Pages: 1 [2] 3 4 5   Go Down
Author Topic: HMS Brave Borderer 1/24 scale  (Read 48301 times)
HS93 (RIP)
  • I cannot spell , tough
Re: HMS Brave Borderer 1/24 scale
« Reply #25 on: December 05, 2010, 08:46:45 pm »
May I make a comment about the props being un supported near the end I think you will need an extra bracket just behind the prop or it will shake itself to death at the recs of a brushless motor .
Peter
Number 6
« Reply #26 on: December 06, 2010, 07:59:21 am »
Very nice Russ, you must have the heating on in the workshop now if you're spraying?  %) Use the fire station bay if you want, one of the perks of the job, nice big heated bay with good lighting! I just make a donation to the Benevolent Fund each year and make sure not to get paint on the big red truck! See you soon, Dave.  :-))
Gra
« Reply #27 on: December 06, 2010, 08:21:39 am »
I agree with HS93,those props will need support at the prop.
Best to fix now to aviod disappointment.
Gra
6705russell
« Reply #28 on: December 06, 2010, 09:12:20 am »
Point taken on board reference the prop supports but i have not had a problem with the 1/12 Tamar and that runs on 800kv brushless with the same prop set up?  I will keep on eye on them when water testing next year, shouldnt see a problem with them.
Russ
triumphjon
« Reply #29 on: December 06, 2010, 09:06:09 pm »
could you not make up some longer prop bearing brackets in brass ? i make all of my own ones using the k&s metals range !
Perkasaman2
« Reply #30 on: December 07, 2010, 11:42:56 pm »
It's a shame the p frames were short ,however, your exposed shafts should certainly create less drag than full length prop tubes. Nothing is perfect but your arrangement is much closer to the Vosper original than most.  :-)
6705russell
« Reply #31 on: December 08, 2010, 06:59:42 am »
Thanks Perkasaman, i think "drag" issues went out the window anyway when i fitted the motors!   ok2
John W E
  • I see no ships !!
« Reply #32 on: December 08, 2010, 09:12:28 am »
Knowledge begins with respect
Perkasaman2
« Reply #33 on: December 08, 2010, 12:46:17 pm »
Great pix Intel..
You're right Russ, but every little helps......... the +30% over brushed equivalents is definately .........no drag.
What size/make props have you chosen? They look like quality items.
6705russell
« Reply #34 on: December 08, 2010, 01:45:55 pm »
The outer props are Sitek,s, if you look closely the middle prop is a different make/design, i have had the two outer ones for a while, i will need to source a third eventually to match them up....
Perkasaman2
« Reply #35 on: December 08, 2010, 05:39:51 pm »
Nice items, they look 40mm+ in size. I cannot recall the diameter of the original Vosper (turbine power) props being listed in any of the usual reference sources I checked recently, although I was researching 'Perkasa' rather than the 'Braves' specs on the usual web sites.This size has remained a mystery. :-)
triumphjon
« Reply #36 on: December 08, 2010, 10:48:09 pm »
ive been onto bmpbt site this evening and although information is shown on thrust &  shaft angles i didnt notice any diameters listed
6705russell
« Reply #37 on: January 03, 2011, 08:46:59 pm »
After been struck down with the "man-flu" i have made a little more progress on the Brave, finished spraying the hull and superstructure, deck sprayed, made the base for the flying bridge, long-range fuel tanks fitted and now starting to fix various deck fittings including the two torpedo racks...
Russ
Number 6
« Reply #38 on: January 03, 2011, 08:53:02 pm »
She's looking good Russ. I know you've had man-flu but managed force that mixed grill down you at the weekend!  O0 See you soon, Dave & Audie... :-))
6705russell
« Reply #39 on: January 03, 2011, 08:56:48 pm »
Growing lad Dave... {-)
nhp651
« Reply #40 on: January 03, 2011, 09:24:05 pm »
you'll burst out ya shirt and not fit in that new Z3 of yours if ya grow anymore........... {-) {-) {-) {-) {-) {-).
nice work on the BB............
6705russell
« Reply #41 on: January 03, 2011, 09:31:26 pm »
Thanks matey, I can fit a few more steaks in yet..  :-))
Hopefully tomorrow I will be installing the new sound unit.....
Russ
nhp651
« Reply #42 on: January 03, 2011, 09:42:59 pm »
Do you use the same one for all your boats, russ.
6705russell
« Reply #43 on: January 03, 2011, 09:48:23 pm »
No, all separate, in two of the lifeboats I am running the Rc Model Workshops, in the Trent is  one of Actions P100 and I have another P100 with gas turbine sound for the Brave.
6705russell
« Reply #44 on: January 07, 2011, 08:08:27 pm »
Over the past couple of days i have made up both Bofors 40mm guns, all deck vents fitted, hatches and torpedos...
Russ
Martin13
« Reply #45 on: January 07, 2011, 10:48:27 pm »
Well done - might have to get back to working on my BB - only wish I could build that fast..
Martin doon under
6705russell
« Reply #46 on: January 09, 2011, 05:09:46 pm »
Today,s mission was to fit the internals and make the rear exhaust shelf, unfortunatley it looks a little bigger than it should do so i will be making a new one, speed controllers fitted along with a P100, amplifier and speaker in a sound box. I also made the second mast array and fitted the nav lights....
Russ
Number 6
« Reply #47 on: January 09, 2011, 08:25:02 pm »
She's looking very impressive Russ. Now you've mastered the mast making are you going tackle the Tamar Lifeboats? See you soon, Dave.  :-))
6705russell
« Reply #48 on: January 09, 2011, 08:29:53 pm »
Hi Dave
Yeh I will be cracking on with the Tamar as soon as I have finished the Brave, got hooked on this build, really enjoying it.....
Number 6
« Reply #49 on: January 09, 2011, 08:36:36 pm »
Noticed you'd got into the Brave, I'll have to do some more soon when have finished the bathroom. Wish the lake would hurry up and thaw out, quite a few of us got new boats to test. We'll have to go over to Chasewater, seen the post about their lake being clear, wonder if they'd mind a few gatecrashers? Dave.  O0 O0
Pages: 1 [2] 3 4 5   Go Up
