Author Topic: Small Hexagon Bolt Heads  (Read 5134 times)
tubby
« on: October 31, 2010, 05:59:22 pm »
Hi All,
I have  a 1/16th Tamar lifeboat (MS) I am building and would like to try to replicate the bolts in the deck, I would also be starting a 1/12th scale mersey (M by D)
I think I have seen something on here with ref to small bolts heads, but have searched the forum with no luck,
can anyone point me in the right direction.
Barry
6705russell
Re: Small Hexagon Bolt Heads
« Reply #1 on: October 31, 2010, 06:03:28 pm »
Hi Barry
Speedline Models do them in 1/16 scale.
Russ
triumphjon
« Reply #2 on: October 31, 2010, 07:58:25 pm »
when i built my tyne class at 1/12thscale , i borrowed a die from the local branch of the international plastic modellers society and stamped them out of plasticard , then glued them onto the deck before it was sprayed ! it may be worth contacting your local group to see if they have a suitable die ?
tubby
« Reply #3 on: October 31, 2010, 08:13:56 pm »
Hi Triumphjon,
Thanks for the idea, do you know what the AF of the boltheads was????,
I can machine an hexagon on the end of a piece of silver steel then harden it,
it is just filing the centre out to suit but I can use the outside as a guide.
Barry
Chuffy
« Reply #4 on: October 31, 2010, 08:39:46 pm »
Barry
The Speedline ones for the 1/12 are 1.98mm AF which is around 14BA, I suppose the 1/16 would be a tad smaller, although strictly scale sizes don't always look right on models.
Paul.
triumphjon
« Reply #5 on: October 31, 2010, 08:45:15 pm »
small ! it was a long time ago and ive long since sold it to a fellow modeller ! sorry i cant be of more help .
colin
« Reply #6 on: October 31, 2010, 08:59:41 pm »
Try this site not cheap but very smalll
http://www.scalehardware.com/washers-c-11
Born free Taxed to death.
Wetwater
  • My mind often wanders. Once it left completely.
« Reply #7 on: October 31, 2010, 09:52:55 pm »
   Might be worth trying   Modern Screws Ltd
   5 Dartford Road, Bexley, Kent DA5 2BH     [email protected]     tel  01322 553224
   They have a website but not everything is listed.  I bought some 12 ba nuts from them a while
   ago.  I needed to know the exact width and thickness etc before buying and asked via email.  Had
   a prompt reply with the info.   Good service.
   Alan.
Alan.
kinmel
« Reply #8 on: November 01, 2010, 07:31:08 am »
On my 1/16th Tamar I intend to use these 1mm Hex heads
I know they are off scale, but appeared ok on another model.
They also offer an etched sheet of various sized bolt heads
Chuffy
« Reply #9 on: November 01, 2010, 09:23:12 am »
Barry
Just a thought, have a look on Speedline's web site. He does a stainless steel bolt head etch set for the 1/16 Severn. It would seem that they just stick on and being stainless won't need any further finishing.
Paul
Tankerman
« Reply #10 on: November 01, 2010, 02:04:16 pm »
Plastruct-Fineline Styrene do packets of ten 250mm. strips of hexagonal rod in seven AF widths from 0.5mm. to 3.2mm.
See: www.plastruct.co.uk
Chris
longshanks
« Reply #11 on: November 01, 2010, 04:07:15 pm »
Hi Barry,
Punch and die set were available from Historex agents
http://www.historexagents.com/shop/tips_punch.php
They also do Grandt line bolts eyes etc but only a small selection.
These are great for scratch building. There is another supplier but I´m in Tenerife at the moment (lucky me). Contact Stan from Kirklees MBC he gave me the company name in the first place.
Stan
« Reply #12 on: November 01, 2010, 05:32:59 pm »
Hi Longshanks.
The company is  SB Models Barrow In Furness Cumbria . Check out my build of the Robbe Schultz on Warships and military small bolts used during construction came from SB Models.
tubby
« Reply #13 on: November 02, 2010, 03:03:44 pm »
Hi Everyone,
Thanks for all your input on this,(more than I expected),
This has given me a few options to pursue,
many Thanks
Barry
Page created in 0.028 seconds with 18 queries.
