Reply #1 on: February 04, 2010, 05:26:27 pm »
How about a judicious application of a warm hair dryer at the root of the blades and then a small twist to each blade?
I guess that with a large number of blades you do not need much off set.
Have a look at a high quality prop to give you some idea of how much twist to introduce.
Roger in France
Patrick Henry
« Reply #2 on: February 04, 2010, 05:57:03 pm »
That's an idea Roger...just hope it doesn't melt! But, it's worth a try for sure...
« Reply #3 on: February 04, 2010, 06:35:40 pm »
would it not be wiser to test it before setting about it with a hairdrier?
Patrick Henry
« Reply #4 on: February 04, 2010, 06:37:39 pm »
Fear not, Essex old chap...I'll give the hair dryer a go on some scrap pieces of sprue first!!
Roger in France
« Reply #5 on: February 04, 2010, 06:39:05 pm »
Take it slowly, a little heat and see if they bend and stay bent. If not a little hotter.
Once you have bent some and want to proceed to the next one, wrap a damp cloth over the ones already done.
If you get in a mess you may need to buy the proper job but at least you will have tried!
Roger in France
Patrick Henry
« Reply #6 on: February 04, 2010, 07:16:31 pm »
Well, it worked to a point Roger, but the plastic blades are so thin, they just bend all over the place once on a shaft and running in water.
It was worth a try though...I suppose now it's onto the Prop Shop website and prepare my plastic flexible friend for a nasty shock... {:-{
craftysod
« Reply #7 on: February 04, 2010, 07:22:32 pm »
Or try George Sitek ,Rich
Mark
Patrick Henry
« Reply #8 on: February 04, 2010, 07:26:31 pm »
Yep, that's another on the list...cheers Mark.
