Author Topic: Apparition!  (Read 2323 times)
Ben Tickle
Apparition!
« on: October 11, 2010, 01:44:49 pm »
With my apparition, previously i have been using 2 nimh packs. Then i transfered to 1 11.1v lipo. I have a choice of 2 which i have. I have a 30c 4200mah or 25c 2000mah pack. The 2000mah pack is considerably smaller and lighter. I am only asking if i use the smaller pack(2000mah) 25c, because it draws a large amount of current, do you think the battery may explode?
Ben :embarrassed:
F1 madness
Re: Apparition!
« Reply #1 on: October 11, 2010, 01:57:22 pm »
All depends on what esc and motor your running and the draw the motor & prop putting on esc and batts,the best thing to do is run for a minute then check the temps of the esc,motor and batts,but to be fair 3s is not really enough for this size hull,depending what you want out of it
Ben Tickle
Re: Apparition!
« Reply #2 on: October 11, 2010, 02:23:13 pm »
My boat is an apparition fitted with a jet navy 600 esc and a 700bb turbo motor 9.6v
Ben Tickle
Re: Apparition!
« Reply #3 on: October 12, 2010, 12:05:24 pm »
How can i find out how many amps my motor is drawing?
And then how do i convert this into C's?
ben
Ben Tickle
Re: Apparition!
« Reply #4 on: October 12, 2010, 02:14:49 pm »
I have spoken to model power today, and they have advised me that my 2000mah lipo 25c will be sufficeient as a:-
25c pack=50amps
and i have a 40 amp fuse inline between battery and speed controller and also between speed controller and motor.
Please may you let me know your views?
Ben ok2
Page created in 0.014 seconds with 16 queries.
