September 12, 2025, 11:58:38 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Tugs and Towing
john king tug Bristol
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: john king tug Bristol (Read 7587 times)
LarryW
Guest
on:
May 06, 2010, 04:21:33 pm »
hi there just got plan of john king scale half in to foot length 29in 9in beam 5in draft what motor and prop should i use i am new to boat modeling so keep it simple please thanks Larry.
Full Mayhemer
Offline
Newport. S Wales
Re: john king tug Bristol
Reply #1 on:
May 06, 2010, 07:31:20 pm »
Does the plan have a view of the the propeller ? The scale looks to be 1:24, maybe you could measure it and it might give you a guide. I would estimate that is around 35-45mm.
Hope this helps
Ken
Despite the high cost of living .......... It remains popular
billa65t
Guest
Reply #2 on:
May 06, 2010, 11:11:19 pm »
Hi Larry,
it depends really what you intend to do with the model,wheather you intend just to use it for cruising around your local pond or wheather you intend to use it for tug towing? and also what size and type of battery you are going to use.If you just want to cruise it around you could just put a small MFA 400 motor in it which will run on anything from 4.8-15 volt but with a smallish prop about 30-35 mm,But if you want to use it for towing then you will need a high torque or 550 geared motor with something like a 2-1 redunction gearbox on it and a large 3 or 4 flat bladed prop around 45-55 mm this will be governed by the amount of space you have and these are usually run on 12 volt
Regards Bill
LarryW
Guest
Reply #3 on:
July 05, 2010, 10:08:54 am »
hi on the water for test .thanks to all for info on motors and props ,as a new boy to boat models i find mayhem a better source than boat mags,i am off to wemouth sunday so i may pick the up moter and prop there cheers larry.
Channel
Full Mayhemer
Offline
Reply #4 on:
July 17, 2010, 11:10:55 am »
Nice model, I am involved with restoring her 'baby sister' the Volunteer.
Chris
Follow my blog -
www.channelimages.com
LarryW
Guest
Reply #5 on:
July 17, 2010, 05:32:01 pm »
thanks chris where is the volunteer?cheers larry.
LarryW
Guest
Reply #6 on:
August 13, 2010, 01:58:26 pm »
launched the john king this week happy as Larry
LarryW
Guest
Reply #7 on:
August 13, 2010, 02:23:46 pm »
AND IT FITS THE BOOT.....................
triumphjon
Guest
Reply #8 on:
August 13, 2010, 03:14:37 pm »
is that st georges lake or eastville looking rathere like pea soup ! model looks very good .
LarryW
Guest
Reply #9 on:
August 13, 2010, 04:03:10 pm »
NO IT,S VICTORIA PARK BATH ITS THE SMALL POND THAT ONLY GETS A WATER CHANGE WHEN IT RAINS OR THE LARGE LAKE OVER FLOWS
CHEERS LARRY.
triumphjon
Guest
Reply #10 on:
August 13, 2010, 07:57:14 pm »
you live nearby viki park then ? sorry i asumed that as your listed as being in bristol you were sailing on one of the two common park lakes there ?
Channel
Full Mayhemer
Offline
Reply #11 on:
August 14, 2010, 08:48:05 pm »
Quote from: LarryW on July 17, 2010, 05:32:01 pm
Whitehaven just now - see
http://www.modelboatmayhem.co.uk/forum/index.php?topic=24614.msg250141#new
Follow my blog -
Full Mayhemer
Offline
Newport. S Wales
Reply #12 on:
August 15, 2010, 12:06:22 pm »
Smashing job Larry. What motor and props did you finally select ?
Ken
LarryW
Guest
Reply #13 on:
August 15, 2010, 12:22:16 pm »
hi ken info MFA 919 re 540/1motor running on 12 volt ... turning a 70mm brass 3 blade Mk troniks 20 amp SEC ...Larry
Full Mayhemer
Offline
Newport. S Wales
Reply #14 on:
August 15, 2010, 12:53:51 pm »
Excellent. A nice 70 mm prop. Should be up to tug towing exercises.
Ken
japottinger
Guest
Reply #15 on:
September 23, 2010, 04:47:18 pm »
Nice to see the model afloat, another to add to my "family" of model plans!
Excellent effort.
Cheers,
Jim
LarryW
Guest
Reply #16 on:
September 23, 2010, 05:09:39 pm »
thanks jim sails well will turn its own lenth ., also steers well , will get on put on scale detail ..cheers larry
Channel
Full Mayhemer
Offline
Reply #17 on:
September 11, 2011, 10:09:15 pm »
In 'M Shed' today.
Follow my blog -
Print
Pages: [
1
Go Up
« previous
next »
Tugs and Towing
