Author Topic: Lights  (Read 6066 times)
wallace
Lights
« on: February 11, 2010, 06:57:49 pm »
Im going to put LED's on my upper deck on my Sir Lancelot so I'm looking for a site where I can buy  the downlighters to put the LEDs into to shine the light onto the deck  around the the ship. Any help please.
               wallace    :-)) :-)) :-)) :-))
The Antipodean
Re: Lights
« Reply #1 on: February 11, 2010, 07:08:52 pm »
Not sure what you have available over there, but these are available in America.
http://www.harbormodels.com/Harbormain/Templates/m13-lighting.htm
Re: Lights
« Reply #2 on: February 11, 2010, 08:17:20 pm »
Try here
www.component-shop.co.uk
Lots of choice   :-))
Umi_Ryuzuki
Re: Lights
« Reply #3 on: February 11, 2010, 10:39:34 pm »
Are you looking for something like these?
craftysod
Re: Lights
« Reply #4 on: February 11, 2010, 11:10:56 pm »
Maplins
portside II
  • tugs at rest
Re: Lights
« Reply #5 on: February 12, 2010, 12:41:50 am »
Something like this , lamps drilled and a led fitted in .
daz
ministeve
  • washing the decks!!!
Re: Lights
« Reply #6 on: February 12, 2010, 06:08:25 am »
will try and bring something with me later wal
Re: Lights
« Reply #7 on: February 12, 2010, 06:42:04 am »
I don't know if this helps. It is a tip I picked up on a website. It may have been this one, but not sure.
Rex Hunt
Re: Lights
« Reply #8 on: February 12, 2010, 08:44:50 am »
I like the last suggestion, but how do you get the paint to 'take'?
Have been trying with enamels......are acrylics the answer?
Rex
Davenotdone
Re: Lights
« Reply #9 on: February 12, 2010, 09:23:15 am »
Try the model railway section of fleabay and type in 'lights'. Red Bank Models ( Blackpool ) have a web site and they do them.
                          Regards, Dave.
portside II
  • tugs at rest
Re: Lights
« Reply #10 on: February 12, 2010, 09:26:45 am »
I like that idea Tiger , i too would be interested in what the best paint to use is  :-)) .
daz
Re: Lights
« Reply #11 on: February 12, 2010, 09:39:14 am »
Brilliant idea TT  :-)) ..........[no pun intended]   ;D .....Derek
chingdevil
Re: Lights
« Reply #12 on: February 12, 2010, 09:51:13 am »
If you use surface mount led's they work well
Brian
Re: Lights
« Reply #13 on: February 12, 2010, 11:01:29 am »
Wallace's original query was about the downlighter, not the LED.
Best bet might be to do as the original did and form the cone from a circle, but use plasticard instead of sheet steel.  Used in conjunction with Tiger's idea of painting and filing the LED should produce a good result.  To help paint take, a bit of surface keying with a mild abrasive should help.  Since the LED should not undergo continued handling, there shouldn't be a problem.
Bulkhead lights are something else again.
Re: Lights
« Reply #14 on: February 12, 2010, 11:15:59 am »
Something like this, although the fitting does need another coat of paint  :-))
FullLeatherJacket
Re: Lights
« Reply #15 on: February 12, 2010, 12:31:00 pm »
Wallace
If you can post a sketch of the downlighter body you need (dimensioned) then I can check it against my CAD plans for the various Model Slipway kits. It might be possible to use or adapt one of Lawrie's white metal castings. I'm sure that Slipway would be only too pleased to supply you with a few.
FLJ
wallace
Re: Lights
« Reply #16 on: February 12, 2010, 04:00:48 pm »
Thanks Malcolm you got it right       Im after the fitting to cover the LED  as a downlighter.
And Steamboat Phil  thanks for the photo thats the sort of light im after  but in a half moon.
well many thanks to one and all you have all been wonderful with your help
I will take a photo of my superstruc  and try to draw what I want and where
            :-))  wallace   :-))
portside II
  • tugs at rest
Re: Lights
« Reply #17 on: February 12, 2010, 11:01:24 pm »
the spot light  i fitted with a led is from the model slipway kit Dutch Courage , i just drilled them out to fitthe led .
daz
wallace
Re: Lights
« Reply #18 on: February 13, 2010, 10:57:17 am »
Many thanks Daz
Page created in 0.045 seconds with 18 queries.
