Author Topic: Chain saw oil.  (Read 3992 times)
Colin H
Chain saw oil.
« on: April 25, 2006, 04:41:43 pm »
Has anyone used the above to lube prop shafts.
I had to use my chain saw today for the first time in many months, (well that 5mm planking gets boring with a razor saw). When I olied the chain I noticed the oil seemed to be just a little thicker than 3 in 1 and thought it might serve the purpose.
Yours Colin H.
do every thing today tomorrow may not arrive.
Youngat65
Re: Chain saw oil.
« Reply #1 on: May 25, 2006, 06:34:09 pm »
I use motor-cycle chain oil in my prop tubes, don't seem to have any problerms
Re: Chain saw oil.
« Reply #2 on: May 25, 2006, 11:53:06 pm »
I use Fishing reel grease.
Its thin and waterproof, and of course cheap!!
White Ensign
  • Limits must be limited!
Re: Chain saw oil.
« Reply #3 on: May 31, 2006, 08:20:41 am »
... my solution is a silicone-oil. Waterresistant and cheap as well. I found a thick oil better than grease, as oil soaks in any seam and find his way to the bearing, as grease just "sits" before the bearing as a clot.
J?rg
When God created planet earth, he made it with 75% of water. Bet he had the modelboaters on his mind!
dennisw100
Re: Chain saw oil.
« Reply #4 on: May 31, 2006, 07:22:43 pm »
Grease is just a thick oil, and oil is a thin grease ;)
Aerosol spray grease would be good as it penetrates, the propelant and evaporating carrier ingredient takes the grease to the bearing. The white grease you get for doing car door locks and hinges, is waterproof too.
