Author Topic: supplier of brass screws  (Read 2855 times)
logoman
« on: February 27, 2011, 09:33:47 pm »
I need to find a supplier of good quality 5/16" countersunk slotted brass screws.
any ideas?
Aeronut4
Re: supplier of brass screws
« Reply #1 on: February 28, 2011, 09:09:17 am »
You don't say what diameter screw you want, but there's some small brass csk screws here - http://www.alwayshobbies.com/Tools-$4-Materials/Fixings-and-Hinges/Woodscrews.ice  5/16" may be a tricky length to find though.
tt1
  • If I only know a little - then I can learn a lot
« Reply #2 on: February 28, 2011, 12:02:26 pm »
Wood screws or machine screws?
logoman
« Reply #3 on: February 28, 2011, 07:27:56 pm »
Wood screws are what I need, I should have said, I already ordered some screws that turned out to be machine screws, not what I needed.
I don't know how to specify the thickness.
RaaArtyGunner
« Reply #4 on: February 28, 2011, 09:56:27 pm »
Indicate thickness by millimeters such as 1mm, 1.5mm, 2mm etc. I visualise the thickness of metric screws etc by looking at a twist drill bit of the same size eg 1mm drill bit etc.
Good Link from American continent fellow mayhem member  :-)) :-)) :-))
http://www.leevalley.com/US/hardware/page.aspx?p=41334&cat=3,41306
Good prompt service, good range and economical, recommended, am satisfied customer also signed up for their newsletter.
logoman
« Reply #5 on: February 28, 2011, 10:28:11 pm »
Cheers, I'm looking for 5/16" 1mm wood screws, from somewhere in the UK.
Islander1951
« Reply #6 on: March 01, 2011, 10:28:45 am »
nemesis
« Reply #7 on: March 01, 2011, 06:06:58 pm »
Hello, Don,t forget to drill your pilot hole first, brass screws have a habit of snapping, Nemesis
